Help! Theater is pre-wired and send speaker wires to the wrong room. Send it back on a 1-2 coax? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-04-2014, 03:36 PM - Thread Starter
w@ntonsoup's Avatar
I moved into a home that was a builder spec house, it's got a finished basement with a theater room with speakers all wired up but it was never used. The problem is that the wires are all run into a utility room 30-40 feet away. This is a problem because I'll be installing an XBox360 and PS3 into the system and the range for those is like 30 feet AT BEST but my setup is through 3 walls too so it's too far.
The potential saving grace is that there are two coax cables run FROM that distant utility room, TO a small room just behind the theater that I want to use as the hidden equipment area. So my big question is: Is it possible to use 1-2 coax cables to transmit multiple speaker wire signals? I can't see how. But it never hurts to ask.
Presuming to answer questions you may ask, I think it would be difficult to run a new run of speaker wire from the utility room to anywhere. It's a completely finished basement.
I am feeling sunk. Any help would be appreciated.
w@ntonsoup is offline
post #2 of 5 Old 01-04-2014, 08:51 PM
Bill Fitzmaurice's Avatar
Liked: 4652
Coax cables should not be used for speakers. They probably are too small a gauge and too much capacitance.
Bill Fitzmaurice is online now
post #3 of 5 Old 01-04-2014, 09:38 PM
sm4llz's Avatar
Quoted: 47 Post(s)
What if you run separate HDMI cables from the utility room (AVR) to the closer room and setup the xbox and playstation there?
sm4llz is online now
post #4 of 5 Old 01-04-2014, 09:48 PM - Thread Starter
w@ntonsoup's Avatar
It's really not feasible to run wires.
I found a component speaker cable in the run and am going to try to use those as speaker cables for the return trip back from the utility room, I'll post my results.
post #5 of 5 Old 01-09-2014, 05:43 PM - Thread Starter
w@ntonsoup's Avatar
Problem solved! I was able to successfully use the component cables to send the speaker signal back where I want it. Whew!
Reply Speakers
Xbox 360 Console
