Premier Acoustic PA-8C - I have a tweeter issue, I Think... - AVS Forum | Home Theater Discussions And Reviews
Old 01-08-2014, 01:06 PM - Thread Starter
kgunkrow's Avatar
Yamaha RX-V467
PA-8C LCR speaker
LINK TO COMPANY WEBSITE FOR SPEAKER:
http://www.premieracoustic.com/buyno...enter+Speakers
so the issue:
My receiver goes in volume level from -80 to +16.5 I Don't need to play it loud as hell but when I turn it up to about -15 to -10 I start hearing crackle / pop / static scary sounds based on my hearing it sounds like it's coming from the tweeter.
now I just recently got this speaker I Don't remember the exact date probly less then a month ago. A guess i've made is maybe the speaker needs to be broken in before playing at higher levels..?? or maybe my receiver isn't very good. Maybe I'm not even supposed to play anything at -15 or higher.
Can someone give advice, a reply or comment about this. please.
-Kgun
1. 8th 2014
*** EDIT-UPDATE*** NOVEMBER 21ST 2015
HELLO, PLEASE LOOK TO POST NUMBER 12 below.. for my new update
THIS SPEAKER IS FINE, (It was probly my source or equipment please read on)
kgunkrow is offline
Old 01-10-2014, 02:36 AM - Thread Starter
kgunkrow's Avatar
No response yet?
Is it possible that I was pushing the speaker too hard for what my receiver can output? Am I clipping or sending distorted signals, at the RX-V467 -10 volume?
It seems to be only the tweeter though.
-Kgun
1. 10th 2014
kgunkrow is offline
Old 01-10-2014, 05:07 AM - Thread Starter
kgunkrow's Avatar
I dunno what just happened, someone posted and it disappeared
eagerly awaiting any responses.
kgunkrow is offline
Old 01-10-2014, 07:00 AM
Bill Fitzmaurice's Avatar
Liked: 4641
Bad sounds from the tweeter indicate either the amp is clipping or the tweeter is clipping or both. The cure is simple, don't turn it up so loud.
kgunkrow likes this.
Bill Fitzmaurice is online now
Old 01-10-2014, 07:23 AM - Thread Starter
kgunkrow's Avatar
Thanks Bill,
If it's the receiver, I'm not too worried(as I may upgrade). If it were to be the speaker, I'd be more upset and worried, I've been thinking of getting two more for left and rights and after hearing the crackles/pops from the tweeter I Wasn't sure if I should . They're about 250 each on amazon but I Can get them for less on another site. I really like them as they can be used as an LCR speaker.
The one issue I've had so far is- I have the PA-8C above my monitor at my desk(it's sort of a HTR / Gaming setup) and I don't have a proper shelf setup to angle the speaker. It doesn't matter a WHOLE LOT but the speaker is definitely high for recliner use, it's proby 3-4 ft above listening height from the recliner(or seated level) and just above/infront of my head for gaming/desk chair use.
I've thought about putting a shelf up with some sort of angled wood with pads to adjust it and keep it griped on there properly.
if you or anyone has a suggestion for center speaker setups for more then just Movie use, at desk and in recliner, please reply
Thanks again Bill
kgunkrow is offline
Old 01-10-2014, 09:18 AM
psychobrew's Avatar
Liked: 30
Does the static come from both speakers or just one?
Samsung PN50C7000
Yamaha RX-V775WA
BIC Venturi DV64 Towers
BIC Venturi DV62 CLRs Center
Still building but sounds amazing so far
psychobrew is offline
Old 01-10-2014, 09:34 AM - Thread Starter
kgunkrow's Avatar
what do you mean?
I only have One PA-8C
I tested the speaker by itself.
I've been thinking of getting two more.
oh wait, do you mean other speakers I use, ..
The other speakers I Can use at higher volumes I have are HB-1 MK2 I haven't noticed any static noises from them. Maybe I Need to do more testing.
kgunkrow is offline
Old 01-10-2014, 10:08 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Maybe you need to buy an HSU center channel.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 01-10-2014, 10:36 AM
psychobrew's Avatar
Liked: 30
I thought you had two, but it seems like you figured out what I was getting at. It might be worth hooking one of your known good speakers up to the center channel to see if you still have the same issue. If not, it's likely a speaker issue. In either case, I would recommend matching your center channel to your mains anyway (i.e. sticking to the same brand and line).
Samsung PN50C7000
Yamaha RX-V775WA
Old 01-10-2014, 10:40 AM - Thread Starter
kgunkrow's Avatar
I was planning on getting 2 more of the PA-8C and use them for my fronts (so PA-8C for left / center / right)
I would then switch the two HSU speakers to my rear left rear right
and If i were to do 7 channel I'd probly get 2 more HB-1 MK2's for back left back right...
hope that clears things up.
kgunkrow is offline
Old 11-20-2015, 08:09 AM
Liked: 0
Pa 6f
I bought a set of these when I moved my 15 year old Cerwins downstairs and they sounded pretty good. After about a year the tweeter went out with popping and crackling. Had to pull the wire while we found replacement. I have a very clean power source and never turn up to distortion so I'm less than impressed. Hopefully new improved tweeters haold up better.
IMAD!man is offline
Old 11-21-2015, 06:38 PM - Thread Starter
kgunkrow's Avatar
Hello I Noticed a reply and I sort of want to update this post with my own reply I am the OP.
I have now, 2 of the PA-8C CENTER/LCR speakers
I use them vertically as left and right
I'm now using the RX-V990(old school-ish) and have been for a while.
I use the ASUS DGX PC SOUND CARD. (internal sound card)
Alls I Can say with my current setup I have no ussues with crackling the tweeters are fine. The original post I made, the crackling could of been anything, my old (new model) RX-V467 yamaha could of had some issue I Don't know It's been a while- It could of been a source issue.. -anything-
I've been happy with my current setup for a whille with the RX-V990.
The PA-8C LCR's are nice.
kgunkrow is offline
Yamaha Rx V467bl 525 Watt 5 1 Channel Av Receiver Each Black
