Ascend Sierra-2 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 61Likes
post #91 of 399 Old 03-18-2014, 10:09 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
Originally Posted by NAIM101 View Post
What the hell are you talking about. AB SWITCH bwteen speakers you can tell right away the difference.
Come think of it, you shouldnt spend more than 5 minutes on a speaker when you are AB switching. You get used to the sound of the speaker playing.
SO KEEP IT LESS THAN 5 minutes when AB switching per speaker. Ofcourse, play the same track etc.
Like I said....
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #92 of 399 Old 03-18-2014, 11:50 PM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
GIEGAR is online now
post #93 of 399 Old 03-19-2014, 03:56 AM
choirbass's Avatar
Well, not much to add to this thread; it is about the Sierra-2's tho, so what little I could add, I hope helps opinions somewhat lol smile.gif (be warned, it is a pretty short more expectedly biased review of them tongue.gif)
http://forum.ascendacoustics.com/showthread.php?5628-Sierra-2-s-Arrived!-D
choirbass is offline
post #94 of 399 Old 03-19-2014, 02:26 PM
newtophoto's Avatar
Looking to pick a set of these up. Which would you recommend for the center? The 2 or the Horizon?
newtophoto is offline
post #95 of 399 Old 03-19-2014, 03:14 PM
choirbass's Avatar
post #96 of 399 Old 03-19-2014, 08:54 PM
smurraybhm's Avatar
Quoted: 1469 Post(s)
Liked: 1760
Another Sierra is more than capable and many use 3 across the front. Full disclosure I have an Horizon with RAAL on order to use with my 2s. I may add two more later, but the 2s are so darn good I may not. I have no doubt you will be happy either way. Coming up on 3 months since I placed my order - the wait is killing me and a little frustrating to be honest. My Sierra 1 center has been doing a good job of filling in while I wait.
choirbass likes this.
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is offline
post #97 of 399 Old 03-20-2014, 05:55 PM
Trace79's Avatar
Liked: 29
What are people using for surrounds with the Sierra 2's? The only way I can squeeze these in my budget in a 5.1 system is if I get $500 (MAX - less is preffered) surrounds that aren't rear-ported, and hopefully not too big either. I emailed Ascend Acoustic yesterday about what they suggest so am waiting on their response. Would still like to see what others are using though. I plan on listening to some multi-channel music so I'd like the timbre to match.
Trace79 is offline
post #98 of 399 Old 03-20-2014, 06:08 PM
choirbass's Avatar
HTM-200 SE's as surrounds should work nicely. ~$330 sans tax. They do fit your description of requirements, and are timbre matched as well. The S-2's as front L&R work perfectly as a phantom center; imaging is spot on. Buying a center would put you over $500, if you go more than the HTM-200 SE's
post #99 of 399 Old 03-20-2014, 06:17 PM
Trace79's Avatar
Liked: 29
Appreciate the reply. Question though; aren't the 200's more so matched to the 340-SE's? How can they be so universal...especially with the RAAL tweeter?
Trace79 is offline
post #100 of 399 Old 03-20-2014, 06:33 PM
choirbass's Avatar
RAAL is certainly ideal, no doubt. But for $500, you do have the option of a S-2 phantom center, since imaging is no problem. As far as how timbre matching is done? I really wouldn't know, I'm sorry.
But, before purchasing any surrounds, I would give a phantom center a try.
Personally, I was never disappointed with any of the surrounds, I just moved to 2 ch stereo for multiple reasons, as you can probably see.. Less room than before, ext 2 ch DAC, the above reasons, and then some :P
post #101 of 399 Old 03-20-2014, 07:49 PM
newtophoto's Avatar
How does one set up a phantom center? I've only just heard of this. Do you just disable the center speaker?
post #102 of 399 Old 03-20-2014, 07:51 PM
choirbass's Avatar
yep.
post #103 of 399 Old 03-20-2014, 09:40 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
basically you will get center vocals with stereo set-up. (left/right) with speakers that have good imaging etc. So you don't really need a center channel.
