First budget build 4.0 vs 2.1 system for movies? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-03-2014, 08:38 PM - Thread Starter
adamw5963's Avatar
I'm looking for speakers for my home theater. It's a small room 12x12. Since I'm on a tight budget I figured I would start with a 2.1 system. I was looking at the Pioneer SP-BS21-LR speakers. They have them at walmart for $78 and I have a $50 gift card there so that would drop them to $28 for me so that's a great deal. I was also planning on getting a Dayton 1000 sub. However, as I was looking on the forums I saw someone suggest that if you were going to mainly watch movies and tv then maybe buying 2 pairs of bookshelves might be better than a 2.1.
So for my situation would it be better to buy 2 pairs of the pioneers and have front and back or buy 1 pair and a sub?
adamw5963 is offline
post #2 of 9 Old 02-03-2014, 08:51 PM
LastButNotLeast's Avatar
Quoted: 1794 Post(s)
Liked: 1404
Save the gift card and get the speakers here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405
Or, better yet, if you have the room, get these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117406
Surround is not nearly as interesting as bass, so stick with 2.1 for now.
And spend the $20 for the 1200.
Of course, it's only been 5 minutes, so you'll surely get dozens of other (contradictory) recommendations.
Have fun.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #3 of 9 Old 02-03-2014, 09:23 PM - Thread Starter
adamw5963's Avatar
Why get it from Newegg? Just curious.
post #4 of 9 Old 02-04-2014, 12:48 AM
zibanez's Avatar
Quoted: 36 Post(s)
3.1 (front center sub) system if you can afford it
Bedroom theater
Dynaudio DM 2/6 - Dynaudio DM Center - Def tech pro monitor 600 - Rythmik Audio CI 15" HP600 - Marantz NR1402 - Bantam Gold Power Amp - Clark Synthesis tst 239 - Dune H1 - PS3
zibanez is offline
post #5 of 9 Old 02-04-2014, 05:30 AM
Liked: 1404
Cheaper and no tax.
I've been dealing with them for years and have had very few problems.
I don't have any problem with Walmart, but I would use the gift card on something else.
post #6 of 9 Old 02-04-2014, 05:31 AM
Liked: 1404
Indeed, it is better to have a matching center.
Any particular reason your two choices are 4 vs. 2?
post #7 of 9 Old 02-04-2014, 06:19 AM
darkpoet25's Avatar
Liked: 40
What is your actual budget, and do the speakers have to be Pioneer? I'd say for now stick with a 2.1 set up and add the center and surrounds as money allows.
Cliff
darkpoet25 is offline
post #8 of 9 Old 02-04-2014, 07:25 AM - Thread Starter
adamw5963's Avatar
Around $150. I know it's really tight but just graduated and funds are not there plus I went a little over budget on the TV lol. I was just saying Pioneer bc they were cheap and seemed to have good expert reviews. I'm all ears if there's another option.
post #9 of 9 Old 02-04-2014, 11:35 AM
darkpoet25's Avatar
Liked: 40
A couple of budget options that people seem to like are BIC and Fluance. Try checking them out and see if they offer something you would like in your price range.
Cliff
Reply Speakers
