setting sub woofer hz ? - AVS Forum
post #1 of 10 Old 01-30-2014, 03:35 PM - Thread Starter
rebs's Avatar
My sub woofer say 90 to 150 Hz, what would I set the receiver to ?
rebs is offline
post #2 of 10 Old 01-30-2014, 03:49 PM
lovinthehd's Avatar
Quoted: 77 Post(s)
Liked: 723
If your sub doesn't automatically cut out the crossover/lpf with a dedicated lfe connection, just turn it to max and let your avr do the bass management. 80 hz crossover is a good starting point generally, but if you're talking about the LPF of the LFE channel setting in your avr (if you have such) use 120. What specific gear do you have?
lovinthehd is online now
post #3 of 10 Old 01-30-2014, 04:48 PM - Thread Starter
rebs's Avatar
The receiver is a yamaha rx-v375 and the sub woofer is a JBL The sub woofer is plugged into the sub woofer pre out
rebs is offline
post #4 of 10 Old 01-30-2014, 06:14 PM
Kini62's Avatar
Quoted: 27 Post(s)
Liked: 295
Set it to as high as it will go.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #5 of 10 Old 01-30-2014, 06:30 PM - Thread Starter
rebs's Avatar
it will go to 200 Hz
rebs is offline
post #6 of 10 Old 01-30-2014, 07:13 PM
Bill Fitzmaurice's Avatar
Liked: 1173
That depends on how low your mains will comfortably go. Read your AVR manual.
Bill Fitzmaurice is online now
post #7 of 10 Old 01-30-2014, 07:15 PM
sivadselim's Avatar
Quoted: 33 Post(s)
Liked: 62
He doesn't mean your receiver's crossover setting. He means your sub's low-pass setting.
Your post's title is misleading.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #8 of 10 Old 01-30-2014, 07:19 PM - Thread Starter
rebs's Avatar
then what should the avr's setting be, how many Hz's ?
rebs is offline
post #9 of 10 Old 01-30-2014, 07:27 PM
crazyrob425's Avatar
Quoted: 58 Post(s)
Liked: 145
What is your full speaker setup? Please include model numbers or your speakers so we can better help you.
crazyrob425 is offline
post #10 of 10 Old 01-30-2014, 07:33 PM
sivadselim's Avatar
Quoted: 33 Post(s)
Liked: 62
This depends upon (among several other things) your speakers' capability. Without any knowledge of this, no one here could possibly answer your question.
And even if we did know your speakers and their specs, we still can't really answer this question for you.
Reply Speakers
User Tag List
