Narrow stage - small bookshelves - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 02-05-2014, 05:24 PM - Thread Starter
jtroxel's Avatar
Basically, I have a narrow sound stage (about 6'), and an interior designer for a wife.  I can't fit floorstanding speakers to the side of the TV, they would have to be bookshelves that sit on the cabinet that runs under the TV, and they can't be bigger than say 10"x6".  I have less than 6" above the cabinet and the bottom of the TV.
Also I should point out that my wife and I sometimes have a hard time understanding dialog, so that is a priority for sure (right now we have an ancient Infinity center, C1 I think).
So, I am wondering if we should go with a relatively bigger center (though slim), compared with the sides? For example a BA RS 223 or Yamaha NS-C310BL with small matching bookshelves.  Or am I better off with the bigger sides and a smaller center?  The 3 speakers will all be so close together, I know I don't want 3 large speakers there.  The viewing are of the space is about 13' deep by 20' wide.
Thanks in advance,
 - John
jtroxel is offline
post #2 of 22 Old 02-05-2014, 05:34 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
If you have trouble hearing dialog getting a more cohesive front sound-stage (aural "sound-stage", not furniture sound-stage) would very likely help - this means getting a center speaker that is timbre matched to the RL main speakers.
Three of these might make a good LCR in your setup - their somewhat unique form factor might be tailor made for your situation. http://www.htd.com/Products/flat-panel-speakers/flat-panel-speaker
They also happen to come in white. The LR mains can either stand up on the cabinet or be mounted on the TV wall. They have a better, richer sound and are deeper than most "wall mount" speakers.
sdg4vfx is offline
post #3 of 22 Old 02-05-2014, 05:41 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
It looks like your center channel speaker is sitting on the bottom - that is one of the problems
You can buy 2 pair of the Focal Sib, use one as center - and have a spare. They use to sell
for $399 a pair
http://www.accessories4less.com/make-a-store/item/FOCALSIBPRWHT/FOCAL-Sib-5-2-Way-Satellite-Loudspeakers-Pair-White/1.html
Another option, Boston 3-channel passive SoundBar - a real good price - put under the TV
http://www.accessories4less.com/make-a-store/item/BOSP400BA/BOSTON-ACOUSTICS-P400-Soundbar-Speaker-Black-NEW/1.html
What subwoofer do you own?
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 22 Old 02-05-2014, 09:00 PM - Thread Starter
jtroxel's Avatar
A better picture of the setup perhaps:
...this is the Infinity C1 center, and 2 satellites just because I don't have anything else that fits yet.  We used to have a bigger wall and we had some BIC bookshelves and a LCR for the center, though we never felt dialog was clear with that setup either (music was great).
The sub we have is also an old Infinity...  I figured that didn't matter too much.
I definitely want to timber match the fronts and center, and assuming the generally the same brand will do that.
I guess another way to ask is, does it make sense to have a center bigger than the sides?
Thanks for the suggestions, will look into those tomorrow.
jtroxel is offline
post #5 of 22 Old 02-05-2014, 09:04 PM
Kini62's Avatar
Quoted: 1419 Post(s)
Liked: 1307
Take a look at NHT speakers.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #6 of 22 Old 02-05-2014, 09:06 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Well, it looks to me that you have room for L/C/R speakers - like the Boston P442
They come with 2 grills in the box - you have a choice of silver or black
http://www.accessories4less.com/make-a-store/item/BOSP442BA/BOSTON-ACOUSTICS-P442-LCR-Left-Right-Center-Speaker-Black-Each-NEW/1.html
http://www.accessories4less.com/mas_assets/cache/image/1/4/f/4/5364.Jpg
Put 2 vertical on the white wall L/R - and the other horizontal, under the TV
http://a248.e.akamai.net/pix.crutchfield.com/ImageHandler/fixedscale/400/300/products/2005/065/x065P442-o-1.jpeg
If budget permits, I would upgrade your subwoofer.
