On VSX-43 Using headphones in combination with Speaker B output. - AVS Forum
post #1 of 1 Old 12-10-2013, 03:53 PM - Thread Starter
Stiv6653's Avatar
I have recently replace an old Pioneer receiver with a new Pioneer VSX-43.  The manual says that I can output to speakers plugged into the speaker B output on the back of the receiver at the same time I have headphones installed in the jack on the front of the receiver.  A friend of mine did this with his VSX-92THX.   Page 15 of the VSX-43 manual says that SP>B can be selected even if the headphones are connected.  Since I am hard of hearing it is important that I be able to use the headphones and speakers via SP>B at the same time.  Is this possible and how can it be turned on.  I can listen to SP>B connected speakers by themselves but as soon as I plug in the headphones the SP>B is turned off.
Stiv6653 is offline
Reply Speakers
Pioneer Elite Vsx 43 , Vsx 92txh Elite Home Theater A V Receiver
