Speaker Advice for Loft with Concrete Floors - AVS Forum | Home Theater Discussions And Reviews
Old 12-22-2013, 08:33 AM - Thread Starter
mangothehuman's Avatar
Folks,
I'm looking for some suggestions for speakers for my living room. Currently, we are running sound out of the TV and it is driving me insane. I've been doing some research and was considering purchasing two floorstanders and a center channel. Possibly a sub as well depending on the speakers, but preferably without because of aesthetics.
Considering the room setup/layout, is it worth spending more on very good speakers or is the audio going to suck no matter what because of the acoustics of the room (concrete floors, very high ceilings, etc)?
Also, any suggestions on speakers? I'd like to pick up the two floorstanders for around $1200 or less. I have an Onkyo TX-SR707 receiver (still chugging away!). Here's where I'm at in no particular order and price per pair:
  1. Monitor Audio RX-6 ($1200)
  2. PSB Image T6 ($1200)
  3. Polk Audio LSI-15 or LSI25 (800-1200)
  4. Polk Audio RTI12 ($800)
  5. Emp Tek E55Ti (~$700)
  6. Definitive Technology BP-8040ST ($1000ish)
Any thoughts on this list?
mangothehuman is offline
Old 12-22-2013, 08:50 AM
Quoted: 911 Post(s)
Liked: 489
Nice place!
As someone with a system in a loft with concrete floors
(see also system link below) some advice:
1) Get a thick real wool (not petrochemical) rug for between the speakers and sofa. And put a natural-fiber rug pad under it.
2) Ditch the coffee table. It's at least as problematic than the floor itself is. Possibly more so. Ideally, replace with plush ottoman upholstered in breathable cloth.
3a) Look for speakers with some vertical directivity control for the mids and treble, to keep floor-bounce away as much as possible. That means waveguides or concentric drivers, or at least an MTM driver layout. (A line array/CBT might work well in that room too, but any decent one would be way over budget.)
3b) However, the catch here is that because of the distance between your side-walls and the listening space, you also want a very broad horizontal pattern. Otherwise, while image focus will be very intense (unrealistically so, in my experience) there will be little spaciousness to the sound.
4) Keep the mids and tweets (or concentric mid/tweet) fairly high off the ground.
5) Add surround side and surround rear speakers placed well if you can, and listen to music in Dolby Pro Logic II to reclaim some of the ambience lost due to the far-away sidewalls.
Of the speakers you've listed, honestly I'm not fond of any of them.
I'm not familiar with any of the speakers you've listed, but keep in mind that Definitive's knockoffs of old Mirage speakers require quite a bit of space from the front wall due to their bipolar radiation.
IMO, something like the Gallo speaker with two balls between a short cylindrical tweeter, mounted on the wall, would work very well in your room, with subwoofers and "room correction" EQ to compensate for Gallo's incompetent crossover designs.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Old 12-22-2013, 09:04 AM
Bill Fitzmaurice's Avatar
Liked: 4630
It is. The most important thing you can do is to fully carpet the floor in the living/dining area. Otherwise it doesn't matter what speakers you get, they'll all sound bad.
mangothehuman likes this.
Bill Fitzmaurice is online now
Old 12-22-2013, 09:31 AM - Thread Starter
Awesome, thank you for the advice! I'll take a look at Gallos as well.
Originally Posted by DS-21 View Post
Nice place!
Old 12-23-2013, 04:40 PM - Thread Starter
Any other suggestions for speakers?
Old 12-23-2013, 04:59 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
If doing some treatment to your floor >>
Then Monitor Audio Silver
And Focal
http://www.accessories4less.com/make-a-store/brand/focal/results/1.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 12-23-2013, 05:57 PM
Quoted: 911 Post(s)
Liked: 489
Not new and I have no idea about used prices/availability, but anything from Snell's old "XA" line (ca. 2001) would be a perfect fit sound-wise. They combine very wide horizontal patterns with a narrower vertical pattern. And just very well engineered speakers all around, better than all but a small handful of current-production speakers. There were a lot of different models: a line or two of towers, some in-cabinet ones, and some in-wall ones. Look for an array with two small midranges flanking a tweeter on a bowtie-shaped "waveguide." They are one of the few speakers I've heard where the horizontal center doesn't stick out horribly. Previous - and subsequent - Snell speakers were not as good.
