A $2,000 budget for a HT system-What Would U Do? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-07-2014, 05:32 AM - Thread Starter
TheSeanO's Avatar
Quoted: 20 Post(s)
I friend of mine would like to improve his HT from his current TV speaker to a 5.1 Ch system. His budget is $2000. I put together a package that would allow him to upgrade in the future. The system is based around the Onkyo TX-NR 818 7.2.
List of components:
L&R Ch. Klipsch RF-42 II $300 ea.
Center Ch. Klipsch RC-42 II $250 ea.
Surrounds Pioneer SP-BS22-LR $126 pair
Subwoofer Klipsch SUB-12HG Synergy Series $299 ea.
Receiver Onkyo TX-NR818 7.2 $699
Total: $1974 (Under budget)
If any money is saved I told him to put it toward the next higher center speaker. What do you think of this system? Anything you would change, or would you go a different route?
His room is open around 14x18. 10ft ceilings. (estimation)
TheSeanO is offline
post #2 of 15 Old 01-07-2014, 06:07 AM
Remythepug's Avatar
List of components:
Having just gone through a complete overhaul w/ a similar budget, my suggestion would be to wait until next year. I saved a good amount of cash on everything from the black friday specials. All online purchases btw - tv, avr, 5.1 spkrs
I also skipped over the Onkyo receivers after several hi-fi dealers kept mentioning the hdmi board problems. I went w/ a Marantz 5008 refurb from A4L. Also, given the 818 is a model old, are you actually able to find one?
In terms of speakers, have you looked at emptek? I chose their tower 5.1 setup as the reviews were good and consistent. Plus it's a small company and you skip the middleman, among other benefits.. My backup plan was the bic acoustech.
In the end, I would encourage you to look beyond the staple labels of klipsch, pioneer, and onkyo. Talk to some dealers (ie. AV Science) for some suggestions too. After all, they do this for a living while I'm just pretending. Good luck w/ helping your buddy.
Remythepug is offline
post #3 of 15 Old 01-07-2014, 06:27 AM - Thread Starter
TheSeanO's Avatar
Quoted: 20 Post(s)
Thank you for the reply. I will have to look into some of the other brands that you mentioned.
TheSeanO is offline
post #4 of 15 Old 01-07-2014, 08:33 AM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
The buyer might not want refurbished equipment, and Black Friday is a loooooong time away...life is too short to wait!
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #5 of 15 Old 01-07-2014, 12:08 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Smooth and refined with good spacious sound - not your regular horn speaker. The Studio 5
series has a clear/clean transparent sound, with good detail, definition and depth. >> Also,
good punch and dynamics.
You can upgrade the sub later.
http://www.sounddistributors.com/buynow.asp?action=detail&prid=2008&crid=321&cat_name=JBL+Speakers
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #6 of 15 Old 01-07-2014, 12:32 PM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 881
$500 - receiver
$500 - subwoofer
$1000 - 5 Identical bookshelf speakers.
KidHorn is online now
post #7 of 15 Old 01-07-2014, 12:38 PM
jephdood's Avatar
Liked: 53
As far as I've heard, the HDMI issues with Onkyo have been resolved quite some time ago.
jephdood is offline
post #8 of 15 Old 01-07-2014, 05:38 PM
swarm87's Avatar
Quoted: 112 Post(s)
Liked: 89
if you want klipsch rf-42 id go for whole system http://www.ebay.com/itm/Klipsch-RF-42-II-Home-Theater-System-FREE-PL-200-/370531150895?pt=Speakers_Subwoofers&hash=item564560ac2f comes with a free pl-200 for ~1200 from an authorized dealer. this leaves you with $800 for a good receiver.
pcm=potato
bitstream=patato
swarm87 is offline
post #9 of 15 Old 01-07-2014, 06:19 PM
Hopinater's Avatar
Quoted: 1784 Post(s)
Liked: 4394
Personally I'm not a fan of the Klipsch Horned tweeters but if he finds that he likes them then I would say they may be a good way to go. Other speakers I would consider would be EMPtek and HTD as they get a lot of love her in the forums.
But I would definitely skip the Klipsch subwoofer and look at something like the SVS PB-1000 at $500.
