Help with amp and speaker setup. - AVS Forum
post #1 of 1 Old 01-24-2014, 10:14 AM - Thread Starter
cent's Avatar
I have got a new amp called ProSound 1600 from Maplins and 2 400w loudspeakers also from Maplins. I connect them to the amp with speakon cables.
I also have a half inch to 3.5mm cable connected from the amp to my PC.
When I have both speakers plugged in, one plays normal and the other one is very quiet, but I can't find the issue.
I've tried one speaker at a time with different cables and it worked. Then I tried both sides of the amp and that work, when there was only one plugged in. So, there's nothing wrong with the speakers, wires or the amp? :confused:
There's 3 speakon outputs on the amp, I tried left and right at the same time and it didn't work. Am I missing something?
I'm not very good with speakers, so go easy :)
also noticed, the left dial on the front of the amp works, but the right one doesn't. When one speaker is plugged in, it uses the left dial and when both are in the left one will change the volume on one speaker but the right dial wont change the volume of the other. Have I got a broken dial? It was delivered by Yodel and the box was pretty battered.
cent is offline
Reply Speakers
User Tag List
