Need your advice on speakers, placement, and how it looks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 02-01-2014, 01:23 PM - Thread Starter
JaredSD's Avatar
Quoted: 95 Post(s)
Hello community! Some of you helped me out a lot with my last post, and I appreciate it. I have decided to upgrade my left, right, and center speakers for the time being. I have a couple of questions you may be able to help me with.
1. I have used these small Velodyne bookshelfs for many years. If I move up to floorstanding speakers, I should be able to tell a difference, right? I have the receiver to push floorstanding speakers quite nice. Any thoughts on sound improvement? Bigger soundstage?
I am on a budget. I don't need the expensive stuff to be happy. I am currently looking at this Polk and this Pioneer as options, and would get the center to match them. I hear great things about both of them, for the price point.
2. Take a look at my setup. I have room on the left and the right for floorstanding speakers, but please tell me.....would it look like crap and out of place in general? The one on the right will hide in the corner next to the sub while the one on the left would just be hanging out (not as bad for the Pioneer though). Also, the Polk (43 inches tall and 15 inches deep) models would come just under the 3rd shelf and the Pioneers (35 inches tall and 10 inches deep) would come to about a 1/3 of the way up from the 2nd shelf. I think the Pioneers are a better size, and perhaps both will provide similar sound?
Any thoughts on this from an aesthetic standpoint? Btw, I don't have a WAF to deal with haha....it is just me.
Any thoughts would be great and any other suggestions I have not mentioned are absolutely welcomed. Feel free to call me out if my logic on considering floors over bookshelfs is wrong. Thank you all!
Jared
JaredSD is offline
post #2 of 18 Old 02-01-2014, 03:48 PM - Thread Starter
JaredSD's Avatar
Quoted: 95 Post(s)
Anyone haha? Sorry, just trying to at least get a couple points of view is all.
JaredSD is offline
post #3 of 18 Old 02-01-2014, 04:07 PM
SyntheticShrimp's Avatar
Quoted: 241 Post(s)
Liked: 210
I think you'll find that you'll hear a large improvement. The speakers will probably be better, but the setup will definitely be better.
Just by getting the speakers out of the bookshelf, as you will be forced to do with floorstanders, you are making a good move.
I can't speak much to the aesthetic sensibility of it. It probably will not be as attractive, but it doesn't strike me as objectionable.
JaredSD likes this.
SyntheticShrimp is offline
post #4 of 18 Old 02-01-2014, 04:15 PM - Thread Starter
JaredSD's Avatar
Quoted: 95 Post(s)
Thanks for the reply! Do you think it is okay to put the speaker in that corner with sub right next to it? The sub would be right next to entertainment area and the speaker would be against the wall. It would be a tight fit, but both would fit and would be postioned straight facing; I could toe in the speaker a little actually. It is the only way it would work....unless I decide to move the sub to the back of the room sometime. I heard it is better to have it up front though.
JaredSD is offline
post #5 of 18 Old 02-01-2014, 04:24 PM
olletsoc's Avatar
Liked: 39
my first though is the one on the right, speakers do not like being placed in a corner.
my second thought is the pioneers are rear ported so they will need some room behind for proper air movement
olletsoc is offline
post #6 of 18 Old 02-01-2014, 04:27 PM
LastButNotLeast's Avatar
Quoted: 1793 Post(s)
Liked: 1404
That's pretty much how I have mine, speaker (http://www.newegg.com/Product/Product.aspx?Item=N82E16882117403) in the corner towed in next to forward-facing sub.
Works fine, and I have REW graphs to prove it. ;)
Had it like this, but switched the sub and speaker because the port was firing into a floor vent! :eek:
http://cdn.avsforum.com/e/e3/e325dc78_020913lighter.jpeg
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #7 of 18 Old 02-01-2014, 04:40 PM - Thread Starter
JaredSD's Avatar
Quoted: 95 Post(s)
That is great, thanks for sharing. Your situation is just like mine. I would actually have about 5 inches behind the speaker for the ports, and those shelves are open so it is not like it is against a flat wall. Perhaps that will help things as well?
