Front Right Speaker Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-22-2014, 01:34 PM - Thread Starter
theprez9's Avatar
Good afternoon,
I have a problem with my front right speaker... It will play fine when I turn the receiver on but will cut off within a minute or so.
I have a 7.1 in-wall speaker setup with the following pieces:
TV:
Panasonic 65" plasma (TC-P65VT50)
Receiver:
Yamaha RX-V573
Speakers:
Front L/R - Micca M-8S
Front C - Micca M-CS
Surround L/R - Micca M-8S
Back L/R (ceiling) - Micca M-8C
So far, I've tried a couple tests... neither fixing the issue.
* 1st tried to run a new separate cable from receiver to speaker (not behind the wall)
* 2nd used a brand new Front Right speaker connecting to both the in-wall cable and cable run not behind the wall
Not sure what (or where) the issue is. It will start just fine once the receiver is turned off and on... Just doesn't last much more then a minute.
Appreciate any ideas or additional tests I could try.
theprez9 is offline
post #2 of 5 Old 01-22-2014, 01:38 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
Try reversing speakers. Connect R to the L receiver output and L to the R receiver output. This will tell whether the problem is in the speaker or the receiver because the problem should follow either the speaker or the receiver amp.
FMW is offline
post #3 of 5 Old 01-22-2014, 02:00 PM - Thread Starter
theprez9's Avatar
Thanks. Will test in couple mins and report back.
theprez9 is offline
post #4 of 5 Old 01-22-2014, 02:24 PM - Thread Starter
theprez9's Avatar
It took longer then before but the left eventually cut off. So it appears an issue with the front right receiver output.
I have screw lock banana plugs on the 14 gauge wire... But when connecting a new line from receiver to speaker (not behind the wall) I used a new pair of plugs.
Can a receiver just crap out like that? Or could there be something I can fix with the connection? Would it be worth trying connecting wire to receiver without the banana plug?
I've had the receiver less then a year and the new room (unfortunately) hasn't gotten a lot of use with a 3 year and 6 month old in the house.
Thanks again
theprez9 is offline
post #5 of 5 Old 01-22-2014, 04:21 PM - Thread Starter
theprez9's Avatar
Took off the banana plugs and connected wire directly into front right connections... Thought it fixed the prob because it worked for a while... but then stopped.
Was hoping the banana plug connection was just dropping.
Not sure what the next step is.
theprez9 is offline
Reply Speakers
Panasonic Viera Tc P65vt50 65 Inch Plasma Tv , Yamaha Rx V573 Receiver , Micca M Cs Dual 5 25 Inch 2 Way Mtm In Wall Speakers With Pivoting 1 Silk Dome Tweeter Each White
