Speaker suggestions to use with Topping TP20 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 02-01-2014, 03:34 PM - Thread Starter
das323's Avatar
Hi
This is my first post. Thanks in advance for any ideas, suggestions and help you can provide.
I'm looking for a pair of small bookshelf speakers to pair with a topping tp20 amp. This will be for music listening only in a relatively small room.
I've read that the amp performs best with high sensitivity speakers, but I don't know for sure.
I'd prefer to keep cost below $300, and as far below that as possible ;-)
I've seem plenty of Polk Audio options for well under $200. The Pioneers by Andrew Jones (I think that's the name) sound great, but at 85db and 6 ohms I don't know if it's right for the amp.
Any help will much appreciated.
das323 is offline
post #2 of 16 Old 02-01-2014, 03:44 PM
mark62's Avatar
Liked: 88
mark62 is offline
post #3 of 16 Old 02-01-2014, 04:02 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
I'm using a Topping TP30 to power a set of our HVL-1's. Works quite well.
I would like to try one of the t-amps that has bluetooth connectivity.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #4 of 16 Old 02-01-2014, 05:34 PM
mark62's Avatar
Liked: 88
Here is a link for those speakers.....
http://www.wavecrestaudio.com/products/hvl-1-two-way-loudspeaker-pair
also there is a 15% off coupon... and a review here...
http://www.hometheatershack.com/forums/speaker-subwoofer-reviews/72159-wave-crest-audio-hvl-1-speaker-review.html
In celebration of this review, use the discount code "jman" and receive 15% off of your order.
mark62 is offline
post #5 of 16 Old 02-01-2014, 05:36 PM
mark62's Avatar
Liked: 88
What do you think about these little amps?
mark62 is offline
post #6 of 16 Old 02-01-2014, 07:16 PM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2985
Originally Posted by mark62 View Post
The class T amps seem to work best with full range drivers. Meaning a speaker with no crossover. But any speaker with a decent sensitivity will work fine.
I've never heard that before, and I've used t-amps with several different sets of speakers. Why are you suggesting that? confused.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #7 of 16 Old 02-01-2014, 07:21 PM
mark62's Avatar
Liked: 88
read it many times, I said SEEMS. sure they work well with a lot of speakers. I'm not going to try to find what I have already read and the reasons for it. so just discount what I said...wink.gif
google it... "t amp full range speakers"
mark62 is offline
post #8 of 16 Old 02-01-2014, 07:45 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
I've used T-amps with many bookshelf speakers. They work great.
And what exactly is a full range speaker? does it really go from 20hz - 20khz?
Afro GT
afrogt is online now
post #9 of 16 Old 02-01-2014, 07:46 PM - Thread Starter
das323's Avatar
Thanks for the helpful feedback.
Mark62, I've read good things (on amazon at least) about the miccas, but I'd crossed them off my list because of their relatively low sensitivity. Perhaps I should reconsider....
Anyone have any thoughts on these options?
1) Polk Audio Monitor30 Series II
2) Polk Audio New Monitor 35B
3) JBL Loft 30
4) Klipsch Synergy B20
5) Definitive Technology Studiomonitor 350
The Definitive Techs look great from what I've read, but they're also the priciest. The others can be had at big discounts online, not that price is the end all, be all....but I don't want to spend money unnecessarily.
Not sure if it will help, but my listening tastes favor clarity and crispness, if that makes any sense. I don't really like boomy, over boosted, heavy sounds. I rarely turn up the bass, for instance, but I will adjust treble sometimes.
Thanks again for the comments. I'd be interested to hear what you all think of the above listed speakers.
das323 is offline
post #10 of 16 Old 02-01-2014, 07:58 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would go with the Definitive - look again, the price is good
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325059
I would still put the HVL-1 on a short list
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #11 of 16 Old 02-01-2014, 08:00 PM
mark62's Avatar
Liked: 88
Of course they dont measure flat to 20hz. A full range speaker is speaker with one driver with no crossover...
I also said that they work good with all speakers as long as you don't overdrive the amp, they get ugly quick , I don't understand why I am getting flack over this....
The T amps are a completely different design than traditional amps, again I've read it several times that T amps don't like crossovers because of the supposed complex load. I read it and it doesn't necessarily make it right. Again I did not say the T amps sound bad with non full range speakers, I in fact said that they work fine.
Also full range speakers tend to be pretty efficient.
http://en.wikipedia.org/wiki/Full-range_speaker
mark62 is offline
post #12 of 16 Old 02-01-2014, 08:38 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
I use them in a desktop system.
As long as the speaker isn't low impedance and it doesn't have any wild impedance swings, and you don't need to get real loud...they should work fine, and a great solution for a small music system. I think I even saw what that had a subwoofer output.
I'd like to try one that has bluetooth connectivity, along with nice speakers instead of some of these phone docks that sound horrible.
-curtis
cschang is offline
post #13 of 16 Old 02-01-2014, 08:41 PM - Thread Starter
das323's Avatar
zieglj01 -- thanks for the definitive tech link. Definitely the best price I've seen, by a long shot. Still it's almost 2x the cost of the Polk monitor 30s I see on newegg. So what to do.... confused.gif
I really miss the old days when there were actual brick and mortar stereo stores where you could listen and compare...wink.gif I went BB today, as it's pretty much the only place around here, aside from the super high end shops, and it wasn't at all conducive to a listening test.
Anyway I digress.
Newegg has a lot of good deals, that's for sure. Truth be told, I have a gift card at amazon I'd love to put to use here. It's restricted to items sold and shipped by amazon, so unfortunately that rules out 3rd party sellers and a lot of the good speaker options. But, if anyone knows of good choices that meet my gift card criteria, I'd love to hear (so to speak) 'em.
Thanks again.
das323 is offline
post #14 of 16 Old 02-01-2014, 08:44 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The Definitive sound signature, is in a higher league over the Polk.
I will look at Amazon
Who AM I
zieglj01 is offline
post #15 of 16 Old 02-01-2014, 08:59 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Thanks again.
Since you like a crisp sound and less bass - the Infinity Primus 153
http://www.amazon.com/Infinity-Primus-P153-Bookshelf-Satellite/dp/B004649W1Y/ref=sr_1_5?ie=UTF8&qid=1391313403&sr=8-5&keywords=infinity+primus
Who AM I
zieglj01 is offline
post #16 of 16 Old 02-01-2014, 09:13 PM
mark62's Avatar
Liked: 88
It also really depends how loud you like to play your music, even with a speaker with a 90dB sensitivity your not going to be able to play REALLY loud. As long as you get a speaker in the 87dB range you should be fine. You can't trust the manufacturer claims a lot of times anyway. Especially Klipsch.
I guess what I'm trying to say is if you listen at say 85dB you are just using a watt or two, and that leaves some headroom for dynamics...
mark62 is offline
Reply Speakers
