center channel NEEDED with ceiling speakers?..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-31-2014, 08:32 PM - Thread Starter
miker2014's Avatar
i have a general speaker question, don't need any specific speaker manufacturer recommendations
assuming a ceiling speaker setup is used in a medium sized room (9 ft ceilings) with 4 mid priced ceiling speakers and a subwoofer, does this setup NEED a center channel for better clarity of dialogue, assuming the setup will be used mainly for tv/movie viewing?
does anyone have any experience with a ceiling setup and the before/after of adding a centre channel?
thanks
miker2014 is offline
post #2 of 10 Old 01-31-2014, 10:08 PM
macddmac's Avatar
Quoted: 16 Post(s)
I have a similar setup and would say absolutely a center makes the best of a suboptimal situation as long as its directly under or on top of the TV.
Otherwise the ceiling speakers give a hollow sound that doesn't sync with the display.
Cheers, Mac
macddmac is offline
post #3 of 10 Old 01-31-2014, 10:23 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
thanks
Think of in-ceiling speakers as "spotlights" that shine a cone of light down from the ceiling. If you're sitting underneath the light, you get a nice bright cone of light. As you move away from the cone, the brightness decreases quickly. Speakers work the same way, especially at higher frequencies, (treble.) As you move out from under the cone of sound, the level, and more importantly, the clarity drops off quickly. If your speakers are in the front of the room, and your seating is across the room, you'll be seated well outside the optimal "cone" of dispersion for in-ceiling speakers. This is true whether you're using 3 front speakers, (L, C & R), or just two speakers, (L & R.)
Bottom line, the compromises inherent in an in-ceiling speaker setup are so significant that the additional compromise of not having a CC... pales to insignificance.
IMO. YMMV. Etc.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #4 of 10 Old 01-31-2014, 10:45 PM - Thread Starter
miker2014's Avatar
thx... this is exactly the kind of feedback i was looking for
post #5 of 10 Old 01-31-2014, 10:45 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would rather semi-suffer with a soundbar
Watching a movie with voices and sounds coming from above, annoys/distracts me.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #6 of 10 Old 01-31-2014, 10:48 PM - Thread Starter
miker2014's Avatar
Cheers, Mac
thx for the post.... this is what i was afraid of and i would hate to get the system done and feel it was out of sync
post #7 of 10 Old 01-31-2014, 10:49 PM - Thread Starter
miker2014's Avatar
IMO. YMMV. Etc.
Craig
well said.... thx
post #8 of 10 Old 01-31-2014, 10:53 PM - Thread Starter
miker2014's Avatar
thx... that is basically what i have decided too, i know deep down inside that the ceiling front speakers will bother me
my installer had planned of doing 4 in ceiling with a sub but i am gonna go with a really nice sound bar (millennia trio) with the sub (bw pv1d) and keep 2 of the rear ceiling speakers for surround... this is gonna make the best of a bad situation
post #9 of 10 Old 02-01-2014, 06:56 PM
DMark1's Avatar
A sound bar can work quite well in some situations. Check out the Legacy Audio soundbars, which are very serious speakers. Also, Current Audio makes some in ceiling speakers (the FIT series) that have the ability to be angled toward the listening position. Not just the tweeter, but the whole speaker angles up inside the ceiling. In ceiling speakers are obviously not optimal, but current's solution seems like it would be better than most.
Fine Music, Movies, Wine, and Friends - A Life Well Lived!
DMark1 is offline
post #10 of 10 Old 02-01-2014, 07:26 PM - Thread Starter
miker2014's Avatar
thx
i will take a look at those
i agree ceilings are not optimal but i am trying to make the best of them
Reply Speakers
