best speakers for around $200? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 64 Old 12-17-2013, 06:33 PM
afrogt's Avatar
Quoted: 1060 Post(s)
Liked: 763
I would get speakers I know I could build a system around.
The matching center for those Mordaunt Short bookshelf is expensive. Are you prepared to pay up to $400 for one?
http://www.ebay.com/itm/Mordaunt-Short-Aviano-5-Center-Channel-Speaker-in-Dark-Walnut-/120810780204
I think I might get two Cambridge S50 towers for $130 each. Yes its $10 over your $250 budget but you wont have to buy stands.
http://www.accessories4less.com/make-a-store/item/CAMBS70OAK/CAMBRIDGE-AUDIO-S70-5-3-way-Floorstanding-Speakers-Each-Dark-Oak/1.html
Then buy the matching center next
http://www.accessories4less.com/make-a-store/item/CAMBS50OAK/CAMBRIDGE-AUDIO-S50-4-3-Way-Center-Channel-Speaker-Dark-Oak/1.html
Then add some s30's to round out your system.
You've been given a ton of good options, you just need to make a decision and don't second guess it because if you keep having buyer's remorse you'll never be happy. I can see you're the type that's gonna agonize over whatever you buy.
Afro GT
afrogt is online now
post #62 of 64 Old 12-17-2013, 06:39 PM - Thread Starter
jack7788's Avatar
thanks but i cant get towers as i have no room for them, the bookshelf speakers are going next to my pc monitor were the old ones i ahve now are
would that center work with the cambridge sx-50 do you think?
jack7788 is offline
post #63 of 64 Old 12-18-2013, 05:03 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
I would stop worrying and buy a pair.
They are good speakers-get them and start enjoying them.
bladerunner6 is offline
post #64 of 64 Old 12-18-2013, 11:35 AM - Thread Starter
jack7788's Avatar
yea your right, im going to get the sx50s this friday and then later on get the Cambridge S50 as the center probably around febuary maybe
thank you all very much!!!! i really appreciate it!!
jack7788 is offline
Reply Speakers
Polk Audio Monitor 40 Am4022 A 2 Way Bookshelf Speakers Pair Cherry
