Dream Christmas surprise for little sister, AVS Style!!! - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 1331 Old 12-23-2013, 04:59 PM - Thread Starter
Blackmambakila's Avatar
Quoted: 53 Post(s)
Liked: 826
Originally Posted by jacob3219 View Post
I do mostly gaming and movies almost two, three times a week, is there a certain sub made for that? I rarely listen to just music unless i have a party, or a little get together.
Honestly a good sub will play in all areas equally. Whats your room demensions? How big are the openings?
80 in Sharp Aquos Quattron led 3d tv
Denon AVR-4520CI receiver DBT-3313UDCI blu ray player
Klipsch RF-82 II, RC-62 II, RS-62 II
Dual PSA Triaxes!
Xbox one, xbox 360 My Videos! >
Christmas Surprise! http://www.youtube.com/watch?v=GJcmWTpBcm0
Triax! http://www.youtube.com/watch?v=rhoKuxirdIg
http://...
Blackmambakila is offline
post #362 of 1331 Old 12-23-2013, 05:05 PM
jacob3219's Avatar
Liked: 45
20x15
with a about a 8 foot open wall to the kitchen in the back of the living room. corner fire place.
51 inch Samsung 3D plasma
AVR - Denon 1713
Front- L & R Polk T15
Center - Onkyo
Rears - Pioneer BS22
Subwoofer - none, yet
Systems - Xbox 360 Gamertag- Justdiscovering
PS3 & PS4 PSN Name - MadolynzJakez
jacob3219 is offline
post #363 of 1331 Old 12-23-2013, 05:06 PM
Hopinater's Avatar
Quoted: 2340 Post(s)
Liked: 5902
A good subwoofer is usually good for both movies and music. Some will tell you otherwise but that's pretty much a myth. Here is a great link that answers some popular myths about subwoofers that can be misleading at times:
http://web.archive.org/web/20080416034852/http://www.audiopulse.com/know-how/subwoofer-driver-guide/myths-about-subwoofers/
DaJoJo likes this.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203
Denon X4200 - Panamax M4300 - Apple TV - Xbox360 - Crowson Motion Actuator's
Hopinater is offline
post #364 of 1331 Old 12-23-2013, 05:12 PM
Hopinater's Avatar
Liked: 5902
20x15
That's pretty large area once the kitchen is taken into consideration. I'm assuming 8 ft ceilings and at least a 8x10 kitchen. IMO the BIC sub wouldn't begin to pressurize that. Your space is about the same size as mine. I would look at the SVS PB12-NSD or the PSA XV15. I would suggest ported over sealed as well (which both of those are).
That said, I still think you should contact SVS and PSA and get their thoughts.
post #365 of 1331 Old 12-23-2013, 05:13 PM
jacob3219's Avatar
Liked: 45
So, should i get my tower speakers first then? the fs-52s? My budget on the towers are 150 each.
AVR - Denon 1713
Center - Onkyo
post #366 of 1331 Old 12-23-2013, 05:22 PM
Hopinater's Avatar
Liked: 5902
Are you getting towers because the bookshelves lack bass?
If so consider a lot of people just go with bookshelves and buy a good subwoofer for the bass. Most people run their towers as small (in their room calibration) and set the crossover to 80hz anyway so towers don't really use their woofers very much.
Why do they do this? Because a subwoofer has one job to do and that is bass, so a good sub will do bass much better than any speaker and that's why people allow the sub to handle the bass.
If you like your bookshelves sound quality then I would keep them and pour the money that you were going to put into the towers into, a subwoofer.