Who AM I
zieglj01 is offline
post #7 of 22 Old 02-05-2014, 09:11 PM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
Yes, that works out OK and should help with dialogue clarity.
But with just 6" of height, I'm not sure you're going to find much.
Couldn't you have a tall speaker on either side of the TV? This kind of thing? or something like this?
buzzy_ is offline
post #8 of 22 Old 02-06-2014, 05:25 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
That picture is very tiny and hard to make out, but it looks as if your L and R speakers are pointed out, they need to be toed in slightly towards the listening position. Try this first and see if dialog improves at all. As was mentioned earlier, I would recommend the looking at NHT as well, specifically the Absolute Zero. It fits your size requirement, comes in white, and would offer great clear dialog. I think just a pair would work fine, a good pair of bookshelves will have no problem with dialog.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #9 of 22 Old 02-06-2014, 06:46 AM
Bill Fitzmaurice's Avatar
Liked: 4653
No. It's OK for the center to be the same size or somewhat smaller, though it's hard to timbre match when they're not identical. The main issue as I see it is that all of those speakers are way too small. Where good sound is concerned size does matter.
Bill Fitzmaurice is online now
post #10 of 22 Old 02-06-2014, 01:39 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+1 ^^^ Bigger, timbre matched speakers will be a big help!
...I definitely want to timber match the fronts and center, and assuming the generally the same brand will do that....
Same brand and same model line. Most manufacturers have a "matching" center for each LR main bookshelf or tower speaker model lines.
...I guess another way to ask is, does it make sense to have a center bigger than the sides? ...
Not really. Try not to think of the front three speakers as separate sound zones, but all three working together to create one cohesive sound zone.
The Cambridge Audio S series is on close out sale right now (at http://www.accessories4less.com/) and it's center should fit your space.
Pair of S30 bookshelves with the S50 center speaker (only 4.5" tall). Should be a big improvement over what you have now.
If you can fit a 7" center a KEF Q100 set will fit your space. They are front ported and would accomplish Bill F's suggestions. (Also at accessories4less, more expensive than the Cambridge Audio set.)
Pair of KEF Q100 bookshelves with the Q200c center (7" tall).
Or, three KEF Q100 bookshelf speakers using one laid on it's side as a center will give you three identical speakers LCR (also 7" tall). The Q100 uses a single concentric driver so unlike most speakers you can lay it on it's side without affecting the sound quality/signature.
sdg4vfx is offline
post #11 of 22 Old 02-06-2014, 06:47 PM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
That's daft. There are lots of centers that are bigger than the sides, meant to be used when audio quality isn't the only goal being balanced. Not to mention that, in the real world it can actually work when there are tradeoffs to be made.
But again, it's not going to work here because you don't have room - there's more space at the sides.
buzzy_ is offline
post #12 of 22 Old 02-06-2014, 07:38 PM
Liked: 4653
While centers do carry most of the load in terms of content per listening minute, when the L/R do kick in at full volume they run louder than the center, so one would not want them smaller than the center. Ideally the three would be identical, but if you can timber match them the center can be smaller. My L/R run the same drivers as the center, but the L/R each have eight midbasses and twelve tweeters, the center has six midbasses and six tweeters. This allows all of them to have the same headroom when each channel is reaching peak output.
Same drivers. Some manufacturers think that matching is a cosmetic issue. rolleyes.gif
post #13 of 22 Old 02-06-2014, 10:24 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
That's daft. There are lots of centers that are bigger than the sides, meant to be used when audio quality isn't the only goal being balanced. Not to mention that, in the real world it can actually work when there are tradeoffs to be made ...
True there are always trade-offs and compromises in any home theater - this is how the notion of a "dedicated" horizontal speakers came to be. Horizontal center speakers were created/designed to accommodate space limitations in the average home theater, not for improved sound quality or to somehow be "optimized" for center channel content (dialog or otherwise). Almost all theaters have identical speakers LCR across the front, and movies soundtracks are mixed on identical speakers LCR (most often even with identical speakers all the way around).