I have had Onkyo, Denon, Marantz and Sony AVRs and IMO the Denon and Marantz are the best.  If the Onkyo HDMI issues truly are fixed then are good as well.
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #10 of 15 Old 01-07-2014, 06:34 PM
ivanpino's Avatar
Quoted: 79 Post(s)
Liked: 74
HSU RESEARCH Value 1 5.1 Package @ $1029.00 + add $ 269.00 for a second sub and have about $700.00 left for a receiver.
http://www.hsuresearch.com/products/value1pkg.html
You can find the Onkyo TX-NR818 for much less than $700.00
http://www.onkyousa.com/Products/model.php?m=TX-NR818&class=Receiver&source=prodClass
That would be a sweet system for the money. The only thing I would do different is change the centre speaker and get the same as the other 4.
ivanpino is offline
post #11 of 15 Old 01-07-2014, 07:21 PM
Mike Garrett's Avatar
Quoted: 5588 Post(s)
Liked: 3569
List of components:
mjgarrett100@gmail.com
Mike Garrett is online now
post #12 of 15 Old 01-07-2014, 07:40 PM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
List of components:
At $699 I reckon you're overspending on the AVR for a $2000 system. For a well balanced system you should only be spending about 20 - 25% of the budget on the AVR and putting the balance towards a better performing sub (or two) &/or possibly rear speakers (if your friends room can accommodate them).
So for $2000, this is what I'd do:
TOTALS:
  • 5.1 system: $1620 + Denon shipping
  • 7.1 system: $1940 + Denon shipping
  • 5.2 system: $2130 + Denon shipping
crazyrob425 and Hopinater like this.
GIEGAR is online now
post #13 of 15 Old 01-08-2014, 08:42 AM
Hopinater's Avatar
Liked: 4394
+1 ^^   I very much agree with the math and the way Giegar broke things down. Nice job.
post #14 of 15 Old 01-08-2014, 08:45 AM - Thread Starter
TheSeanO's Avatar
Quoted: 20 Post(s)
Thank you for all of the replies. I will look into some of those other brands and maybe using a less expensive receiver so I can put more money into the speakers.
AV Science - I sent you a PM
TheSeanO is offline
post #15 of 15 Old 01-16-2014, 03:58 AM - Thread Starter
TheSeanO's Avatar
Quoted: 20 Post(s)
Everything is going well. I have been doing lots of reading and research. He will not be able to make the purchase until March.
This setup was suggested to someone else in a similar situation on AVS. I find it is hard to stay on budget when the next step up is only a few hundred dollars more. I blame marketing departments, lol. I have spoken to AV Science and will contact him again closer to purchase time.
Receiver: Denon AVR-X1000 $450.00
http://www.amazon.com/Denon-AVR-X1000-5-1-Channel-Networking-Receiver/dp/B00CALM2JY
Left/Right speaker: Definitive Technology ProMonitor 1000 $219.00 each
http://www.amazon.com/Definitive-Technology-ProMonitor-Bookshelf-Speaker/dp/B000V41XII/ref=sr_1_2?ie=UTF8&qid=1389764395&sr=8-2&keywords=def+tech+pro+monitor+1000
Center speaker: Definitive Technology ProCenter 2000 $293.00
http://www.amazon.com/Definitive-Technology-ProCenter-Compact-Speaker/dp/B000UW270Y/ref=sr_1_2?ie=UTF8&qid=1389764426&sr=8-2&keywords=def+tech+pro+center+1000
Surround Left/Right: Definitive Technology SR-8040BP $230.00 each
http://www.amazon.com/Definitive-Technology-SR-8040BP-BiPolar-Surround/dp/B00422L3GW/ref=sr_1_1?ie=UTF8&qid=1389764538&sr=8-1&keywords=SR-8040BP
Subwoofer: SVS PB12-NSD Outlet $599.00
http://www.svsound.com/specials/outlet-specials/pb12-nsd-outlet#.UtYgt2QQbt4
Killer home theater total: like $2240.00
TheSeanO is offline
Reply Speakers
Onkyo Tx Nr818 , Klipsch Rf 42 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rc 42 Ii Reference Series Ii Center Channel Loudspeaker Black Each , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black , Marantz Sr5008 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