Alas, I don't know of anything new that is similar.
The NHT Classic Three/Classic Four is a very good current speaker with very wide horizontal dispersion. Not as good vertical, though. I think they're in your budget. (Only if you are doing 2-channel or can fit three of them across the front, though. The "matching" center is horrible. Two Fours with a Three in the middle would work fine.)
The Phase Technology PC3.5 is something else to look at, though I don't remember how much they cost. Again very wide horizontal pattern, and some pattern control down low due to the woofer spacing.
The KEF Q100, Q500, or Q900 might also be something to try out. Or R100. They may be a little too focused in your room, because of the relatively narrower horizontal pattern. The overall design can be improved, but they're still very good and that concentric driver is one of middle-priced audio's greatest wonders. (The Q300/Q700 are not as good as the others.) Again, avoid the "matching" center channels if you're doing 3-channel.
Serious Audio Blog
DS-21 is offline
Old 12-23-2013, 06:20 PM
losservatore's Avatar
Quoted: 2299 Post(s)
Liked: 2046
Sorry but your room is challenge, guys I think a more directional sound will help better than a speaker with lots of dispersion.
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
Old 12-23-2013, 07:13 PM
RN2013's Avatar
Liked: 47
Yes, concrete floors and high ceilings can be tough...but there are exceptions to every "rule". I have a very very large open concept room with tile on concrete and a couple of area rugs. I'm running Tekton Lores and they have good imaging, strong bass and are very musical.
Maybe some loudspeakers won't do the job but I'm pretty sure the Lores will.
RN2013 is offline
Old 12-23-2013, 10:02 PM - Thread Starter
The XA line looks nice, but looks like it'll be hard to find. Not much on eBay.
The Focal's look like a great option and good price point for what they offer.
And Focal
Those Lore's aren't the prettiest, so I'll have to make sure they're girlfriend approved, but seems like they offer a fantastic speaker for the price.
Old 12-23-2013, 10:17 PM - Thread Starter
Whats the general consensus on Polk's? They seem to be priced pretty well but I'm not seeing a lot of love?
Also, as far as floor treatments are concerned, we do have two large thick wool rugs that are in the living/dining room, so I think that will cut down on some of the sound issues. They have a small pad underneath, but I can spring to get a thicker one. I can't imagine we'll opt for more carpeting or rugs. Not sure if that changes any of the suggestions.
  6. Snell XA (???)
  7. Emp Tek E55Ti (~$700)
  8. Focal 727V ($849)
  9. Tekton Lore ($1000)
  10. Definitive Technology BP-8040ST ($1000ish)
Old 12-23-2013, 10:24 PM - Thread Starter
And Focal
Was there a particular Focal model that you recommend?
Old 12-23-2013, 10:32 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The 727V
http://www.accessories4less.com/make-a-store/item/FOCAL727VHVN/FOCAL-Chorus-727V-726v-Triple-6-1/2-Tower-Speaker-PAIR-Havana/1.html
Who AM I
zieglj01 is offline
Old 12-24-2013, 09:26 AM
Quoted: 911 Post(s)
Liked: 489
I don't think any speaker with a tweeter on a flat baffle and a large midrange is a good option regardless of price point.
Serious Audio Blog
DS-21 is offline
Old 12-24-2013, 12:08 PM - Thread Starter
This is a little more than I want to spend, but the guys at Magnolia suggested the martin logan esls. Any thoughts on those?
Old 12-24-2013, 06:24 PM
RN2013's Avatar
Liked: 47
I suspect that they don't have the volume capability or the low end to really shine in a room that large...also, are you able to place them 4-5 feet out into the room...
RN2013 is offline
Old 12-24-2013, 07:46 PM - Thread Starter
ha, no way I can put those 4-5 feet out into the room!
Old 12-24-2013, 08:10 PM
RN2013's Avatar
Liked: 47
I'd say you've reached the point where you pick any of the speakers on your list that you can return at no cost or low cost to you and see how they sound in the "big room". The psb's if purchased from crutch field would be $50 to return...which is pretty reasonable.
Have you considered a bookshelf/sub combo?
