Need help with Crossover Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 01-30-2014, 04:20 PM - Thread Starter
Micah123's Avatar
Quoted: 80 Post(s)
Have L&R Rti5's and a Csi6 for center. Rti3's for L&R rears in 5.1 system. Need to know what crossover settings I should use. Have 15" Hsu sub. Currently have 5 speakers the same at 60hz. Thanks for the input. Seems like the rears are very hard to hear even when I set their volume way up.
Micah123 is offline
post #2 of 16 Old 01-30-2014, 04:42 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Well, surrounds aren't rears, they're surrounds (to the sides is the general intention in a 5 ch system) and there's not a lot of content in the surrounds generally as compared to the mains. What avr do you have? Are you using the auto speaker setup routine/room correction software in it? 60 isn't a bad starting point, although you might try the THX suggested 80 or something in between as well....
lovinthehd is offline
post #3 of 16 Old 01-30-2014, 06:30 PM - Thread Starter
Micah123's Avatar
Quoted: 80 Post(s)
AVR is a HK3600. Originally used HK system to set up but since have been doing it manually. Room is rectangular with rear wall a long distance from tv.........30 ft. Will see about placing speakers to the sides vs behind. Just looking for a starting point to know I am somewhere close to where the crossover settings should be set. Really do not even know what the function of setting the crossover freqs are. Thanks for the suggestions.
Micah123 is offline
post #4 of 16 Old 01-30-2014, 06:43 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
What input do you have the RTi3's hooked up? Surrounds or SB(Surround Back)
Have you used the "EzSet/EQ automates room-equalization and system-calibration for simple system setup and optimal audio quality in any listening room."
Crossover from 60-80hz should be find though I don't think the cross over is the problem for lack of volume with the surrounds
crazyrob425 is offline
post #5 of 16 Old 01-30-2014, 07:08 PM
Jack D Ripper's Avatar
Liked: 272
Use the automatic setup for levels and delays (AKA distance).
The function of the crossover is to separate the deep bass from the main channels and send it to the subwoofer.  The reason for that is that the subwoofer can generally handle deeper bass than the main speakers can.  If you send the deep bass to the main channels, whatever they cannot reproduce, you do not hear, plus they will distort more trying to reproduce frequencies that they are ill suited to deal with.
I would probably go with an 80 Hz crossover.  You want your speakers to be able to go lower (at their -3dB point) than your crossover point, and although they are all rated for lower than 60 Hz, it is a little closer than I would recommend for 60 Hz.  Try 80 Hz and see how you like it.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
post #6 of 16 Old 01-30-2014, 07:12 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1300
I wouldn't go lower that 80hz. And the "rear" or back surround speakers seem to be much farther from the listening position than the front so you might need to up the trim on them.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #7 of 16 Old 01-30-2014, 09:13 PM - Thread Starter
Micah123's Avatar
Quoted: 80 Post(s)
so do I set all 5 speakers to 80?
Micah123 is offline
post #8 of 16 Old 01-30-2014, 09:17 PM
Kini62's Avatar
Liked: 1300
I would. Maybe even 100 for the surrounds.
Def Tech SC8000
Kini62 is offline
post #9 of 16 Old 01-30-2014, 09:49 PM
Quoted: 443 Post(s)
Liked: 337
Polk RTi A3's are -3db at 50hz. They will be fine with a 80hz crossover
post #10 of 16 Old 01-30-2014, 09:50 PM
mark62's Avatar
Liked: 88
another confirmation of 80hz...
mark62 is offline
post #11 of 16 Old 01-30-2014, 10:02 PM
lovinthehd's Avatar
Liked: 4775
Not familiar with that avr or its setup/room correction software....is it ezset? I've heard of that but not familiar with it....
Where's your listening position in this room and what are all three dims of the room?
You don't specify a sub, what is it? You can't crossover anything unless you have the .1, a sub....
post #12 of 16 Old 01-30-2014, 10:53 PM
mark62's Avatar
Liked: 88
He states system is 5.1.
Room size or LP really has nothing to do with the xover setting.
mark62 is offline
post #13 of 16 Old 01-30-2014, 11:33 PM
lovinthehd's Avatar
Liked: 4775
I'm more curious about his setup and how he got there is all. He states .1 but doesn't mention a sub....
post #14 of 16 Old 01-31-2014, 04:33 AM - Thread Starter
Micah123's Avatar
Quoted: 80 Post(s)
sub is a 15 inch Hsu
Micah123 is offline
post #15 of 16 Old 01-31-2014, 04:46 AM
lovinthehd's Avatar
Liked: 4775
This was what got me curious about if you had a sub or not.....what did you mean by this?
post #16 of 16 Old 01-31-2014, 05:39 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Refer to this website for proper speaker placement.
I would also recommend using the auto-EQ on your receiver, it does more than just set a crossover. Using the mic it will determine the levels to set each speaker so everything is matched. The only way to do this yourself is with an SPL meter.
Also just out of curiosity, I assume you have the HSU VTF-15H, what do you have the knobs on the back set to?
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Reply Speakers
