Speaker suggestions for home theater system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-01-2014, 02:20 AM - Thread Starter
cobee10's Avatar
I have little knowledge of speakers and would kindly appreciate some advise on speakers for my new house. I recently got a Yamaha RX-V773 and realized my old Klipsch HD 500 speaker system is too weak for my larger living room 25'x20'. I would like to get floorstanding speakers and center with $500 budget. We use the home theater system for movies and music. The back surround speakers are installed in the ceiling, which I believe are B&W CWM 200. My questions are
1. Which front speakers should I get?
A. pair of Polk rti8 (2 x $150 = $300)
B. pair of Infinity Primus 363 (2 x $107 = $214)
C. pair of JBL ES80 (2 x $144 = $288)
2. Any recommendation on a good center for my setup?
3. Can I use my current subwoofer from the Klipsch HD 500 system (labeled as Klipsch sub 8)? Keep in mind I do not plan to make my room shake since I have a 3 year old who is a light sleeper.
Thank you for your help.
cobee10 is offline
post #2 of 7 Old 02-01-2014, 07:34 AM
wes182's Avatar
Quoted: 51 Post(s)
Liked: 26
I like the sound of Energy speakers. Best Buy has their CF70s and CF50s on clearance. Unfortunately above your $500 range. If you are set on floorstanders then maybe buy used. I've seen some nice sets in your range that may provide better quality. If you are not set on floorstanders and you aren't a "room shake" type of person then maybe consider some bookshelves if you have a place to put them. See if those and your sub provide good enough quality. Might save you a few bucks. And, if not already mentioned, match the fronts and centers.
I know that doesn't answer the direct question but maybe some ideas.
wes182 is offline
post #3 of 7 Old 02-01-2014, 12:09 PM
mark62's Avatar
Liked: 88
I would get a better sub evntho you state you dont want to shake the room, and if you have a good sub you do not need towers.
As for a center get a center that matches your L/R from the same brand...
mark62 is offline
post #4 of 7 Old 02-01-2014, 12:10 PM
mark62's Avatar
Liked: 88
I had the CF-70's and sold them within a month because they were too bright for me. Just goes to show how subjective speakers are...
mark62 is offline
post #6 of 7 Old 02-01-2014, 10:35 PM - Thread Starter
cobee10's Avatar
Thanks for the comments. there is no room for book shelf speakers in my entertainment center. I went to Frys to take a listen to the speakers. The speakers I had listed above sound kinda muddled. The salesman there talked me into getting a pair klipsch RF42 II tower for $480 (amazon has it for $300 each). He told me I can use the current sub and center from my old klipsch HD 500 system, saying this setup would be better than the Jbl es80, primus 363, or Polk rti8 with a new center. Do you agree or did the salesman got me?
cobee10 is offline
post #7 of 7 Old 02-01-2014, 10:42 PM
mark62's Avatar
Liked: 88
.. that HD 500 center is just not going to cut it. The center is the most important speaker for HT. Never listen to the floor associates, ever...
you stated that the HD 500 was too weak for your new room, it applies more than ever to that center..
You really need this center
http://www.amazon.com/Klipsch-RC-42-II-Center-Speaker/dp/B0040QMTK4/ref=pd_bxgy_e_text_y
mark62 is offline
Reply Speakers
Klipsch Hd 500 Compact 5 1 Home Theater System Set Of Six Black , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Jbl Es80bk 3 Way Dual 6 1 2 Floorstanding Speaker Black , Yamaha Rx V773wa Receiver , Infinity Primus P363 Three Way Dual Infinity Floor Standing Speaker
