AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Speakers (http://www.avsforum.com/forum/89-speakers/)
-   -   Speaker setup for Onkyo TX-NR626 (http://www.avsforum.com/forum/89-speakers/1517017-speaker-setup-onkyo-tx-nr626.html)
mahbazmi1 02-10-2014 02:13 AM
hi, i have just bought Onkyo Tx-NR626 to replace my old Onkyo Home Theater System HT-S6200 (7.1) My question is, can i use the same speaker of HT-S6200 as so far i could not able to have the same sound as i use to get on HT-S6200 using Audyssey setup mic. My speaker has following configuration :-
SKF-670 L/R 2-Way Front Speakers
• 4" (10 cm) cone woofer
• 1" (2.5 cm) Balanced dome tweeter
• Max. input power:130 W
• 6-ohm impedance
SKC-670 2-Way Center Speaker
• 6-ohm impedance
SKR-670 L/R Full-Range Surround Speakers
SKB-670 L/R Full-Range Surround Back Speakers
• 3-1/4" (8 cm) Full-Range Speaker
• 6-ohm impedance
SKW-770 Bass Reflex Powered Subwoofer
• 10" (25 cm) cone
• Output Level Control
• Max. power:290 W
my room size is 14' x 12'
thanks in advance for any advice/feedback!
bladerunner6 02-10-2014 03:06 AM
• 6-ohm impedance
• 6-ohm impedance
• 6-ohm impedance
• 10" (25 cm) cone
• Max. power:290 W
Is the subwoofer working?
I am thinking the sub you have might be a passive sub.
mahbazmi1 02-10-2014 05:09 AM
Yes, the sub woofer is working..but the bass sometimes is too heavy that skakes my room while watching movie. By the way what is passive?
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
