Home Theater with RF-7 and RF-7 II - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 02-17-2014, 06:50 AM - Thread Starter
evanderburg's Avatar
I am currently using the Klipsch RF-7 for my front right and left in my 9.1 setup and I am purchasing a single RF-7 II for my center channel. I understand that the crossovers were changed between the RF-7 and RF-7 II so I was wondering what you suggest I do to integrate the RF-7 II into my setup.
- Eric Vanderburg
evanderburg is offline
post #2 of 16 Old 02-17-2014, 07:08 AM
commsysman's Avatar
Quoted: 765 Post(s)
Liked: 462
Sounds like a question you should be asking Klipsch Technical Support.
commsysman is offline
post #3 of 16 Old 02-17-2014, 07:42 AM - Thread Starter
I can try that. Thanks.
- Eric Vanderburg
post #4 of 16 Old 02-17-2014, 08:42 AM
FOH
FOH's Avatar
Quoted: 37 Post(s)
Liked: 231
your welcome to contact them, however I see little need. Do you have some type of auto Eq functionality within your receiver or preamp processor? If so it will make any necessary adjustments in either the frequency or time domain, you'll be fine.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #5 of 16 Old 02-17-2014, 10:02 AM - Thread Starter
Yes. I am using a Yamaha RX-A2020 and it has autocalibration. This is connected to two Rotel THX power amplifiers. One controls the FL, FR, C, HR, and HL while the other controls RR, RL, SR and SL. However, I am not bi-amping the speakers.
- Eric Vanderburg
post #6 of 16 Old 02-17-2014, 01:44 PM
FOH
FOH's Avatar
Quoted: 37 Post(s)
Liked: 231
Cool
I've not used, nor am I the least bit familiar with Yamaha's YPAO auto EQ/alignment. But, no matter, it should take care of any changes needed in FR or time alignment.
Good luck
FOH is offline
post #7 of 16 Old 02-17-2014, 04:03 PM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
Is there no chance of getting a used RF-7? I would do that or a RC-7. If your set on the RF-7ii as a center then i would sell the the RF-7 and get 3 RF-7ii.
But i think your best value here would be a used RF-7. Even a pair used will run around what a new rf-7ii would cost. Then you can sell the other one pretty easy i think.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #8 of 16 Old 02-17-2014, 06:57 PM - Thread Starter
I am on a pretty tight budget. I bought the two RF-7s used a few years ago and I just bought the RF-7 II used somewhere else so that's what I have to work with.
- Eric Vanderburg
post #9 of 16 Old 02-18-2014, 11:46 AM
FOH
FOH's Avatar
Quoted: 37 Post(s)
Liked: 231
IMO, you're fine, you did good.
FOH is offline
post #10 of 16 Old 04-04-2014, 09:23 AM
davemaribel's Avatar
I have a very similar set up to yours except I have SVS PB-1300 Ultra. I am very pleased. It is also where do stop. LOL enjoy you awesome setup. Remember only the dog or a meter can differentiate the dif. Our 2020' do an awesome job of improving audio / picture quality as well as the power filters. Again enjoy you have a great set up
davemaribel is offline
post #11 of 16 Old 04-04-2014, 03:38 PM
Zen Traveler's Avatar
Quoted: 482 Post(s)
Liked: 507
I also think you did good and report back how it sounds because I've wondered how the two generations would match. The Original RF-7s are EXCELLENT speakers and I can't imagine the RF-7IIs are an "upgrade," but if they didn't have a similar sonic signature Klipsch wouldn't have kept the "RF-7" in the name.
Zen Traveler is online now
post #12 of 16 Old 04-04-2014, 03:46 PM
Quoted: 482 Post(s)
Liked: 507
Do you have mix-n-match Klipsch RF-7s up front? I gather what you are referring to above is the SVS PB 13 ultra subwoofer and not speakers, but I could be wrong.
post #13 of 16 Old 04-04-2014, 11:49 PM
Klipisch rf-5.
Rc-62II
Rears are morel sun spots ad
And take a beating still sound great
Yes SVS PB 13 ultra just one
Room is 40 feet by 18feet
Ceiling is 20 high
20 feet of wall is glass
Room open to all granite and travertine kitchen approx 20 by 20 feet also a great deal of plate glass
65 inch Panasonic VT50
Looks and sounds great and have yet to have professional calibration which I anticipate will provide even more improvement overall
Our receivers and speaker/ sub equal or exceed thx. The manufacturer has has pay Lucas at large sum to have that cert., I rather they invest in equipment. And give a great product and price
post #14 of 16 Old 04-05-2014, 06:37 AM
Quoted: 482 Post(s)
Liked: 507
The RF-5s are nice speakers but saying they and your AVR "exceed thx' really isn't true...That said, your speakers may be better than some THX certified models. Also keep in mind there are several THX designations.
post #15 of 16 Old 04-05-2014, 11:00 AM
agreed. There are quite few receivers and speakers new ones that do not use Lucas Thx cert that are fantastic. I would name some but only have access to my phone for now. I do think that what you have is fantastic. One must go by what their ears tell them, hard to do when not in your own space. I do not think human ears can tell the diff between l/r rf7 and rc7II. They are close and have different functions.
post #16 of 16 Old 04-05-2014, 11:24 AM
Quoted: 482 Post(s)
Liked: 507
... I do not think human ears can tell the diff between l/r rf7 and rc7II. They are close and have different functions.
For the record, I have the RC-7 (no such thing as an RC-7II) Center channel and the op wants to put the newer RF-7II in between 2 original RF-7s and that would give him 3 tower speakers up front...
Reply Speakers
Klipsch Rf7black Classic Tower Speaker Black , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Yamaha Rx A2020 9 2 Channel Network Aventage Av Receiver
taboola here
