JBL Cinema 3722/4722 vs QSC KW-153 active speakers for HT - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 36 Old 02-09-2014, 10:02 PM - Thread Starter
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
Hello forum friends,
I am brainstorming regarding speakers for a new HT (around 3500 cubic feet) and planning to use pro gear behind a false wall.
Which would you guys prefer for LCR between:
(1) JBL 3722n (or 4722n) (2 way passive, powered by crown xls drivecore 2000 amps)
or
(2) QSC KW153s (active 3 way, 1000 watts)
Max output is almost the same - 135/136 dbs.
The JBLs have a larger horn but the QSCs have DSP - not sure which would be better. The JBLs are super sensitive and I am not sure about the QSCs; I guess there is no sensitivity rating as they are active speakers
I have read several threads related to each of these two lines of speakers, but I don't recall seeing any comparisons between JBL pro stuff and active speakers, such as QSC, Electro Voice or JBL PRX series.
Davecraze is online now
post #2 of 36 Old 02-09-2014, 10:08 PM
pokekevin's Avatar
Liked: 102
I thought the KW line from QSC was designed for DJ purposes as they are based off of the K series?
What about QSC's DCS line?
pokekevin is offline
post #3 of 36 Old 02-09-2014, 10:32 PM - Thread Starter
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
The QSC DCS series are passive so they seem substantially equivalent to corresponding JBL pro and Klipsch pro offerings.
The KW153 uses the same drivers as the QSC DCS-2150, as I understand it.
post #4 of 36 Old 02-09-2014, 10:34 PM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
I had JBL pro 4675c vs K10's at one time and the JBL's were much better all around. The K10's sound good but they could fit inside the horn easily of the huge JBL's. The 4722n would give any speaker a run especially for theater.
Marantz 7702 Atmos
MKtheater is online now
post #5 of 36 Old 02-09-2014, 10:40 PM - Thread Starter
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
Thank you, MKtheater. I know you have traveled a long and winding road with respect to LCRs so appreciate your insight. May I ask why you replaced your 4675c and what you replaced them with?
post #6 of 36 Old 02-10-2014, 02:39 AM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Get the 4722N. Or the 3722n as second choice. Theses speakers are absolutely incredible for movies and at there price I can't think of anything that would top them for HT use
JBL Pro Cinema/PSA&HSU subs/Crown power/Sony SXRD
MANCHESTER UNITED!!
Reddig is offline
post #7 of 36 Old 02-10-2014, 08:36 AM
MKtheater's Avatar
Liked: 1116
I needed space and went with dual stacked DR-250's.
Marantz 7702 Atmos
post #8 of 36 Old 02-11-2014, 07:39 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
I just got a call from a cinema installer I had contact with before and he gave me an offer I couldn't refuse on 3 JBL 4722Ns so I bought them! Driving my F-150 to Oklahoma Saturday to pick them up!! I'm ecstatic!!
its phillip likes this.
MANCHESTER UNITED!!
Reddig is offline
post #9 of 36 Old 02-11-2014, 08:39 PM
MKtheater's Avatar
Liked: 1116
Awesome
Reddig likes this.
Marantz 7702 Atmos
post #10 of 36 Old 02-13-2014, 07:07 PM
pokekevin's Avatar
Liked: 102
Pics!
post #11 of 36 Old 02-13-2014, 07:11 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Originally Posted by pokekevin View Post
Pics!
Will do!! I'll take some pics of the warehouse I'm picking them up at on Saturday as well.
MANCHESTER UNITED!!
Reddig is offline
post #12 of 36 Old 02-14-2014, 12:33 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
To the OP, either choice would serve you well.
If you perform a quick AVS search for QSC KW series, you'll find some good discussions regarding those. The JBLs are high value/high performance too. At the same price, I'd likely get the JBLs, the more you could save by getting the QSCs, then that tilts things that way IMO. Seriously, either way, you'll be fine.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #13 of 36 Old 02-15-2014, 08:09 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Got my 4722s. Different horn than what comes with the 4722s tho. Got a couple old school Crowns thrown in the deal too.
MANCHESTER UNITED!!
