Speaker Mounting assistance - AVS Forum | Home Theater Discussions And Reviews
Old 01-13-2014, 05:08 PM - Thread Starter
Methodx1's Avatar
I will be purchasing in the very near future my 5.1 setup thanks to all the great info from everyone here. So thank you for all the help. I have quite a small room measuring 16.ft(L)x 11.8ft(D) x 9 ft high ceiling.
Yamaha RX-V475
Ascend Acoustics- 170 L/R, 340c, 200 surround
SVS Sound- pb1000 sub
My only issue as you will see below is speaker location and mounting. I need to find something that I can mount to the side of my wall unit to hold the bookshelf speakers. I will not be able to use stands as the sub will take up the area needed for stands. I have found a company called pinpoint who makes a mount I think would work but, unsure if at 90 degrees it will open enough to hold the 170s. So what else is out there, that you think I can use or any other ideas. I do want something that can swivel the speakers inward so I can focus the sound If I needed.
Methodx1 is offline
Old 01-14-2014, 12:47 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
Good question, have used AM-40 mounts with my 170s but pointing straight ahead, not the 90 degree thing, but the clamps open unevenly if needed so I wouldn't think it would be a problem (and they're not in use right now so hard to eyeball it without digging them out of a box in the garage smile.gif You can't simply mount on the wall?
lovinthehd is offline
