5.1 for small bedroom primarily for movies - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-11-2014, 01:32 PM - Thread Starter
adamw5963's Avatar
I have been looking for the past few weeks for some speakers for my bedroom. It's a small square room 10x10 with 8' ceiling. I know that's terrible for sound. I've looked at AJ Pioneer bookshelf speakers and Dayton subs but right now I'm trying to decide between 2 options.
Option 1: VIZIO S4251w-B4 5.1 Soundbar with Wireless Subwoofer and Satellite Speakers for $278
Option 2: Yamaha RX-V371 $150 and Monoprice 5.1 speakers for $100 = $250
I know option 2 would probably be suggested bc of the upgrades you could do down the road but right now I'm just concerned with sound quality. The reason I thought about the Vizio is bc my room is so cramped right now that I hated the thought of running wires around my room but I still wanted that 5.1 sound that engulfs you in a movies. Also, I know very little about audio except what I have learned these past few weeks. So I guess the main question is will there be much sound quality difference between the 2?
adamw5963 is offline
post #2 of 17 Old 02-11-2014, 02:01 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
For such a small room, 5.1 is really kind of over the top; not really workable.
I would suggest that you just use 2.0 or 2.1.
The Onkyo TX-8020 is $159 from Amazon, and the Dayton B652 speakers are $40 per pair.
Those are actually good speakers, believe it or not. The crazy low price makes it hard to accept, but they are good ones.
I bought a pair based on their Stereophile review, and they replaced some Boston speakers that cost over $200.
Forget the crappy soundbar; that is not the way to go.
commsysman is offline
post #3 of 17 Old 02-11-2014, 02:05 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
First off with only $250-$280 to spend realize any purchase you are making that it is a huge compromise.
I personally would rather see you leave with option 2. Better connectivity and all around a better starting point, and it will be able to offer Dolby TrueHD or DTS-HD Master Audio.
Honestly speaking its not hard to run speaker wires around the room along the walls, especially in a bedroom.
IGNORE THE SUGGESTION ABOVE!!! It will result in HORRIBLE sound as you will be missing a center channel and that stereo receiver will not know where to send the sound that is meant for center channel speakers which is 75%-80% of audio in surround sound TV shows and Movies. It results in you having to turn up the volume in dialogue scenes and turn it down during action scenes.
Stereo receivers are only good for music
adamw5963 likes this.
crazyrob425 is offline
post #4 of 17 Old 02-11-2014, 03:13 PM - Thread Starter
adamw5963's Avatar
Thanks for the replies. I guess my concern was the receiver. It seemed like all the AVRs had mixed reviews in the price range.
Tony Wilkins 99 likes this.
post #5 of 17 Old 02-11-2014, 03:22 PM
adupree's Avatar
Not true, as long as the playback device that is being used, then it will downmix it.
Ignorance is a choice
adupree is offline
post #6 of 17 Old 02-11-2014, 03:28 PM - Thread Starter
adamw5963's Avatar
What would guys recommend on A4L that's less than $150?
post #7 of 17 Old 02-11-2014, 03:31 PM
zieglj01's Avatar
Quoted: 1568 Post(s)
Liked: 1423
Denon 1513 receiver
http://www.accessories4less.com/make-a-store/item/DENAVR1513/DENON-AVR-1513-5.1ch-Home-Theater-Receiver-3D-ready/1.html
I would get a pair of nice bookshelf speakers for now
Then add more as time goes by
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #8 of 17 Old 02-11-2014, 03:48 PM - Thread Starter
adamw5963's Avatar
Originally Posted by zieglj01 View Post
Denon 1513 receiver
Thanks. How does it compare to the Pioneer VSX-522-K from Newegg?
post #9 of 17 Old 02-11-2014, 04:36 PM - Thread Starter
adamw5963's Avatar
Denon 1513 receiver
Ok 2 more options lol:
Option 1: Pioneer SP BS21 $78-$50 gift card + Dayton 1000 sub $120= $148
Option 2: Pioneer SP FS21 $132 with no sub
post #10 of 17 Old 02-11-2014, 04:41 PM
zieglj01's Avatar
Liked: 1423
The 522 is not looking that good - too many lower star reviews
I would go with option 1 > speaker and subwoofer
Who AM I
post #11 of 17 Old 02-11-2014, 04:43 PM - Thread Starter
adamw5963's Avatar
Thanks. Man picking out a tv is so much easier lol.
post #12 of 17 Old 02-11-2014, 04:52 PM
Chevypower's Avatar
Liked: 40
I'd go with option 2 if that's your max budget. Stay away from soundbars, they over promise and under deliver. My old Sony DAVS-880 I used to have (HTIB) sounded FAR better than a Yamaha YSP-2200 that I bought, tried out, and returned. Let us know if you don't mind spending more, we can point you to better systems that will fit well in a small room, and still perform very good if you move it to a larger room.
Chevypower is offline
post #13 of 17 Old 02-11-2014, 04:54 PM - Thread Starter
adamw5963's Avatar
Yea it's pretty much my max budget unfortunately. I overspent on the TV. I should have budgeted it out better.
post #14 of 17 Old 02-11-2014, 05:08 PM
Chevypower's Avatar
Liked: 40
You mentioned the AJ speakers. I haven't listened to them, but they get rave reviews here so I would consider changing your speaker choice to them. If that means buying only a pair of bookshelf speakers or just one center channel to begin with, you will probably be glad you went this route by the time you are finished. People usually advise to stay away from their subwoofer though.
post #15 of 17 Old 02-11-2014, 05:33 PM - Thread Starter
adamw5963's Avatar
Yea they had the BS21s at walmart for 78 and I have a $gift card there. I didn't know if that was a good deal bc they are the lowest AJ speakers.
post #16 of 17 Old 02-12-2014, 08:48 AM
Quoted: 443 Post(s)
Liked: 337
For the price they are better than your other options listed. And since this is a HT set-up primary go with a subwoofer
post #17 of 17 Old 02-12-2014, 03:17 PM
Chevypower's Avatar
Liked: 40
I didn't mean go without a sub, I meant don't buy the AJ sub. Sorry I should have been clearer on that. The Polk 505 or Bic 12'' seem to be good options for the money.
Reply Speakers
Vizio S4251w B4 5 1 Soundbar , Yamaha Rx V371bl 5 1 Channel Av Receiver , Onkyo Tx 8020 Stereo Receiver , Denon Avr 1513 Receiver