Reddig is offline
post #14 of 36 Old 02-15-2014, 08:27 PM
MKtheater's Avatar
Liked: 1116
What horn and CD are those? Make sure it has at least the same upgraded CD.
Marantz 7702 Atmos
post #15 of 36 Old 02-15-2014, 09:19 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
It doesn't. Was getting ready to type that but got busy. Only the cab is from the 4722. When I got there we tried out the 4722 horns and CDs and one of them sounded crackily so he had another trio of JBLs and we took the horns and CDs off those and put them on the 4722 cabs and they all sounded awesome!! I'm not sure what horn and CDs they are tho cause the labels aren't on them. I didn't think they looked like JBLs but they sounded just like our better than the 4722 horns and CDs. He gave me a discount
MANCHESTER UNITED!!
Reddig is offline
post #16 of 36 Old 02-15-2014, 09:28 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
[IMG]
CD is huge. 6in across is measures. I'll live with them for awhile and if there's any crossover problems with this CD with the crossover that's on the cabs I'll get the original matching 4722 horn and CD used somewhere.
ellisr63 likes this.
MANCHESTER UNITED!!
Reddig is offline
post #17 of 36 Old 02-15-2014, 10:20 PM
MKtheater's Avatar
Liked: 1116
I wonder if they are the 4670D tops. My CD for my 4675 was bigger though but maybe mine were older. Any numbers on them?
Marantz 7702 Atmos
post #18 of 36 Old 02-15-2014, 10:22 PM
MKtheater's Avatar
Liked: 1116
What size is the throat or the part of the CD that attaches to the horn?
Marantz 7702 Atmos
post #19 of 36 Old 02-16-2014, 09:37 AM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Ya no numbers on them. Think the the throat is 2 inches
MANCHESTER UNITED!!
Reddig is offline
post #20 of 36 Old 02-16-2014, 10:29 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
The compression drivers appear to be P Audio, but uncertain.
Reddig likes this.
FOH is offline
post #21 of 36 Old 02-16-2014, 11:44 AM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Cool thanks for chiming in. Was hoping someone might have an idea.
MANCHESTER UNITED!!
Reddig is offline
post #22 of 36 Old 02-16-2014, 12:24 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Think it might be this one.
http://www.p-audio.co.uk/products/P-Audio_BM-D750_100W_2_inch_Throat_Compression_Driver.html
MANCHESTER UNITED!!
Reddig is offline
post #23 of 36 Old 02-16-2014, 12:35 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Glad to help, good luck.
Reddig likes this.
FOH is offline
post #24 of 36 Old 02-22-2014, 05:39 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Thanks always appreciate it. My Horn is the JBL 2380A
MANCHESTER UNITED!!
Reddig is offline
post #25 of 36 Old 02-22-2014, 07:31 PM
MKtheater's Avatar
Liked: 1116
So, we need graphs and such, impressions?
Marantz 7702 Atmos
post #26 of 36 Old 02-22-2014, 07:42 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Ya I'll let you guys know. I'm waiting on RCA to 1/4" adapters from Monoprice to run signal to the amps. Will be here Monday. I'm a total newb with measuring and need to get a good mic. I do have mic that came with the Onkyo receiver for Audyssey MultEQ XT. I have REW on laptop but have never used it. I'm sure I'll be asking lots of questions.
MANCHESTER UNITED!!
Reddig is offline
post #27 of 36 Old 02-22-2014, 11:15 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
[IMG]
If the crossovers don't like them... Why not try a MiniDSP and bi-amp the setup?
Reddig likes this.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is online now
post #28 of 36 Old 02-23-2014, 08:14 AM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Yes that's a great point and something I would definitely consider. I've always wanted a MiniDSP. These would prolly sound there best bi-amped anyway. Thanks dude!
MANCHESTER UNITED!!
Reddig is offline
post #29 of 36 Old 02-23-2014, 11:48 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Unless you have the knowledge to design the crossovers, adding a MiniDsp and bi-amping will be pointless. You really need to get the proper horn and compression driver. No way to get around that.
Martycool007 is offline
post #30 of 36 Old 02-23-2014, 08:01 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I have someone that is helping me get mine setup with the MiniDSP.
Reply Speakers
