One rear speaker set 3db louder? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-17-2013, 07:59 PM - Thread Starter
brazosdog02's Avatar
After running audyssey my left rear speaker is set to +2.0db and the other was set to +1.5. She sitting I. My seat and watching tv, the sound is really lopsided. So, to get it where I think it sounds balanced, I set the right surround to +5.0. NOW it sounds balanced to me. Is this a room acoustics thing? I'm nearly certain that originally the speakers sounded the same when you walked up and looked at them but sitting that is certainly not the case. It's like the one isn't even on.
brazosdog02 is offline
post #2 of 8 Old 12-17-2013, 08:29 PM
afrogt's Avatar
Quoted: 1060 Post(s)
Liked: 763
swap the two speakers and run Audyssey again. If it sounds lopsided the same way its probably the room acoustics. Or maybe when you calibrated the room you didn't do enough listening positions.
How many positions did you place the audyssey mic in?
You said left rear speaker. Is this a 7.1 or 5.1 setup? Left rear speaker implies a 7.1 setup.
Afro GT
afrogt is offline
post #3 of 8 Old 12-18-2013, 09:00 AM - Thread Starter
Its 5.1. I guess I meant "rear surround". I did 6 positions. Its on a flat part near an angled ceiling, whereas the other is on a flat par with no angles around it.
post #4 of 8 Old 12-18-2013, 09:11 AM
Bill Fitzmaurice's Avatar
Liked: 4740
That accounts for the difference. Google 'space loading'.
Bill Fitzmaurice is offline
post #5 of 8 Old 12-18-2013, 09:54 AM - Thread Starter
Yeah, The speaker is 'even' with it, but Im sure there are effects. I was actually going to re-calibrate without using teh seating location closest to that wall and angle since no one sits in it much.
post #6 of 8 Old 12-18-2013, 10:00 AM
jcwhammie's Avatar
Quoted: 45 Post(s)
Liked: 47
You may want to get an SPL meter at radio shack so you'll know when they are the same dbls at the main listening position. I used to do my adjusting by what I perceived the speakers to sound the same dbls, then I got the SPL meter. I was a few dbls off on a few speakers.
TV: Panasonic 60GT50/ Receiver: Yamaha RX-A2020/ Bluray: PS3 Slim/ Fronts: Focal Chorus 726V/ Center: Focal Chorus cc700V
Surrounds: Focal Chorus 705V
Subs: (4) sealed SI HT 18" powered by Inuke NU6000dsp
jcwhammie is online now
post #7 of 8 Old 12-18-2013, 01:45 PM - Thread Starter
Well, I mean perception is reality right?
I don't care if it quantitatively is the same, if it is not perceived by my ear to be the same, then its going to sound weird, right?
post #8 of 8 Old 12-18-2013, 02:15 PM
Liked: 4740
+1.
Reply Speakers
