Boston Acoustics E60 and Ascent CBM-170 SE, which can be listened to quietly? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 162 Old 02-23-2014, 12:15 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Originally Posted by stgatev View Post
Actually, yes. Can you offer any tips on configuration with the E60 speakers? Currently, I have the speakers configured the following way on my receiver:
Audio
    Subwoofer Level
        Subwoofer: On
        Subwoofer Level: -10.5db
    Audyssey
        MultiEQ XT: Audyssey
        Dynamic EQ: On
        Reference Level Offset: 0db
        Dynamic Volume: Off
Speakers
    Speaker Config
        Front: Small
        Center: None
        Subwoofer: Yes
        Surround: None
    Bass
        Subwoofer Mode: LFE
        LPF for LFE: 120 Hz
    Crossovers
        Crossover: Individual
        Front: 40Hz
On the back of the sub, I have all knobs in middle position; Phase is at 0 degrees, and the Variable Notch Filter is OFF.
I used the Monster subwoofer cable that came free with the sub, connected to the Left input (I did not connect the Right).
The receiver configuration is result of the Audyssey calibration with the exception of me turning off the Dynamic Volume.
If you like and want Audyssey, then you may not like my tip - because I fired Audyssey, MCACC, YPAO and the like.
If you like Audyssey working for you - then keep him > however, I do not like the -10.5db sub level, and the front crossover should be 80 hz.
This is my manual set-up
Front crossover > 80 hz
LPF for LFE > 120 hz
Sub crossover knob set > 120 hz
phase > 0
notch filter > Off
Receiver subwoofer level > +1
Sub volume knob > 11 o'clock
It will vary depending on your room, between 9 and 12 o'clock average > if I need to adjust the
level (+/-), then I control it with the receiver sub level > however, I do not go higher than +2 in
the receiver, after that I control it with the sub. Note: once you set it up - you should rarely need
to adjust the volume, if it is blending with the speakers
Your option and call - maybe Audyssey will find a job at your house.smile.gif
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #92 of 162 Old 02-23-2014, 03:04 PM - Thread Starter
stgatev's Avatar
Thanks! I will give it a try.
stgatev is offline
post #93 of 162 Old 02-23-2014, 03:11 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Personally I use Audyssey only for HT (manually set the crossover to 80hz) while I use a manual EQ for listening to stereo music.
Some people like Audyssey for everything.
Some people only use Audyssey to get distance, levels and phase settings.
Also, after you calibrate using Audyssey it has an "Audyssey Flat" option - I prefer that over the standard Audyssey selection.
sdg4vfx is offline
post #94 of 162 Old 02-26-2014, 08:14 AM
brandtlj's Avatar
I'm also trying to compare the E60 with the CBM-170se...I've owned the VS-260 which was a fantastic speaker I didn't want to part with, but I sold them after getting an offer I couldn't refuse...
So, how does the E60 compare with the VS260 in terms of SQ and presentation....and I guess I'll have to try out the 170's as well.
I also need a fairly efficient speaker...I was able to drive the VS-260 just enough with a nice T-amp crossed at 70hz...the 170se's should be even easier - not sure about the E60's.
brandtlj is offline
post #95 of 162 Old 02-26-2014, 09:00 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The E60 is 87.5 db sensitive - not really hard to drive - they are close to the VS260 in the mids
and highs, with real good detail, definition and depth - the VS260 is a little better and smoother.
The 260 will go deeper and has more bass energy - however, the E60 can be crossed at 80 hz,
and will play below 55 hz.
There are only 2 left at Amazon.
Who AM I
zieglj01 is offline
post #96 of 162 Old 02-26-2014, 09:41 AM
brandtlj's Avatar
Psychologically, it's hard to go down a level in speakers, i.e. from the vs260's to either the e60's or cbm-170se's. I had the 260's in a near-field setup, and I wonder if the e60's may even be better suited for that purpose...but the tweeter on the VS260 was sublime...i'd hate to lose that super detailed sound...but it sound like the E60's are close...what bugs me is the statement "the VS260 is a little better and smoother"...which to someone like me, can keep you up at night.
