Using Klipsch Surround for front L/R and upgrading center channel advise - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-09-2014, 09:42 PM - Thread Starter
dmb12679's Avatar
Quoted: 546 Post(s)
Liked: 252
Due to the set up for my room I need small mountable front speakers.
Current set up:
70" Sharp above fireplace(no room on floor for big fronts)
Direct TV
HK AVR 3650
Fronts Bose 161's
Center JBL Northridge
Surround Klipsch SS1's
PA 12" ported
I really like the sound and look of the Klipsch SS1's
Question is if I run 4 SS1's and upgrade my center to a high end center like a Klipsch 52 II, or 42 II, how would it sound. The look of the bose 161's don't do anything for me, the sound is ok. The room would look much better with Klipsch SS1's all around and a Klipsch center. But would the sound be an upgrade, downgrade, or equivalent?
Any advise would help, thanks
Marantz SR6010 -- Marantz MM7025 -- Marantz UD5007
Klipsch RF-7ii's - RC-64ii - RB-51ii's - RS-42ii's - R-112sw(x2)
HK990
Denon DVD2900
Klipsch RF-7ii's
dmb12679 is offline
post #2 of 4 Old 01-10-2014, 12:19 AM
auceny's Avatar
Quoted: 42 Post(s)
Liked: 35
You won't want surrounds as your main speakers. Look at using bookshelf speakers that match the center channel. Should easily be able to find wall mounts for them unless you find something that already has them built in.
Denon 2113, Ascend Sierra-1, HTM-200se, SVS PB-1000, PSA XS15se
Downtown Chicago (condo)
auceny is offline
post #3 of 4 Old 03-23-2014, 08:33 PM
collinbii's Avatar
i too an using surround speakers for fronts and side.  i am using klipsch s1.   i am thinking about upgrading fronts to klipsch s20...is this wise
collinbii is offline
post #4 of 4 Old 03-23-2014, 08:40 PM
collinbii's Avatar
i also am using a klipsch wc24 center and am thinking about upgrading it to a 52ii
should i expect to c a noticeable sound difference.
my setup being pushed by an onkyo tx-sr876
Reply Speakers
Harman Kardon Avr 3650 Audio Video Receiver , Bose 161 Bookshelf Speaker System Black , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry
