Help With my Selection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 02-08-2014, 10:55 AM - Thread Starter
dmoney94's Avatar
1--Jamo S 426 HCS 3 WENGE 5-Piece Home Theater System
2--Polk Audio TSi300 5.1 Home Theater Speaker Package
3--Definitive Technology Pro Cinema 800 System Black
I using the Yamaha RX-A730
Please help me pick one...
dmoney94 is offline
post #2 of 24 Old 02-08-2014, 11:48 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
What is your budget?
What is the size of your room?
What are your listening preferences?
bladerunner6 is offline
post #3 of 24 Old 02-08-2014, 12:16 PM - Thread Starter
dmoney94's Avatar
I have a big living room. .
Mostly for movies..
About $800 or more..
dmoney94 is offline
post #4 of 24 Old 02-08-2014, 12:42 PM
Quoted: 20 Post(s)
Liked: 59
Mostly for movies..
What does "big" or "800 or more" mean?
post #5 of 24 Old 02-08-2014, 02:58 PM
mark62's Avatar
Liked: 88
mark62 is offline
post #6 of 24 Old 02-09-2014, 07:35 AM - Thread Starter
dmoney94's Avatar
Originally Posted by mark62 View Post
The Jamo's are not very good I got them for $129 and returned them...
these are another option..
http://www.htd.com/Products/level-two-speakers
http://www.htd.com/Products/level-three-speakers
sub...
http://www.parts-express.com/dayton-audio-sub-1200-12-120-watt-powered-subwoofer--300-629 2 of these
or
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_1?s=electronics&ie=UTF8&qid=1391900170&sr=1-1&keywords=bic+subwoofer
Are these sub better than the Klipsch 350 subwoofer?
http://www.svsound.com/subwoofers/ported-box/PB-1000#.Uva15pB6OGQ
all of these subs are better than the ones in the packages...
dmoney94 is offline
post #7 of 24 Old 02-09-2014, 09:11 AM
mark62's Avatar
Liked: 88
Yes they are better than the Klipsch 350 subwoofer by a long shot.
mark62 is offline
post #8 of 24 Old 02-09-2014, 09:12 AM
mark62's Avatar
Liked: 88
mark62 is offline
post #9 of 24 Old 02-09-2014, 10:41 AM - Thread Starter
dmoney94's Avatar
18×18 living room.
Bought the klipsch 350 subwoofer $80..
dmoney94 is offline
post #10 of 24 Old 02-09-2014, 10:43 AM
mark62's Avatar
Liked: 88
18×18 living room.
That sub is not really good enough for that size room, however it may be enough for you.....
mark62 is offline
post #11 of 24 Old 02-09-2014, 11:03 AM - Thread Starter
dmoney94's Avatar
Are you suggesting I should get the one on parts express.com for $129
What about TSI300 floorstand?
dmoney94 is offline
post #12 of 24 Old 02-09-2014, 12:08 PM
mark62's Avatar
Liked: 88
Yes the Sub-1200 or the Sub-1000 would be better.. preferably 2 of them, maybe add one at a later date...
IMO there are better speakers than the TSi at that price point. What price can you get them for?
The HTD Level Twos for example are better...
mark62 is offline
post #13 of 24 Old 02-09-2014, 12:58 PM - Thread Starter
dmoney94's Avatar
The have the pair of TSI300 for $160..
I will get one of those sub..
dmoney94 is offline
post #14 of 24 Old 02-09-2014, 01:12 PM
mark62's Avatar
Liked: 88
I didn't know you already had the Polks, what is your question regarding those?
mark62 is offline
post #15 of 24 Old 02-09-2014, 01:30 PM - Thread Starter
dmoney94's Avatar
I am trying to buy the polk..
dmoney94 is offline
post #16 of 24 Old 02-09-2014, 02:45 PM
mark62's Avatar
Liked: 88
mark62 is offline
post #17 of 24 Old 02-10-2014, 06:14 PM - Thread Starter
dmoney94's Avatar
Need a good center channel under $150..
Any help.
dmoney94 is offline
post #18 of 24 Old 02-10-2014, 07:54 PM
mark62's Avatar
Liked: 88
Any help.
You should always get a center that matches your mains...
mark62 is offline
post #19 of 24 Old 02-11-2014, 06:47 AM - Thread Starter
dmoney94's Avatar
Does it matter if the 4 surround are different from center and the two front..
The is going to be my setup:
A Pair of Polk Tsi300B for the Front
A matching center if I found one
And 4 Definitive Technology Procinema 800 for the surround.
dmoney94 is offline
post #20 of 24 Old 02-11-2014, 10:11 AM
mark62's Avatar
Liked: 88
mark62 is offline
post #21 of 24 Old 02-11-2014, 10:28 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
The Matching center to the TSi300's is the Polk CS10 and they are widely available in the USA just follow the links above.
Surrounds don't have to match the front 3 but without matching front 3 you are really missing out. Thats why you should get the CS10
crazyrob425 is offline
post #22 of 24 Old 02-11-2014, 11:47 AM - Thread Starter
dmoney94's Avatar
Thanks Guys..
How good is this Dayton Sub 1200, I see it has a lot good reviews.
Are reviews a marketing stunt or is it that good?
dmoney94 is offline
post #23 of 24 Old 02-11-2014, 12:13 PM
Quoted: 443 Post(s)
Liked: 337
Thanks Guys..
For the price there is nothing better. Its a good subwoofer for its money. Its that good. Spending more money would get you a better subwoofer but that is how it goes.
You could also try the Lava LSP12, email them that you are a AVS Forum user with your user name and they might give you an additional 15% off the already low price of $170
post #24 of 24 Old 02-12-2014, 05:03 PM
EugeneDebs's Avatar
Mostly for movies..
There is a Hsu 5.1 package for a hair over $1000:
http://hsuresearch.com/products/value1pkg.html
EugeneDebs is offline
Reply Speakers
Jamo S 426 Floorstanding Speaker , Polk Audio Tsi300 Floorstanding Speaker Single Black , Definitive Technology Pro Cinema 800 System Black , Yamaha Rx A730 7 2 Channel Network Aventage Home Theater Receiver
