Surround sound with tv in corner? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 01-20-2014, 12:34 PM - Thread Starter
adamw5963's Avatar
Ok I'm looking to put a system in my bedroom. I assumed I would just put all the speakers in the upper corners of the room except the center and sub. However, after further research I discovered I should have them around ear height. The problem is I have my 60" tv in the corner. I have it in the corner bc it's a plasma and it gets reflections from the windows on the right. My room is 12x12 with an 8ft ceiling. If I put one of the speakers above the tv it probably wouldn't sound right. Am I right?
Sorry about the small pic.
adamw5963 is offline
post #2 of 19 Old 01-20-2014, 06:41 PM
Randall.White's Avatar
Quoted: 353 Post(s)
Liked: 89
Why not just buy some black out curtains? Probably 20-30 bucks for some cheap ones at Wal-Mart.
http://www.walmart.com/ip/Eclipse-Samara-Blackout-Energy-Efficient-Curtain/15734048
Also available on Amazon for a little bit more.
To answer your question, yes it won't sound right. What kind of speakers/receiver do you have?
Randall.White is offline
post #3 of 19 Old 01-20-2014, 07:00 PM - Thread Starter
adamw5963's Avatar
Haven't bought the equipment yet. I was looking at some of the refurb receivers on accessories4less that were under $200. Not sure about speakers yet. I was looking at the $84 monoprice set but I'm not sure how good they are. I've never had real surround sound so I'm guessing most any of them will sound good to me.
post #4 of 19 Old 01-20-2014, 07:03 PM
Quoted: 353 Post(s)
Liked: 89
What's your budget for everything? receiver/speakers/sub.
post #5 of 19 Old 01-20-2014, 07:09 PM - Thread Starter
adamw5963's Avatar
Under $300 for everything. I know it's tight but it's just to get me by for now.
post #6 of 19 Old 01-20-2014, 07:40 PM
Quoted: 353 Post(s)
Liked: 89
My old room mate isn't really into HT like I am and he bought this:
http://www.amazon.com/Onkyo-HT-S3500-5-1-Channel-Theater-Receiver/dp/B0077V88V8/ref=sr_sp-btf_title_1_6?ie=UTF8&qid=1390271610&sr=8-6&keywords=5.1+speakers
He likes it and it "does the job".
post #7 of 19 Old 01-20-2014, 07:47 PM - Thread Starter
adamw5963's Avatar
post #9 of 19 Old 01-20-2014, 07:56 PM - Thread Starter
adamw5963's Avatar
Those look good Mark. Of course the first option looks best but a little over budget. Would there be much difference with this:
http://www.accessories4less.com/make-a-store/item/DENAVR1513/DENON-AVR-1513-5.1ch-Home-Theater-Receiver-3D-ready/1.html             Denon AVR 1513
and this..
http://www.accessories4less.com/make-a-store/item/YAMNSAP2600BL/YAMAHA-NS-AP2600-Satellite-Speaker-Package/1.html#!more          Yamaha APS2600
and this...
http://www.amazon.com/Polk-Audio-10-Inch-Monitor-Subwoofer/dp/B0002KVQBA/ref=pd_sim_e_6        Polk PSW10 sub
Are those Yamaha satellites as good as those home theater packages?
post #10 of 19 Old 01-20-2014, 08:00 PM
mark62's Avatar
Liked: 88
mark62 is offline
post #11 of 19 Old 01-20-2014, 08:02 PM
Quoted: 353 Post(s)
Liked: 89
Look very similar. Might just be a older model?
Might be cheaper going through Amazon. Accessories4less charges quite a bit for shipping IMO plus I'm a Prime member, so I use that as much as possible.
adamw5963 likes this.
post #12 of 19 Old 01-20-2014, 08:06 PM
mark62's Avatar
Liked: 88
what looks very similar?
mark62 is offline
post #13 of 19 Old 01-20-2014, 08:10 PM - Thread Starter
adamw5963's Avatar
I think he was talking about the Onkyo AVX 290 being very similar to the Onkyo S3500
post #14 of 19 Old 01-20-2014, 08:16 PM - Thread Starter
adamw5963's Avatar
Looks like I've got some thinking to do. Those Yamahas I mentioned, are they any good? I'm more of a TV guy so I know next to nothing about audio
post #15 of 19 Old 01-20-2014, 08:19 PM
mark62's Avatar
Liked: 88
notice that 1513ba is $300 on amazon so double the price.
shipping is not that bad depending on where you live. for me it was $40
i would not recommend the yamaha system
mark62 is offline
post #16 of 19 Old 01-20-2014, 08:25 PM
mark62's Avatar
Liked: 88
mark62 is offline
post #17 of 19 Old 01-20-2014, 08:28 PM - Thread Starter
adamw5963's Avatar
Sorry that was the wrong yamaha system. I meant the Yamaha NS-SP1800B
http://www.amazon.com/Yamaha-NS-SP1800BL-5-1-Channel-Theater-Speaker/dp/B001AVRD62/ref=cm_cr_pr_sims_t
post #18 of 19 Old 01-20-2014, 08:31 PM
mark62's Avatar
Liked: 88
i wouldnt recommend that either, but give it a go, if you dont like it ship it back.
mark62 is offline
post #19 of 19 Old 01-20-2014, 10:09 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Unless you move the TV out of the corner get a sound bar and be done with it. Surround sound is currently not feasible with your current setup
crazyrob425 is offline
Reply Speakers