NAIM101 is offline
post #104 of 399 Old 03-21-2014, 08:38 AM
JasonT35's Avatar
Quoted: 48 Post(s)
Liked: 54
I have a pair of S2s and don't use a center channel and it works great. Not missing anything
JasonT35 is offline
post #105 of 399 Old 03-21-2014, 03:00 PM
Jahjd2000's Avatar
Quoted: 48 Post(s)
Liked: 79
I believe the phantom center debate hinges on the listener's HT/Music preferences. For my listening preferences I couldn't go without center. Does the phantom center sound great on my Ascend Towers when listening to music? It absolutely does. But for HT, I run my Horizon a few dbs hot to improve dialog intelligibility. Having that flexibility is key for me.
Dolby Atmos 5.1.4
Denon x6200
Ascend Acoustics Towers and Horizon Center (NrT)
RSL 34CE in-ceilings (4)
Rythmik E15HP
Jahjd2000 is offline
post #106 of 399 Old 03-21-2014, 03:51 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Phantom center works great, but when you start moving away from the center listening position, the less well it works.....with any speaker.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #107 of 399 Old 03-22-2014, 11:33 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Remember to toe in speakers slightly for better imaging. And get them away from side walls for better soundstagr and imaging.
NAIM101 is offline
post #108 of 399 Old 03-24-2014, 09:56 PM
Trace79's Avatar
Liked: 29
Dave emailed me back. He said the 170 are what he uses as surrounds for his L/C/R S2's in his demo room. He said just having the RAAL up front with 170's in the back will sound will sound better than a dome tweeter with matching timbre all around.
I think I'm going to have to try the S2's out. Looks like the HTM-200 uses the same tweeter as the 170 so it shouldn't be that much of a difference in sound.
Wondering if anyone went from a phantom center to a S2 center and can comment on how it sounds. Can anyone with all three up front do a test on turning off the center when listening to movies and report a comparison?
Trace79 is offline
post #109 of 399 Old 03-25-2014, 02:16 PM
choirbass's Avatar
Acoustic measurement comparisons will show the similarities between all of their monitors (It's essentially your eyes hearing the difference, if that makes much sense):
http://ascendacoustics.com/pages/products/speakers/SRM2/srm2meas.html
http://ascendacoustics.com/pages/products/speakers/cbm170/cbm170meas.html
http://ascendacoustics.com/pages/products/speakers/htm200/htm200meas.html
They honestly are 'just close enough', to where each doesn't sound unlike the other. Cumulative Spectral Decay images are pretty awesome, IMO (frequency linearity, dB volume, time duration, and residual energy decay, all in one). Ribbon's have close to zero decay, and a near linear spectrum at just about all volume levels, contrary to domes. It is also a reason they will sound different, as well as more accurate. However, accuracy and preference don't 'always' go hand in hand; it is worth adjusting to nonetheless, if you haven't already. Basically, you'll begin to recognize more flaws than you know are there. The flip side of which, is discovering all of the positive's that have been hidden away. These are the consequences and benefits of hearing realism; they are Real.
You had asked before, but my mind drew more of a blank.
cschang likes this.
post #110 of 399 Old 04-01-2014, 04:43 PM
Chatoboy's Avatar
Quoted: 18 Post(s)
Any new news about the Sierra 2? Did Geocab decide between these or the Philly's? Enquiring minds want to know:)
Receiver: Denon AVR-X4200W
Front LRC: Ascend Sierra 2
Surround: Axiom Qs8
Sub: Rythmik F15hp
TV: Samsung UN65KS8500
Source: PS4 Pro, Direct TV
Chatoboy is offline
post #111 of 399 Old 04-01-2014, 04:46 PM
Billy p's Avatar
Quoted: 300 Post(s)
Liked: 662
He started a dedicated thread as well...
http://www.avsforum.com/t/1518268/dialogue-too-quiet-tv-speakers-looking-to-add-5-1-or-other-solution/90#post_24549788
Ascend Acoustics Towers: STC w RAAL, 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo BDP-103D,
Apple TV+ Giga 1800
Sub FA 18: (Santos RW)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is offline
post #112 of 399 Old 04-01-2014, 08:49 PM
geocab's Avatar
Quoted: 51 Post(s)
Liked: 59
S2's are the main choice, but I liked the Phils too and decided to keep them for my second zone.
