Need suggestion for good 5.1 'cube' speakers for 15x20 room - AVS Forum | Home Theater Discussions And Reviews
Old 01-22-2014, 05:17 PM - Thread Starter
bugeyes's Avatar
There are so many choices and I am confused, I like someone to point me to the right direction of excellent small speakers for watching movie most of the time in a 15x20 room, as small as possible without sacrifice sound quality and a small sub to go with it, budget can be up to 1k for everything more less, thanks in advance....
bugeyes is offline
Old 01-22-2014, 05:24 PM
zieglj01's Avatar
Quoted: 942 Post(s)
Liked: 846
I would look to go above the cube speaker - look at the
Focal Sib
http://www.crutchfield.com/p_091SBCUB3B/Focal-Sib-Cub3-Black.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 01-22-2014, 06:23 PM
mark62's Avatar
Liked: 88
Focal Sib
+1
mark62 is offline
Old 01-22-2014, 06:32 PM - Thread Starter
bugeyes's Avatar
how is this compare with Cambridge MInx 21?
bugeyes is offline
Old 01-22-2014, 06:41 PM
zieglj01's Avatar
Quoted: 942 Post(s)
Liked: 846
You get a bigger woofer - and the Sib speakers will play down lower in the bass -
to get some punch from the satellites - and to help better blend with a sub. >>
Plus, the Sib sats will have more radiation range, for sound dispersion and can
handle some power.
The Cambridge sats are -3dB at 168 Hz, and -6dB point at 143 Hz.
Now, take note of this price
http://www.accessories4less.com/make-a-store/item/FOCALSIB51BLK/FOCAL-Sib-Cub3-Home-Theater-Speaker-System-Black/1.html
Who AM I
zieglj01 is offline
Old 01-22-2014, 09:07 PM - Thread Starter
bugeyes's Avatar
So, what about the SVS PB1000 to pair up with the Sib? or the Cub3 is actually better?
bugeyes is offline
Old 01-22-2014, 09:29 PM
zieglj01's Avatar
Quoted: 942 Post(s)
Liked: 846
SVS will be the better sub - the Sib is $199 a pair at AC4L
Who AM I
zieglj01 is offline
Old 01-23-2014, 11:56 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+1
sdg4vfx is offline
