Technical question - Bookshelved woofer not moving - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-10-2014, 06:05 AM - Thread Starter
steven1110's Avatar
I bought a pair of used Monitor Audio GX100's and after hooking them up last night I noticed the bass was weak from one speaker. I went and touched the driver and it was very very slightly vibrating so I turned off the system and manually pushed on the driver. It didn't budge at the center and at the edges it only slightly moved but was definitely "pinned" at the center. It also seems that the woofer is roughly at zero displacement, meaning that the driver isn't seized in or out of it's neutral position.
What could cause a woofer to seize in this manner? Is there anything I can do to try to fix it before returning it to sender or purchasing a woofer from M.A.?
EDIT** I should also note that the speaker's box was a little rough upon delivery. Could it seize from a hard jarring?
steven1110 is offline
post #2 of 3 Old 01-10-2014, 06:54 AM
Bill Fitzmaurice's Avatar
Liked: 4655
A blown voice coil or a fractured magnet structure.
No.
Dropping it can cause the adhesive holding the magnet structure together to fail.
Bill Fitzmaurice is offline
post #3 of 3 Old 01-10-2014, 07:14 AM - Thread Starter
steven1110's Avatar
What can cause the voice coil to blow or the magnet to fracture? Overdriving?
Reply Speakers
