Speaker Placement Quandary - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By johnnyFTwedge
post #1 of 10 Old 12-17-2013, 12:02 PM - Thread Starter
johnnyFTwedge's Avatar
I recently purchased the following:
Projector: Epson 5030UB
Screen: BD Zero Edge 100" 1.4 gain
Receiver: Denon X1000
Speakers: Sonance VP62 In-wall speakers
I am having difficulty deciding on where to place my speakers. The wall I am putting the screen on is only 92" wide and the screen is 88" wide. So obviously I can't put the L/R speakers to the side of the screen.
The ceiling is 9' and I was planning on putting the center of the screen at 4.5'. The screen is 49.8" tall, so this would put the bottom of the screen at 29.1" and the top at 78.9".
I've read that LCR speakers should ideally all be at the same height, so mine will either have to all go above or below the screen.
There doesn't seem to be a consensus on which option is better. As of right now I am leaning towards placing all 3 LCR speakers above the screen but would like to hear some feedback.
There will only be one row of seats that can be moved from 10' to 13' from the screen.
Any suggestions would be much appreciated.
johnnyFTwedge is offline
post #2 of 10 Old 12-18-2013, 01:40 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
The bottom of the screen is much closer to your ear level, which should be around 36" above the floor.
Next time, try giving some thought to the audio first, before you buy a screen too big for the room.
I would always prefer to have better audio than an over sized screen...just my opinion.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 10 Old 12-18-2013, 02:26 PM
Bill Fitzmaurice's Avatar
Liked: 4663
Don't believe everything you read. They are three discrete speakers playing three discrete sources, so while they should have very similar, if not identical, frequency response, they need not be at the same level. What comes from the center will seem to be coming from the center of the screen, whether it's above or below the screen, because your eyes says so, and visual directional cues over-ride audio directional cues. I have my L/R up high, aimed downward, and my center below the screen, because there's no room for it above the screen. No issues at all.
Depending on the angle of the seats you might put the screen higher. I sit in a recliner, my screen center is 6 feet above the floor, the top 6 inches from the ceiling.
Bill Fitzmaurice is online now
post #4 of 10 Old 12-18-2013, 02:55 PM - Thread Starter
Appreciate the response.
I'm just the opposite. I prefer to largest screen possible, even if it means slightly less audio.
post #5 of 10 Old 12-18-2013, 02:57 PM - Thread Starter
The guy that sold me the speakers suggested I do the same as you, LR above screen and center below. Good to know someone has actually tried this.
I will probably play around with different locations before I cut the holes in the wall.
post #6 of 10 Old 12-18-2013, 04:13 PM
JerryLove's Avatar
Liked: 79
This is great advice if all the speakers have perfect off-axis vertical response.
If, like all speakers in the real world, the off-axis vertical response varies from the on-axis response; then this will make the center out of tembre' (possibly to downright bad). You could solve the problem by angling the center speaker up; but that's going to create a "sweet spot" that's on-axis surrounded by off-axis areas.
Some speakers have good off-axis vertical dispersion, but others do not. I certainly would not reccommend something like an ML planar speaker for such use.
In short: I think the advice can work for some speakers and some setups; but will be problems with others.
Given how close together your speaker are: I wonder if a center channel is even appropriate. Of course, some people will tell you that you need a speaker in the center to hear sound in the center, but these same people will tell you that a center on the floor will make sound in the center of the wall; so perhaps that claim deserves a grain of salt.
JerryLove is offline
post #7 of 10 Old 12-19-2013, 02:53 PM
Nuke61's Avatar
Quoted: 18 Post(s)
I would do all speakers below the screen. The reason is seamless panning for the sound field. I've tried the center low and L/R high and didn't like the result. Even though they are in-walls, I suggest temporarily placing them at the possible locations and listening for yourself.
Nuke61 is offline
post #8 of 10 Old 12-30-2013, 06:41 AM - Thread Starter
I ended up putting all 3 front speakers above the screen. I used the Audyssey setup mic that came with the Denon X1000 and the results are great. The sound seems to come from the screen, not above. I couldn't be more pleased.
biotron2000 likes this.
post #9 of 10 Old 12-30-2013, 06:58 AM
Liked: 4663
You'd hear it coming from above the screen with your eyes closed. Open your eyes and the sound comes from the screen. That's basic psycho-acoustics at work. cool.gif
post #10 of 10 Old 12-30-2013, 07:10 AM - Thread Starter
Luckily I watch TV with my eyes open.
Reply Speakers
Epson 5030ub 2d 3d 1080p 3lcd Projector , Denon Avr X1000 5 1 Channel Home Theater Receiver
