Suggestions for Enclosed In-Wall Speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-21-2014, 08:22 PM - Thread Starter
coachkapps's Avatar
Here's where I'm at now:
34 x 12 room (main HT is 14 x 12 in the middle - 10 feet open on each side, walls all four sides)
Onto to the pressing issue I'm having. I'm leaning toward in-wall speakers but would want to buy enclosed speakers or install enclosures. Which is better? More bang for the buck?
What about enclosed speakers? All the searching is racking my brain. What are a few great choices for $300 each LCR and surrounds? Again, best quality for the dough? Budget is $1500.
Loving the idea of either 1 or 2 SVS PB-1000s or 1 SVS PB-2000 for a sub choice. What's better? One 2000 or two 1000s?
coachkapps is offline
post #2 of 4 Old 01-21-2014, 08:54 PM
mark62's Avatar
Liked: 88
Two 1000's in my opinion.
that is a really big room for in wall speakers.
http://www.accessories4less.com/index.php?page=search&search_query=bosvsi&x=0&y=0
dont know what you mean by enclosed speakers.
mark62 is offline
post #3 of 4 Old 01-22-2014, 05:33 AM - Thread Starter
coachkapps's Avatar
I guess I'm looking/wondering if in-wall speakers should be set in enclosures or be the enclosed back (steel) style speaker. I don't know how the open cavity affects the quality.
post #4 of 4 Old 01-22-2014, 08:28 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I would encourage you to put shelves on the walls and use speakers with properly-designed enclosures.
NO in-wall speaker the I have ever seen has a properly-designed enclosure, and the performance is badly compromised.
That's not what you need for a room that large.
Wharfedale Diamond 10.1 speakers are $350 per pair. I suggest that you get four of those, and the 10CC center speaker ($249).
commsysman is offline
Reply Speakers
Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Wharfedale Diamond 10 1 Blackwood Pr Bookshelf Speakers