I still am wondering where the Ascend 170's fall into the mix...i have yet to read about someone who has listened to both speakers....we shall see
brandtlj is offline
post #97 of 162 Old 02-26-2014, 09:49 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Do not want you to stay up all night - so, read this review
http://www.audioreview.com/cat/speakers/bookshelf-speakers/boston-acoustics/e60/prd_397855_4290crx.aspx
The E60 measurements from 200 hz to 10 khz, is one of the best period (that would mean smooth).
The speakers use to list/sell for $1200 a pair - I prefer them over the Snell K7 ($1250 pair)
Who AM I
zieglj01 is offline
post #98 of 162 Old 02-26-2014, 12:42 PM
brandtlj's Avatar
So, I pulled the trigger on the E60's...a guy on ebay was selling a used pair. Interestingly enough, the specs on the Boston website show a 90db sensitivity for these speakers, rather that 87.5. I'm excited to give 'em a go against the VS260's. Stay tuned
kaiforce likes this.
brandtlj is offline
post #99 of 162 Old 02-26-2014, 02:41 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
They were measured by HT Labs, to be 87.5 db - which is good for a speaker
that size. Have fun
Who AM I
zieglj01 is offline
post #100 of 162 Old 02-28-2014, 06:28 PM
brandtlj's Avatar
I received the E60's today and listened to them for about an hour, setup exactly where the VS-260's were. These are great speakers and a real bargain for the price I got them. The E60's will definitely tide me over until I can find another pair of VS-260's.
Comparisons between the two:
I should start by saying the VS-260's have been the best speakers I've ever listened to...that said, the E60's are just a hair behind. The VS-260 had a slightly larger, more enveloping soundstage and a bit more high end clarity - but honestly, I think I'm nitpicking. It's only really noticeable on a few songs recorded at very high bit rates.
brandtlj is offline
post #101 of 162 Old 02-28-2014, 06:53 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
They are close - The E60 is a former flagship model - you made a good choice - continue to enjoy
Who AM I
zieglj01 is offline
post #102 of 162 Old 03-02-2014, 12:02 PM
brandtlj's Avatar
Zieg, if you ever find a speaker you like heads and shoulders above the VS-260's, please let me know b/c I feel your opinions are spot on!
brandtlj is offline
post #103 of 162 Old 03-02-2014, 12:27 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I am still looking - something may show or pop-up.
Who AM I
zieglj01 is offline
post #104 of 162 Old 03-02-2014, 03:33 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
Are the Philharmonitors on your candidate list?
That's a speaker I'd like to hear.
alphaiii is offline
post #105 of 162 Old 03-02-2014, 03:49 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
There are 3 on my list, and I will only choose one
Philharmonitors
Rhyme Acoustics Nuscale
MB Quart Vera VS05
http://shop.mbquart.com/p/vs05be-pair-elsberry-finish?pp=24
Who AM I
zieglj01 is offline
post #106 of 162 Old 03-02-2014, 04:10 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
MB Quart Vera VS05
Very interesting price given their original MSRP.
For the heck of it, I threw them in the shopping card. MB Quart wants $75 shipping and handling. Are they shipping them from Germany? It would be an expensive demo if round trip shipping costs were necessary to return them.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #107 of 162 Old 03-02-2014, 04:21 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
They came out around 2004 - MB Quart has poor USA marketing for home audio
The speakers are heavy, around 26 lbs each - if I buy them, I can live with the shipping.
alphaiii is the one who may cringe - because he likes to play ping pong with speakers.
I think deep down, he wants to be a pro-reviewer - it is just that it costs him money.biggrin.gifsmile.gif
They can only be shipped in the USA
Who AM I
zieglj01 is offline
post #108 of 162 Old 03-02-2014, 05:05 PM
brandtlj's Avatar
Philharmonitors
MB Quart Vera VS05
I vote for the Philharmonitors...I've read some prefer these to the Sierra-1's. There's a pair of B-stock for $699 shipped ;-)
http://philharmonicaudio.com/folio-me/html/Phil%20Pages/philharmonitor.html
Also, I think an AVS member has already ordered both the Sierra-2's and the Philharmonitors, so I'll also be anxiously awaiting his comparison.
brandtlj is offline
post #109 of 162 Old 03-02-2014, 05:30 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
That comparison/test will be subjective - plus his room and set-up is not ideal - however, his take will be interesting.