JaredSD is offline
post #8 of 18 Old 02-01-2014, 04:43 PM
Liked: 1404
No, it's just that the stuff on the shelf will be pushed forward. :D
There are those who prefer the second generation Pioneers, but I'm very happy with the ones I have. You can get either center, price and size can determine your preference.
Michael
post #9 of 18 Old 02-01-2014, 04:50 PM
Quoted: 241 Post(s)
Liked: 210
That arrangement would work. It does place the right speaker closer to the boundaries than is preferable.
I think the consideration of port location is overblown here on AVS. One gets boundary gain when the source is less than 1/4 wavelength from the boundary. It doesn't matter if the OP uses front or rear ported, the frequencies the ports cover will be well within that zone either way.
JaredSD likes this.
post #10 of 18 Old 02-01-2014, 05:01 PM - Thread Starter
JaredSD's Avatar
Quoted: 95 Post(s)
Perfect, thank you all. One more thing I wanted to clear up....there is a center channel that is offered in this series. However, I am not sure it is better than the one I have? Could be an even trade. I also understand the importance of keep some parts of the set the same perhaps. Could I get any center channel to go with these speakes or do I need to follow matching rules? I want a good center channel for sure. If you have any ideas other than what is listed here then please advise for sure.
What I have:
Velodyne Two 4 1/2" Woofers in CT-42 Center Channel Speaker
What is offered in the Pioneer line:
http://www.amazon.com/Pioneer-SP-FS52-LR-Designed-standing-Loudspeaker/dp/B008NCD2S4 (click on center channel)
Also, these speakers are 6 ohms. My receiver says something about 8 ohms. Not sure if that matters or not?
JaredSD is offline
post #11 of 18 Old 02-01-2014, 05:04 PM
mark62's Avatar
Liked: 88
What I have:
your center indeed should match your L/R.....
JaredSD likes this.
mark62 is offline
post #12 of 18 Old 02-01-2014, 05:09 PM - Thread Starter
JaredSD's Avatar
Quoted: 95 Post(s)
That is what I thought. Well, do you think this one is adequate? I am sure it is about the same as what I have now, but at least it would match. Damn, I wanted something huge haha.
JaredSD is offline
post #13 of 18 Old 02-01-2014, 05:11 PM
Liked: 1404
Which is what I said. Either generation of the Pioneers will be fine with either generation of towers.
And no, you DON'T want a huge center channel.
(You want a HUGE subwoofer, but that's another topic altogether.)
Also on sale:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117404
I got my first generation when the second was released; paid even less than these prices (from NEgg).
post #14 of 18 Old 02-01-2014, 05:13 PM
Quoted: 241 Post(s)
Liked: 210
I've seen that pioneer center, and it may be bigger than you're anticipating. It has relatively small drivers, but the enclosure is pretty large.
JaredSD likes this.
post #15 of 18 Old 02-01-2014, 05:17 PM - Thread Starter
JaredSD's Avatar
Quoted: 95 Post(s)
Awesome, then I feel good with this set. Thank you so much for the time to respond to this. I appreciate it.
JaredSD is offline
post #16 of 18 Old 02-01-2014, 06:05 PM - Thread Starter
JaredSD's Avatar
Quoted: 95 Post(s)
Also on sale:
I sent you a PM with a couple of questions. Thanks!
JaredSD is offline
post #17 of 18 Old 02-01-2014, 06:24 PM
mark62's Avatar
Liked: 88
Also on sale:
You would want the same generation center speaker to match as they are quite different in their sound characteristics.
mark62 is offline
post #18 of 18 Old 02-01-2014, 06:43 PM - Thread Starter
JaredSD's Avatar
Quoted: 95 Post(s)
Goctha, thanks. I did have a question I PM'ed you about...please.
JaredSD is offline
Reply Speakers
