My current speaker set up (mixed brands) help - AVS Forum
post #1 of 6 Old 02-04-2014, 02:47 PM - Thread Starter
GJDMan's Avatar
Hi,
During a black friday a few years back I got some great deals; however, I didn't think too much into sticking with one brand. Anyways, I bought:
Fronts - Klipsch Icon VF35s
Center - Polk Audio CS20
Surrounds - Polk Audio Monitor 40 series II
So I read I should have all of the same brand. How true is this and if I should, which components should I take out?
GJDMan is offline
post #2 of 6 Old 02-04-2014, 03:15 PM
darkpoet25's Avatar
Liked: 32
Originally Posted by GJDMan View Post
Hi,
Ideally you want the front three speakers to be timbre matched, since most of the audio is in the front soundstage. When the sounds pan across the speakers, they will be seamless and blend well together. So if you like your Polk speakers, replace your Klipsch Icon's with a matching pair for your CS20 center channel. Vice versa, if you like the sound of the Klipsch's get the matching center channel. You can keep your Polk's for surround use if you get the Klipsch's.
SanchoPanza likes this.
Cliff
darkpoet25 is offline
post #3 of 6 Old 02-04-2014, 03:24 PM
roland6465's Avatar
This is the perfect response. The priority is getting a smooth transition between the L, C, & R speakers (and sub), and the surrounds are secondary.
roland6465 is online now
post #4 of 6 Old 02-04-2014, 09:45 PM
sdg4vfx's Avatar
Liked: 92
+1
sdg4vfx is offline
post #5 of 6 Old 02-05-2014, 02:02 AM
SanchoPanza's Avatar
Quoted: 46 Post(s)
Liked: 437
+2
Will I find La Scala, or better, to displace my La Scala fronts, before I displace my kg1, kg2 & kg3 with Heresy or better?
RED AND BLUE=MAROON!
SanchoPanza is online now
post #6 of 6 Old 02-05-2014, 09:36 AM
FMW
FMW's Avatar
Quoted: 74 Post(s)
Liked: 617
No need really to replace or buy. Just move the Polk speakers to the main position and the Klipsch to the surround position.
FMW is online now
Reply Speakers
Polk Audio Cs20 Center Channel Speaker , Polk Audio Am4095 A Monitor40 Series Ii Two Way Bookshelf Loudspeaker Pair , Klipsch Icon Vf 35 Floorstanding Speaker
User Tag List
