Klipsch & Rythmik: setup/size/hz? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-15-2014, 07:14 PM - Thread Starter
geoffreygg's Avatar
Hi - okay the rig is online and bada$$.
To assure it's being maximized I'm calling all audio geeks for help!
To what size should I set the RF-7 ii? Small or Large?
To what size should I set the RC-64? Small or Large?
If small for either one what hertz rate?
Hz for RF-7 ii fronts?
Hz for RC-64 ii?
Hz for Rythmik F15HP?
Thx
TV: Aquos Sharp 65"
PrePro: Marantz AV7701
Amp: Marantz MM7055
BDP: Marantz UD7007
Fronts: Klipsch RF-7 ii
Center: Klipsch RC-64 ii
Cables: Zu Mission, Kimber PBJ
Sub: Rythmik F15HP
Streamer: Apple TV / iPad
SAT: DirecTV Geni
geoffreygg is offline
post #2 of 2 Old 02-15-2014, 07:30 PM
Jack D Ripper's Avatar
Liked: 269
For the receiver settings:
You should set every speaker to "small" that is not as capable with deep bass as the subwoofer.  In most cases, this means all channels should be set to "small."  The crossover for each channel should be above the -3 dB point of the bass of the speakers hooked up.  Thus, with a speaker rated 60-20kHz +/-3 dB, the crossover should be set above 60 Hz.  In such a case, 80 Hz would probably be a good choice.
With a receiver or processor that cannot set the crossover differently for the different channels, it should be set above the -3 dB of all of the speakers that are hooked up.
For the settings on the subwoofer itself:
If the receiver has a crossover (and all modern surround receivers do), you should bypass the crossover on the subwoofer if possible.  If not possible, then set it to its highest crossover setting.  The reason for this is because you are using the crossover in the receiver, and do not want the crossover in the subwoofer to interfere with the crossover slope.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
Reply Speakers
Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Fv15hp Subwoofer
taboola here