Choosing your trade-offs/compromises is part of setting up any home theater system wink.gif
sdg4vfx is offline
post #14 of 22 Old 02-07-2014, 08:16 AM - Thread Starter
jtroxel's Avatar
Thanks all, you've got me busily researching several options.  This forum is awesome.
Right now I am thinking identical LCRs or at least boxes (can I call them that?) that have the same drivers.  Seems like wall mount enclosures have the best chance of fitting for me.  Paradigm Cinema 200, BA P442 would work, though a width under 5' would allow the TV to swing out.  Our couch is off-center in relation to TV, silly split-level layout.  I also an very intrigued by the HTD Flat Panels and Middys, I like that I can kick the tires with little risk there.
Thanks again for all the advice so far...  I think I am headed toward a solution.
 - John
jtroxel is offline
post #15 of 22 Old 02-07-2014, 10:35 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
You do not want to swing out the TV, to where the sound would come from behind the vision/sound plane.
That can be a distraction, that can also lead to an annoyance with dialog.
Who AM I
zieglj01 is offline
post #16 of 22 Old 02-07-2014, 10:48 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
The HTD Flat Panel, to my ears, does sound better than most flat-panel wall mount speakers (some costing 4x more). But to be fair it has the advantage of not really being flat - it's a 4" deep wood cabinet smile.gif
Good luck!
sdg4vfx is offline
post #17 of 22 Old 02-07-2014, 11:26 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The HTD Flat Panel is good for the money, and better than some. However, not as transparent,
open and clear as I would prefer - and somewhat lacking in detail and definition. However, I do
prefer it over the likes of Bic and the Infinity that you own. Still a nice option for the price.
Who AM I
zieglj01 is offline
post #18 of 22 Old 02-07-2014, 03:59 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+1 Standard bookshelf speakers would be preferable to any flat-panel (or satellite) speakers - you can't circumvent physics wink.gif
The 6" height restriction on your center speaker is one of your biggest limitations. The Cambridge Audio set will fit your space and IMO would sound better than the HTD Flat Panel speakers. (I'm sure there are other speaker sets I'm not familiar with center speakers 6" or less ...)
If you can increase that space to accommodate a 7" or 7.5" tall center speakers your options increase dramatically.
Again - Good Luck!
sdg4vfx is offline
post #19 of 22 Old 02-07-2014, 06:06 PM
MarsianMan's Avatar
Liked: 33
I wonder if you can fit an Arx A2 by putting it on the front edge of the cabinet and covering the bottom frame of the tv? The Arx bookshelf and center would be good and the center is just over 7.1 inches. Although, not sure that would pass the WAF.
MarsianMan is offline
post #20 of 22 Old 02-07-2014, 06:22 PM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
Did you look at NHT?
On Wall - 13.8 H x 5.7 W x 4.6 D
http://www.nhthifi.com/Home-Theater-Absolute-On-Wall-Speaker-White?sc=12&category=7166
Absolute Zero Center - 6.25" x 19" x 7.375" - will that fit in front of the TV or in the cabinet?
http://www.nhthifi.com/Absolute-Center?sc=12&category=3774
You could re-mount the TV, there's room.
buzzy_ is offline
post #21 of 22 Old 02-07-2014, 11:30 PM
macddmac's Avatar
Quoted: 16 Post(s)
Another option could be psb imagine minis with the mini center.. Not cheap but I love the minis in my office and have heard them in larger rooms- quite impresssive.
Also , is there a way to adjust the hanging bracket on the TV so that the display raises an inch or two?? Most brackets have such adjustability.
You may have to remove the bolts and reinstall in a lower position to raise the TV .
Cheers, Mac
macddmac is offline
post #22 of 22 Old 02-10-2014, 08:03 AM - Thread Starter
jtroxel's Avatar
I am adding the NHTs to the short list.  Sadly the PSBs are out of my range.
Thanks again for all the suggestions.  Now for the negotiations with my wife :)
jtroxel is offline
Reply Speakers
Yamaha Ns C310bl 2 Way Bass Reflex Center Speaker