post #367 of 1331 Old 12-23-2013, 05:23 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
i'd go for the sub as you don't have one yet.. then see if you still want the pioneer.. imho the klipsch rule where it comes to movies sound
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz , center RC-64-II 200W 59Hz-24KHz , sides 2xRS-62-II 150W 50Hz-24KHz , rears 2xRB-81-II 150W 44Hz-24KHz , heights 2x Salora T25i
Yamaha RX-A3040, SVS PB13-Ultra 1000W 14-200hz
4 mm el cheapo wire / Samsung UE-ES8000S TV+evo 2014 / Optoma DH-1015 Sony PS3
DaJoJo is offline
post #368 of 1331 Old 12-23-2013, 05:26 PM - Thread Starter
Quoted: 53 Post(s)
Liked: 826
Yep, work your way up from the inside out. Check out your receivers specs and make sure it'll take care of your future upgrades. Then upgrade your front towers and center, make sure theyre matching and will give you the sound your wanting. Then add a good sub and buy the best one you can afford, keeping in mind that you could get a 2nd matching sub in the future and give you an even better response in a room that size. Every time I bought things in a rush I kept having to return stuff until I finally got to where I wanted, it sucked
Dual PSA Triaxes!
http://...
post #369 of 1331 Old 12-23-2013, 05:27 PM
jacob3219's Avatar
Liked: 45
im using crappy Polk audio T15s as fronts, they were on sale for 50 dollars at best buy.  I just like the way the towers look too. Or should i just buy another pair of BS22s and a pioneer cs22 center, and use the rest towards a good sub?
AVR - Denon 1713
Center - Onkyo
post #370 of 1331 Old 12-23-2013, 05:28 PM
Hopinater's Avatar
Liked: 5902
I know that feeling. I've done it way too many times. You're right it sucks.
post #371 of 1331 Old 12-23-2013, 05:29 PM - Thread Starter
Quoted: 53 Post(s)
Liked: 826
For example, every time I bought better speakers my receiver would lack, every time I'd upgrade one thing something else would be a weak link. Once I restarted with an awesome receiver, I got speakers and everything else on par, then some killer subs. That's when I finally was happy
Dual PSA Triaxes!
http://...
post #372 of 1331 Old 12-23-2013, 05:29 PM
jacob3219's Avatar
Liked: 45
The 22s are so big, i might as well get a tower.  I'm just still used to the onkyo's satellite speakers.
AVR - Denon 1713
Center - Onkyo
post #373 of 1331 Old 12-23-2013, 05:30 PM
jacob3219's Avatar
Liked: 45
I just got a Denon  avr 1713 last week by the way.
AVR - Denon 1713
Center - Onkyo
post #374 of 1331 Old 12-23-2013, 05:37 PM
Hopinater's Avatar
Liked: 5902
I know what you mean about liking the looks of towers, I do too. :)
I can't say regarding the Pioneers because I've never heard them. But, if you already own them and you really like them then you will know best if you should buy more. Right now the FS52s are at Amazon for $125 each. So that's under your budget, that's a good thing.
post #375 of 1331 Old 12-23-2013, 05:40 PM
jacob3219's Avatar
Liked: 45
Yea best buy has them for 129 each. If i can something better for money, that's what im getting.
AVR - Denon 1713
Center - Onkyo
post #376 of 1331 Old 12-23-2013, 05:45 PM
Hopinater's Avatar
Liked: 5902
Similar story to mine. I was unhappy with my satellites, so I bought bookshelves but decided I wanted towers instead so I took back the bookshelves (after two days) and bought the towers. Then my weaker AVR no longer made me happy so I had to get a new one. Then I needed better bass. But this time I got smart and bought a very good subwoofer right from the start and got the PSA XV15 to replace my smaller, weaker infinities. Although the XV15 is not nearly as good as your Triaxes, but few subs are. :eek:
Blackmambakila likes this.
post #377 of 1331 Old 12-23-2013, 05:52 PM
afrogt's Avatar
Quoted: 1435 Post(s)
Liked: 982
Get the Pioneers since they match your BS22 surrounds.
Or if you want to go a completely different route then look at the Cambridge S70 towers. But you'll also need to add the matching s50 center later.
http://www.accessories4less.com/make-a-store/item/CAMBS70BLK/CAMBRIDGE-AUDIO-S70-5-3-way-Floorstanding-Speakers-Each-Black/1.html
http://www.accessories4less.com/make-a-store/item/CAMBS50BLKOPEN/CAMBRIDGE-AUDIO-S50-4-3-Way-Center-Channel-Speaker-Black/1.html
Afro GT
afrogt is offline
post #378 of 1331 Old 12-23-2013, 06:03 PM
jacob3219's Avatar
Liked: 45
hmmm the Cambridges look good. how are they compared to the Pioneers?