I have not decided - however, Sound & Vision and also SoundStage, gave the Vera speakers a good review - and they
measured nicely, even the center channel.
http://www.soundandvision.com/content/mb-quart-vera-vs-1f-speaker-system-ht-labs-measures
Who AM I
zieglj01 is offline
post #110 of 162 Old 03-03-2014, 04:58 PM
brandtlj's Avatar
Cel -
Would like to know your thoughts on how the Indeed T-amps would do powering these MB Quarts...the speakers are 6ohm...I can't find the sensitivity
Here is a german review of the speakers...I'm getting fairly interested, but I don't know if I my Indeed amp can handle this speaker
http://translate.google.com/translate?hl=en&sl=de&u=http://www.hifi-forum.de/viewthread-100-1610.html&prev=/search%3Fq%3DVS05B%2Bmbquart%26safe%3Doff%26espv%3D210%26es_sm%3D93
brandtlj is offline
post #111 of 162 Old 03-03-2014, 05:26 PM
cel4145's Avatar
Liked: 2991
The Indeed t-amps are rated rated to 4 ohms, so they should be fine with 6 ohms. If they are mainly for desktop use, the Indeed should work fine to drive it loud volumes. Even people who have owned the Pioneer Andrew Jones bookshelves have found TA2020 t-amps to work well for that. If the goal is to say provide moderate background music in a bedroom, I would imagine that it would work well.
But yeah. Best to try to find out the sensitivity, just in case it's something really low, like those SVS bookshelves that were 83db.
cel4145 is offline
post #112 of 162 Old 03-03-2014, 05:40 PM
brandtlj's Avatar
Ziegl found this on the Vera VS 1B, which is the MTM version of the VS 05...rated @ 87 from 500hz+ I would imagine the VS05's sensitivity is either the same or higher...
brandtlj is offline
post #113 of 162 Old 03-03-2014, 06:09 PM
kaiforce's Avatar
Quoted: 106 Post(s)
Liked: 127
I found this on the Vera VS 1B, which is the MTM version of the VS 05...rated @ 87 from 500hz+ I would imagine the VS05's sensitivity is either the same or higher...
kaiforce is offline
post #114 of 162 Old 03-03-2014, 06:10 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
For me, I would want something like the Sherbourn/Emotiva amp - MB Quart
recommends at least a 70 watt amp, for some reason >> however, I see no
problem using a lesser amp for nearfield.
http://www.accessories4less.com/make-a-store/item/SHRBNPA250/SHERBOURN-PA-2-50-Stereo-Flex-Amplifier/1.html
Who AM I
zieglj01 is offline
post #115 of 162 Old 03-03-2014, 06:12 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Who AM I
zieglj01 is offline
post #116 of 162 Old 03-03-2014, 07:04 PM
brandtlj's Avatar
**Corrected
I am very close to buying these speakers...I'm just concerned that my current Indeed amp won't give them the juice they need. I wasn't looking to spend much over $500 to begin with...and having to upgrade my amp as well is a little worrisome.
Ziegl, any chance you are going to hop on these soon...if they get a good audition, I think I will follow suit!
brandtlj is offline
post #117 of 162 Old 03-03-2014, 07:29 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I am getting close - they should have the same sensitivity as the Boston VS260
Who AM I
zieglj01 is offline
post #118 of 162 Old 03-04-2014, 12:46 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
They have been ordered
Now a couple pair of my speakers need to go.
Who AM I
zieglj01 is offline
post #119 of 162 Old 03-04-2014, 12:58 PM
brandtlj's Avatar
Woohoo!!!
brandtlj is offline
post #120 of 162 Old 03-04-2014, 01:17 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Woohoo!!!
PM me
Who AM I
zieglj01 is offline
Reply Speakers
Ascend Acoustics Cbm 170 Se , Boston Acoustics E60 High Performance Bookshelf Speaker , Yamaha Rx A700 7 1 Channel Audio Video Receiver Black
