Speaker/Receiver/Sub Suggestions for 18x12' living room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 12-20-2013, 12:36 AM - Thread Starter
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
I'm looking for suggestions on a solid set of speakers in the $300 range (5.1 surround sound). Speakers will be for everyday listening, multiple uses. Movies, music, gaming, etc. Normal seating area will be about 8-14' away from television and front/center speakers. Here's what I was considering so far:
Subwoofer:
Klipsch Sub-12HG Synergy Series 12-Inch 300-Watt Subwoofer with High Gloss Trim (Black)
Speakers:
I was looking to keep these in the $300 range.
Polk Audio Blackstone TL150
http://www.crutchfield.com/p_107TL150/Polk-Audio-Blackstone-TL150.html
Receiver:
Denon E300
http://www.accessories4less.com/make-a-store/item/DENAVRE300/DENON-AVR-E300-5.1-3D-Networking-Receiver-AirPlay/1.html
Little note about the receiver. I would like something that has bluetooth/wifi built in, but it's not completely necessary. I understand the above receiver does not but I have heard great things about the automatic speaker tuning features of this particular lineup.
Thanks for the help!
jhoffy22 is offline
post #2 of 21 Old 12-20-2013, 02:10 AM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1733
amazon affiliate link removed.
jhoffy22 likes this.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #3 of 21 Old 12-20-2013, 04:57 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
How big is your room?
What is your total budget for everything -speakers,sub & receiver
bladerunner6 is offline
post #4 of 21 Old 12-20-2013, 09:57 AM - Thread Starter
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
Sorry, that was not even my aff link. I copy pasted from Slickdeals where they automatically insert affiliate links when someone posts a link to a store.
Roughly $8-900. 18 feet by 12 feet, rectangular. TV/front stage sits on the 18 foot span so long ways in the room if that makes sense.
jhoffy22 is offline
post #5 of 21 Old 12-20-2013, 10:11 AM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1733
DrDon is offline
post #6 of 21 Old 12-20-2013, 10:16 AM
Quoted: 20 Post(s)
Liked: 59
Some Polks,Primus, Pioneer or Cambridge speakers would be some typical options.
A BIC F-12 or NXG sub could be among your choices,
A receiver from accessories4less or a closeout/open box deal from a B&M store might be your choice.
post #7 of 21 Old 12-20-2013, 10:21 AM - Thread Starter
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
What do you think about the Polk TL150s vs the monoprice setup? I know there are underground brands that perform much better than mainstream brands like Polk or Klipsch etc. If you're curious about what monoprice setup I'm talking about just google Premium 5.1-Ch. Home Theater System with Subwoofer monoprice. That is the one. I can't post links.
jhoffy22 is offline
post #8 of 21 Old 12-20-2013, 10:32 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
They will be better than TV speakers - however, there are better options as
bladerunner6 has stated.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #9 of 21 Old 12-20-2013, 10:48 AM - Thread Starter
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
Any specific direction I should look? My budget for the speakers is $300ish.
jhoffy22 is offline
post #10 of 21 Old 12-20-2013, 10:51 AM
Quoted: 20 Post(s)
Liked: 59
If you are willing to spend 800-900 total for everything you will vastly better performance from buying individual components rather than the Polk or Monoprice systems you listed.
Here is a link to the Pioneer speakers-
http://m.newegg.com/ProductList?Keyword=Pioneer+speaker
The speakers ending with "1" are an exceptional bargain.
Some Primus speakers such as the P163 are popular choices.
http://www.harmanaudio.com/search_browse/reconditioned.asp?brand=INF
Some Cambridge bookshelf and a center are pretty close to your budget.
http://www.accessories4less.com/index.php?page=search&search_query=Cambridge+Speakers
post #11 of 21 Old 12-20-2013, 11:00 AM - Thread Starter
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
I basically had a ~$300 budget for just the speakers. (front, rear, center)
Thanks for the suggestions.
jhoffy22 is offline
post #12 of 21 Old 12-20-2013, 11:07 AM
Quoted: 20 Post(s)
Liked: 59
The Pioneers fit your budget-towers, center and bookshelf for tears.
post #13 of 21 Old 12-20-2013, 11:11 AM - Thread Starter
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
Alright so the Pioneers are the better buy (anything ending in "1") over the Polk TL150s.
jhoffy22 is offline
post #14 of 21 Old 12-20-2013, 11:31 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
If you desire the Polk - then buy them
I recommend one pair of Pioneer BS22 bookshelf for fronts
The C22 center, to match the B22
Then get one pair of the BS21 for surrounds
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405
Who AM I
zieglj01 is offline
post #15 of 21 Old 12-20-2013, 11:33 AM
Quoted: 20 Post(s)
Liked: 59
That is also an excellent idea.
post #16 of 21 Old 12-20-2013, 11:55 AM - Thread Starter
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
Thanks guys!
jhoffy22 is offline
post #17 of 21 Old 12-20-2013, 12:11 PM - Thread Starter
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
I see the BS21 speakers are 6ohm speakers, would these work well with the Denon AVR E300?
jhoffy22 is offline
post #18 of 21 Old 12-20-2013, 12:31 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Yes
Who AM I
zieglj01 is offline
post #19 of 21 Old 12-20-2013, 12:38 PM - Thread Starter
jhoffy22's Avatar
Quoted: 61 Post(s)
Liked: 29
Yes
It looks like the Denon AVR E300 is going to be a bit too powerful for these speakers. They are rated for 80w RMS and the Denon puts out 125w rms @ 6ohms. Sorry I can't post direct links due to being a new member. Is it okay to overdrive them by this much?
jhoffy22 is offline
post #20 of 21 Old 12-20-2013, 01:00 PM
Quoted: 20 Post(s)
Liked: 59
You won't be overdriving them-take the receiver's specs with a grain of salt.
post #21 of 21 Old 12-20-2013, 01:00 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
No, it will not be too powerful for the speakers - most people do not even use 80 watts of
the receiver. Do not get too carried away with speaker and receiver specs. The subwoofer
will relieve some stress off the speakers.
Also, in surround mode - the Denon becomes less efficient
The only issue would be if you are an extreme head-banger.
Who AM I
zieglj01 is offline
Reply Speakers
Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Denon Avr E300 , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