AVR - Denon 1713
Center - Onkyo
post #379 of 1331 Old 12-23-2013, 06:35 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Originally Posted by jacob3219 View Posthmmm the Cambridges look good. how are they compared to the Pioneers?
allthough the cambridges are really nice i would stick to the pioneers.. there more matched to combine with a subwoofer and are timbre matched with the rears and should theoreticly do pretty well.
DaJoJo is offline
post #380 of 1331 Old 12-23-2013, 06:38 PM - Thread Starter
Quoted: 53 Post(s)
Liked: 826
See jacob, this is the hard part, so many choices! Lol smile.gif thats why you got us here to help you
Dual PSA Triaxes!
http://...
post #381 of 1331 Old 12-23-2013, 06:41 PM
Hopinater's Avatar
Liked: 5902
I think I agree; but the Cambridge are nice at this price point. Decisions decisions. Glad I'm not then one having to make it for once.
post #382 of 1331 Old 12-23-2013, 06:52 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
so it is bro
me too... we just help him narrow the choices as best as we can. still have to make em urselfs though
DaJoJo is offline
post #383 of 1331 Old 12-23-2013, 07:08 PM
jacob3219's Avatar
Liked: 45
Send us a picture when the present to your sister is all set up!
AVR - Denon 1713
Center - Onkyo
post #384 of 1331 Old 12-23-2013, 07:11 PM
jacob3219's Avatar
Liked: 45
I may stick woth the pioneers, the safe choice as well they match the rears, which I do like. I just wish that sub wasn't so much money, so I can get it quicker.
AVR - Denon 1713
Center - Onkyo
post #385 of 1331 Old 12-23-2013, 07:17 PM
Hopinater's Avatar
Liked: 5902
I hear you on that. I'm busy saving right now for either a 2nd XV15 or a Denon X4000. Always saving for some upgrade but I really like what I have right now so I'm happy.
post #386 of 1331 Old 12-23-2013, 07:26 PM
Hopinater's Avatar
Liked: 5902
Blackmamba, I'm looking forward to your Christmas almost as much as I'm looking forward to my own. I can't wait to see how you pull this off. Also can't wait to hear about her reaction. You all deserve to have a super Merry Christmas after the stuff you experienced.
What line of Klipsch towers are you considering? Crutchfield has $100 off on some of theirs right now. The RF-62 II and the new RF 600 are both $100 off but that means they still cost $399 each. That might be more than you want to spend, don't know.
http://www.crutchfield.com/fg_12000_FFBrand%7cKlipsch/Klipsch-Floor-standing-Speakers.html
post #387 of 1331 Old 12-23-2013, 07:41 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
+1 :)
the bookshelfs with a good sub will also do fine. i see mine are 500 with special discount.. i payed 450€ each.
DaJoJo is offline
post #388 of 1331 Old 12-23-2013, 07:48 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
well.. so far for my happy christmas.. first day is gonna be a lonely one again. was going to go with a friend to his mother by invitation of hers. turns out his girl had him rather go with her and so he canceled the whole thing. both me and his mother suffering from that.. when do man get it that they shouldn't dance to a womans will all the time and forget about his own life:mad:
DaJoJo is offline
post #389 of 1331 Old 12-23-2013, 07:51 PM
Hopinater's Avatar
Liked: 5902
That stinks, I'm really sorry to hear that. I hope you can get another invite somewhere.
post #390 of 1331 Old 12-23-2013, 07:52 PM
jacob3219's Avatar
Liked: 45
Do any of you guys know what you are getting for Christmas from others?
AVR - Denon 1713
Center - Onkyo
Reply Speakers
Denon , Power Sound Audio Triax , Dayton Audio , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Samsung 60 Class 1080p 120hz Led Hdtv , Bowers Wilkins , Audyssey , Sonos , Monster Power