RN2013 is offline
Old 12-24-2013, 08:31 PM
Liked: 2046
I think that a speaker with a horn or a waveguide have a more controlled directional sound than a ribbon or planar tweeter .
Old 12-24-2013, 09:39 PM - Thread Starter
Very true - I was hoping to eliminate a few first before I started buying/testing/returning.
I would definitely consider a bookshelf/sub combo. I was leaning towards a floorstander mostly because of the size of the room and because I really cannot get more than a 3.1 setup for that room. If you know of any that you think would be worthwhile looking at - I'd definitely consider them. Are there benefits to using bookshelf speakers over floorstanders?
Hmm..Noob here so I'm not entirely sure what the differences are, but I'm going to definitely take advice into consideration.
Old 12-24-2013, 09:53 PM
RN2013's Avatar
Liked: 47
Have you considered HSU...great bookshelves, high power handling, controlled directivity, great pricing... and great subwoofers....and package deals...
Go to hsuresearch.com and check them out as an option.
RN2013 is offline
Old 12-25-2013, 03:57 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
a horn is better able to direct the sound towards you as opposed to spreading out and bouncing off the floor and walls.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Old 12-25-2013, 07:07 AM
Liked: 4630
To some extent, but nowhere near as well as a line array. In any event I assume that you mean a horn loaded tweeter, not a horn loaded speaker, and a horn loaded tweeter does nothing for vertical pattern control in the midbass and midrange. Where the OP is concerned an MTM like the Hsu HC1, configured for vertical use, would probably work well.
They don't take up floor space, and dollar for dollar perform better than floor standers, unless you don't have subs, which tends to be a bad idea for HT.
Old 12-25-2013, 06:02 PM
defmoot's Avatar
Could you expand on this a bit? What is it that you find objectionable? Which model(s) do you have experience with?
I run Classic Threes in phantom center mode with an Outlaw EX sub and was considering adding a ThreeC or TwoC center. I really like the Threes and assumed the WTMW configuration of the centers would provide decent quality sound, up to the level of their other speakers (horizontal layout notwithstanding).
hi-fidelity — why fight it?
defmoot is offline
Old 12-25-2013, 06:54 PM
Liked: 2046
Off topic question....
Are you against floorstander speakers?I haven't see a single post of you recommending floor standing.
Old 12-25-2013, 08:15 PM
Quoted: 911 Post(s)
Liked: 489
The one with the dome mid-tweeter flanked by two woofers. It's marginally better than a standard toppled-MTM, but not much better. Same issues, just a little lower in frequency. The dome mid just doesn't go low enough to work in the configuration.
Serious Audio Blog
DS-21 is offline
Old 12-25-2013, 08:44 PM
defmoot's Avatar
Thank you for the response.
The crossover points for both the Classic Three bookshelf and the ThreeC center are 800Hz (2nd order) and 3.2kHz (3rd order). Why would the Three bookshelf be better as a center, crossover-wise, if the points are the same?
defmoot is offline
Old 12-25-2013, 08:58 PM
Liked: 4630
Off topic question....Are you against floorstander speakers?I haven't see a single post of you recommending floor standing.
I recommend them when they're the best choice for the intended application. IMO that's very seldom the case.
Old 12-26-2013, 02:12 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Yes, I was referring to a horn loaded tweeter. Question, isn't it the higher freqs anyway that are the most energetic and suffer more from reflections?
Old 12-26-2013, 03:03 AM
Liked: 2046
Bill Fitzmaurice I think that we are more concerned about the high frequencies.smile.gif
Monitor Audio Rx 6 Floorstanding Speaker , Psb Image T6 Tower Floorstanding Speaker , Polk Audio Lsi15 Left Channel Tower Speaker Single Cherry , Polk Audio Lsi15 Right Channel Tower Speaker Single Cherry , Polk Audio Lsi25 Left Channel Tower Speaker Single Cherry , Polk Audio Lsi25 Ebony Floorstanding Loudspeakers With Built In Powered Subwoofer Pair , Polk Audio Speakers Rti 12 , Emp Tek E55tir Tower Speakers , Definitive Technology Bp 8040st Ea Bipolar Tower With Built In Powered Subwoofer Each
