where to set my crossovers on my avr - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-06-2014, 08:48 PM - Thread Starter
bearbear22's Avatar
Denon 2113ci
Energy cf-50's
sony sub (htib sub) small 8"
listening rm. 2000 cubic ft.
buying a svs pb1000 so im assuming my crossover set up will change then.
right now mains & sub are all at 80hz. thanks advice is appreciated with this setup and after the pb1000 gets here.
bearbear22 is offline
post #2 of 11 Old 01-06-2014, 08:53 PM
Elihawk's Avatar
Quoted: 1015 Post(s)
Liked: 860
The subwoofer, while a huge improvement, should not change your x over settings. Those are usually set based on the limitations of your front L/R/C speakers.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #3 of 11 Old 01-06-2014, 08:57 PM - Thread Starter
bearbear22's Avatar
well they sound fantastic at 80 so ill stick with that. thanks
can hardly wait for the svs.  gonna start with the pb1000 and work the upgrade every year till i demo my house down with LFE...lol
post #4 of 11 Old 01-07-2014, 08:06 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
80hz works great, your CF-50's are rated to "39Hz - 20kHz ± 3dB " so you could set their crossover to 40hz (Don't suggest doing that though) but personally I wouldn't go lower than 60hz. Play around with your crossover and see what sounds best
67jason likes this.
crazyrob425 is offline
post #5 of 11 Old 01-07-2014, 08:51 AM - Thread Starter
bearbear22's Avatar
the "merlin wizard" on SVS's website also said 60hz
actually it said 60hz in multichannel and 40hz in 2.1 ch.
does that mean every time i go from movies to music(stereo mode) i should switch from 60-40?
assuming it sounds right to my ears.
post #6 of 11 Old 01-07-2014, 09:38 AM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1300
Just leave it on 80 or run your speakers as large with the sub active on all frequencies. My AVR lists this a LR +LFE in the sub setup. Meaning that the sub gets all signals for the mains speakers plus LFE content from movies. Your LR speakers will get full signal minus the LFE track.
See what you like best.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #7 of 11 Old 01-07-2014, 09:42 AM
Elihawk's Avatar
Liked: 860
As Crazyrob suggests, try 50, 60, 70, 80 and just see which sounds best to you. However, even though your towers are capable of going below 80hz, will they sound better than your subwoofer at those frequencies!? I would think not, which is why I would set the crossover to 70/80hz and enjoy the SVS sub doing what it does best!
Elihawk is offline
post #8 of 11 Old 01-07-2014, 10:29 AM - Thread Starter
bearbear22's Avatar
Thanks you guys.
post #9 of 11 Old 01-07-2014, 10:32 AM
mark62's Avatar
Liked: 88
80hz
mark62 is offline
post #10 of 11 Old 01-07-2014, 10:52 AM
Hopinater's Avatar
Quoted: 1781 Post(s)
Liked: 4390
As stated above, you can try 60, 70, 80 and even 90 but most people seem to end up around 80. Some of that has to do with the quality of your subwoofer. Someone with a cruddy subwoofer may find crossing lower to allow their towers to handle the bass to be a good idea where as someone with a good subwoofer (like your SVS will be) may even want to cross over a little higher like 90 to let the sub handle even more bass.
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #11 of 11 Old 01-07-2014, 11:05 AM
Bill Fitzmaurice's Avatar
Liked: 4631
Originally Posted by crazyrob425 View Post
your CF-50's are rated to "39Hz - 20kHz ± 3dB so you could set their crossover to 40hz
A pair of 5.5 inch woofers are going to run out of gas real quick running them to 60Hz, let alone 40Hz. Depending on how loud he wants to go he might find 100Hz gives the best overall result, only by experimenting will he know.
Bill Fitzmaurice is offline
Reply Speakers
Denon Avr 2113ci Receiver , Energy Cf 50 Floorstanding Tower Speaker Black , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
