Rear surround suggestions - AVS Forum | Home Theater Discussions And Reviews
Old 02-08-2014, 10:50 PM - Thread Starter
rlcoopmsu's Avatar
I have recently have put together a value surround sound and I'm not sure what to buy to finish my setup. I currently have two polk monitor70s, cs2 center, two svs pb-1000s and a Onkyo TX-NR626 7.2 receiver.
I'm looking to buy 4 more speakers for the rears to have a 7.2 setup but space is more of a concern considering the aesthetics. Would 4 satellite speakers be a good match or am I heading in the wrong direction? And what speakers would be a good fit for the price/value?
Any suggestions would be appreciated. Thanks!
rlcoopmsu is offline
Old 02-12-2014, 10:52 AM - Thread Starter
rlcoopmsu's Avatar
Let's try this again. Any suggestions?
Old 02-12-2014, 10:58 AM
flickhtguru's Avatar
Liked: 109
I would recommend Polk Monitor 30 Series II on newegg.com for $120 per pair. Or if you can find them at a better price somewhere else or if you have the original Monitor 70s then maybe you could find Monitor30s.
Shawn
flickhtguru is offline
Old 02-12-2014, 11:02 AM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
What is the budget?
Look at NXG Pro 4.1 - the all around word is good
http://www.amazon.com/Nxg-Pro-4-1-Satellite-Speaker/dp/B0044UHVOK/ref=sr_1_1?ie=UTF8&qid=1392231686&sr=8-1&keywords=nxg+pro+4.1
__________________________________________
Who AM I
Speakers > MB Quart VS05, Boston VS260, Snell K7, EOS 150SP
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PAR-200, Pioneer VSX-30
zieglj01 is online now
Old 02-12-2014, 11:14 AM - Thread Starter
rlcoopmsu's Avatar
I thought I would initially buy the first pair with a budget of 75-125. I noticed the monitor30s ii go on sale for 89.99?
I have the monitor70 ii.
Old 02-12-2014, 11:16 AM
Liked: 109
Ok. Well if you have room for the Monitor 30 II that is what I would go with cuz its part of the same set.
Shawn
Old 02-12-2014, 11:21 AM - Thread Starter
rlcoopmsu's Avatar
That was my initial thought. I just wanted to get a second opinion to know if there was better value/performance with an alternative. Thanks for the feedback.
Polk Audio Am7092 A Monitor70 Series Ii Floorstanding Loudspeaker , Polk Audio Monitor Series Cs2 Center Channel Speaker Single Black , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Onkyo Tx Nr626 7 2 Channel Network Audio Video Receiver
