Are Polk Audio RTI A3 recommended over B&W 686? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 86 Old 01-18-2014, 09:41 PM
mark62's Avatar
Liked: 88
also you have to keep in mind that you are in a bedroom situation and those subs will literally rattle the house, so if you are living with others may not be a good idea.
mark62 is offline
post #62 of 86 Old 01-18-2014, 09:45 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
I do live with others and it would be a good idea for payback around here lol
php111 is offline
post #63 of 86 Old 01-18-2014, 09:45 PM
mark62's Avatar
Liked: 88
Originally Posted by php111 View Post
Without what was mentioned in here or what was already mentioned, what would be "your" first speaker choice in your preference?
listen, only you can decide what is best for you.
if it was my choice it would be the Focals hands down. they are a very nice speaker. and if their rated sensitivity is honest they will play quite a bit louder than your b & w's
mark62 is offline
post #64 of 86 Old 01-18-2014, 09:49 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Thank you so much!
And now what should be done to setup a sub in the receiver? I am asking cuz in my opinion I would like a sub.
php111 is offline
post #65 of 86 Old 01-18-2014, 09:55 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
http://www.youtube.com/watch?v=oDYi-dPn_rc
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #66 of 86 Old 01-18-2014, 09:56 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Continued
http://www.youtube.com/watch?v=ZpSAQDjuWN0
Who AM I
zieglj01 is offline
post #67 of 86 Old 01-18-2014, 09:59 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
And continued
http://www.youtube.com/watch?v=uzCIMufCQLk
Who AM I
zieglj01 is offline
post #68 of 86 Old 01-18-2014, 10:00 PM
mark62's Avatar
Liked: 88
zieglj01 i didnt watch the videos but he has a stereo receiver with a sub out. do stereo receivers setup the same way as a 5.1 or would he have to set the xover on the sub itself?
and to php you will need a SPL meter and some test tones.
mark62 is offline
post #69 of 86 Old 01-18-2014, 10:03 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
And what is a SPL meter and some test zones and where to get them from?
php111 is offline
post #70 of 86 Old 01-18-2014, 10:04 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
He will set the Xover on the sub - starting with 80 hz.
Who AM I
zieglj01 is offline
post #71 of 86 Old 01-18-2014, 10:10 PM
mark62's Avatar
Liked: 88
if he got the Focals wouldnt he start somewhere around 60hz? since they are rated 3dB down at 55 hz?
i really think the OP is going to have a hard time understanding all this. but has to start somewhere i guess.
mark62 is offline
post #72 of 86 Old 01-18-2014, 10:13 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would start with 80 hz - he will get plenty of punch and dynamics.
Who AM I
zieglj01 is offline
post #73 of 86 Old 01-18-2014, 10:13 PM
mark62's Avatar
Liked: 88
meter http://www.amazon.com/Velleman-AVM2050-ANALOGUE-SOUND-LEVEL/dp/B000LR169Q/ref=sr_1_2?s=electronics&ie=UTF8&qid=1390108244&sr=1-2&keywords=spl+meter
your gonna need bass warble tones and a 1khz reference tone or white or pink noise. dont know where to get them, not looking.
been a long time since i set a sub up this way.
basically you need to blend the sub with the speakers.
mark62 is offline
post #74 of 86 Old 01-18-2014, 10:17 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
There needs to be a simple beginning to start with - use the sub volume control to start with,
to balance the sound with the receiver.
Who AM I
zieglj01 is offline
post #75 of 86 Old 01-18-2014, 10:27 PM
mark62's Avatar
Liked: 88
yeah on the back of the sub there will be a volume control and a crossover setting control. set the crossover around 80hz, maybe 70hz then play music and turn the volume up on the sub until it blends without over powering the speakers.
mark62 is offline
post #76 of 86 Old 01-18-2014, 10:37 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
And that's it? So just plugged the sub into Pre out on receiver and than set the crossover on sub to 80hz and turn up the volume on sub until blends in and than it would be done?
php111 is offline
post #77 of 86 Old 01-18-2014, 10:46 PM
mark62's Avatar
Liked: 88
thats the crude way to do it, but yeah....
and need one of these...
http://www.monoprice.com/Product?c_id=102&cp_id=10236&cs_id=1023603&p_id=6305&seq=1&format=2
mark62 is offline
post #78 of 86 Old 01-18-2014, 11:49 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
As for hooking your subwoofer up to your receiver
Read the manual COVER to COVER!
They explain it in the manual. And you NEED to read the manual cover to cover as you are struggling to listen to people here when they are telling you what you need to do.
So your budget is $400? (That is the price of Polk RTi A3's)
crazyrob425 is offline
post #79 of 86 Old 01-19-2014, 07:16 AM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
It's true "most" manuals do tell you how to setup a subwoofer, but "most" is not the same thing as saying "all" manuals tell you how. The manual for my receiver tells you to connect it to preout and does not tell you how to set it up.
http://onkyo-audio.pl/uploads/files/ins/integra/dtm-5.9.pdf
That's the manual.
php111 is offline
post #80 of 86 Old 01-19-2014, 10:43 AM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Mark,
Without setting up a sub the crude way, how to step it up the right way by following exactly step by step instructions from start to finish?
php111 is offline
post #81 of 86 Old 01-19-2014, 07:29 PM
Quoted: 443 Post(s)
Liked: 337
That's the manual.
Go to pg13 the section is called. "Connecting a Powered Subwoofer" rolleyes.gif
post #82 of 86 Old 01-19-2014, 07:39 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
That's right and that is all. Only connecting but not how to set it up.
php111 is offline
post #83 of 86 Old 01-19-2014, 07:42 PM
Quoted: 443 Post(s)
Liked: 337
Fine
Phase= 0
Crossover knob to 80-100 hz
Gain knob until it blends smoothly with the bookshelves and doesn't overpower. Really no more than 50% to 60% tops should be needed
post #84 of 86 Old 01-20-2014, 06:13 AM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Thank you!
php111 is offline
post #85 of 86 Old 01-28-2014, 10:37 AM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
i see the sub output, but i dont see how you set it up in the receiver.
Response from Integra is below. It's a copy/paste from my email. I just received it like a matter of minutes ago.
Good Afternoon,
The sub is connected in the subwoofer pre-out connection and that is all that is needed to be done. There aren't any adjustments that need to be done to get the sub to work on this receiver. Just make sure the volume on the sub itself is up to a decent level.
php111 is offline
post #86 of 86 Old 01-28-2014, 01:02 PM
mark62's Avatar
Liked: 88
Good Afternoon,
So it looks like the receiver just sends a full range signal to the sub... so just follow the post above to set up the sub...
mark62 is offline
Reply Speakers
Polk Audio Rti A3 Bookshelf Speakers , Klipsch Rb 61 Ii Reference Series Bookshelf Loudspeakers Black Pair , Focal 706v Chorus Loudspeakers , Jbl L830 3 Way 6 Inch Bookshelf Loudspeaker Pair Black