Billy p likes this.
geocab is offline
post #113 of 399 Old 04-02-2014, 01:54 AM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
I run 3 S2s up front, I ran it in stereo which cuts out the center and it sounds really good, I had to keep putting my ear to the center to make sure it wasn't turned on. Even at low volumes at -40 on the avr its very clear and dialog is easy to hear, I had it at -60 on the avr too and it's still very easy to hear the dialog. So even at extremely low volumes having no center sounds really good over the S2s. After a few minutes I forgot I turned off the center... So it does sound really good but when I turn the center back on it sounds better, clearer... I'd recommend going with all 3 up front but just the LR isn't lacking, sounds really good but when you turn the center back on the things that should be in the center are more clear. I have the HTM-200 as my rears and they work great with the S2 but after my sub upgrade getting the S2s as my rears will be the next thing. I notice your post is over a week old.. Woulda answered sooner but I spend my time in the sub part as for speakers with the S2 I have no need to be in the speaker part anymore cause these things are really that awesome and are much better than I thought they'd be, I just don't have any desire to buy another speaker not named the Sierra-2, I love the smaller size but they don't sound small you'd swear they were big speakers, so if I buy another speaker it'll be the S2 again but in different finish to try out.
tdogroeder and choirbass like this.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
JustABrah is offline
post #114 of 399 Old 04-02-2014, 08:24 AM
neveralone777's Avatar
Quoted: 42 Post(s)
I have 2 Sierra 2's up front with no center. It sounds great as long as you aren't too far on each side it produces the center very well. However there are times I know it's a little off and do plan on buying another S2 for the center. I do want to get another but I don't feel that it's an urgent upgrade. I also need a sub and surrounds and since the phantom center is working just fine I feel that these will enhance my experience much more and these are all I can afford for now. Early 2015 I will purchase the center.
neveralone777 is offline
post #115 of 399 Old 09-30-2014, 01:39 PM
Wolfy701's Avatar
Quoted: 67 Post(s)
Liked: 31
Heard "Ascend" speakers for first time today. Are they good for Classical music/opera?... That's 99% of my listening. I don't want any artificial highs or exaggerated bass. my audiophile benchmarks are the major concert halls & opera houses in LA, SF, NY.
Source: Thinkpad running iTunes/JRMC upsampling to 24/192
DAC/SACD: Oppo 105D
Head-amp: Pathos Aurium
AVR: Yamaha Aventage RX-A3010
Headphone: AKG K812 Pro, K553, Sennheiser HD600
Wolfy701 is offline
post #116 of 399 Old 09-30-2014, 01:47 PM
Cvetan1's Avatar
Quoted: 35 Post(s)
Liked: 50
They will play well with any music you throw at them. They measure great and flat, check out their website.
Cvetan1 is offline
post #117 of 399 Old 09-30-2014, 01:53 PM
Wolfy701's Avatar
Quoted: 67 Post(s)
Liked: 31
I notice the highly-rated Monitor Audio BX-2 has comparable specs -- 42Hz-30kHz frequency response, 100w at 8ohms, but retails for $500 ($250 ebay).
DAC/SACD: Oppo 105D
Wolfy701 is offline
post #118 of 399 Old 09-30-2014, 04:25 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
You can't go on specs alone.
For one, they're often exaggerated.
Two, even if they were entirely honest, they may be measured with different equipment, different measurement techniques, etc, which will lead to different results.
And, three, the limited information given in such specs is not nearly enough to tell you about how a speaker sounds. It's like giving the length, width, height, weight and engine horsepower of a car and thinking that's enough to know exactly what the car will look like and how it will ride.
As for comparing with the BX-2, the BX-2 is a decent budget speaker, but the Sierra 1 or 2 will trounce it in every way. The Sierra 1 trounces the Monitor Audio Silver RX-1, so the Sierra 2 certainly trounces the lower-model BX-2.
Avliner likes this.
beaveav is offline
post #119 of 399 Old 09-30-2014, 05:19 PM
natetg57's Avatar
The Sierra's also measure very well in the time domain. Because of the lightweight materials in the cone and tweeter combined with powerful magnets, the sound starts and stops extremely quickly. The opposite of muddy or bloated.
natetg57 is offline
post #120 of 399 Old 10-01-2014, 07:15 AM
cranster's Avatar
Quoted: 155 Post(s)
Liked: 89
I have 3 2's across the front, and love these speakers. I was considering getting the towers, or 3horizons across the front, but these speakers with the lv12r sound so good, I really don't see the need to move to anything else.
cranster is offline
Reply Speakers
