Cross-Over Settings - AVS Forum | Home Theater Discussions And Reviews
Old 02-20-2014, 03:42 PM - Thread Starter
Cocahoe's Avatar
My system consists of an Onkyo TX-Sr604, Polk Monitors 60s for mains, Polk CS1 center, and Polk OWM3s for surround. Just received my BIC PL-200. My Onkyo will not allow you to set the speakers to large or small, you have to set a cross-over for each speaker. I set the sub at 80. Need advice on what to set cross-over for remaining speakers. Any help would be great. Thanks, Jim
Cocahoe is offline
Old 02-20-2014, 03:51 PM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
Setting all speakers to 80 is a good starting point.
However, when you run the Audyssey calibration it should set them for you. You should run Audyssey whenever you change your speakers, including after adding a subwoofer. See page 38 of the 604's owner's manual.
Selden
Selden Ball is online now
Old 02-20-2014, 04:35 PM - Thread Starter
Cocahoe's Avatar
I do not have the Audyssey microphone. Looking for suggestions?? Should sub be the same as all of the speakers???
Cocahoe is offline
Old 02-20-2014, 04:56 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
There isn't a crossover setting for the subwoofer. That setting is the LPF of LFE setting and it should be set at 120hz. That's also what Audssey recommends. If you set it any lower you're throwing out information from the LFE channel that wont be recovered. Audyssey does not set the speaker crossovers. The receiver does. The setting that the auto calibration selects isn't always the best crossover setting. 80hz is the most commonly used crossover. It's a steep 4th order crossover and it gives a dynamic sound as long as you have a properly placed capable subwoofer. It also takes a load off of the amplifiers in your AVR.
Secret Squirrel is offline
Old 02-20-2014, 08:10 PM
Bill Fitzmaurice's Avatar
Liked: 4630
Originally Posted by Secret Squirrel View Post
That setting is the LPF of LFE setting and it should be set at 120hz. That's also what Audssey recommends. If you set it any lower you're throwing out information from the LFE channel that wont be recovered. .
That's seldom actually the case. The LFE bandwidth is specified to run no higher than 120Hz. In practice there tends to be little actual LFE channel information above 80Hz.
It's quite common for the best results to be had if the sub low pass filter is set lower than 120Hz, though never lower than the AVR crossover frequency. If you can directionally locate the sub turn the low pass filter frequency down gradually until you can't. When it sounds right it is right.
Bill Fitzmaurice is online now
Old 02-21-2014, 05:25 AM
Liked: 1494
The LFE low pass filter affects only the incoming LFE audio channel. If it affects the low bass-managed frequencies which are being redirected from the other speaker channels, then your receiver (or pre/pro) has a defective design. (Such things have been known to happen.) If bass management is enabled (some or all of your speakers are set to "Small") turning the LFE LPF down will only partially affect how localizable your subwoofer is. That's primarily affected by how low the crossover frequencies are for your bass-managed speakers.
80 Hz is the recommended crossover frequency because frequencies that low are hard to localize. However, the audio filters used are not "brick walls", so some higher frequencies are sent to the subwoofer, and with very careful listening you probably can determine where the subwoofer is located. Of course, if any of your speakers require higher crossover frequencies, it's that much easier. However, being able to determine from careful listening where your subwoofer is located generally is considered to be less of a problem than the distortions which arise when you try to drive speakers to higher volume levels than they're designed to handle at those low frequencies.
Selden
Old 02-21-2014, 05:42 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
I have all my speakers set to small 70hz, even the sub. I don't like 120hz for the sub crossover it's too high. Won't that 70hz+ from the LFE channel be re-directed to the mains then? Lexicon pre
fatbottom is offline
Old 02-21-2014, 07:32 AM
Liked: 4630
All of the LFE goes to the sub, no matter what the AVR crossover is set at. if you have the sub low pass filter also set at 70Hz you'll lose some of the LFE content, but not much. With a 70Hz setting in the AVR you probably don't have to run the sub low pass at 70Hz to eliminate all directional content, 100Hz would probably be sufficient. I'd try taking that up in 5Hz steps, and if you do reach a point where you can locate it drop it back down a bit from there.
Old 02-21-2014, 07:59 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Set the Monitor 60s to 60hz, CS1 to 80hz, and OWM3 to 100hz
and the subwoofer LPF to 120hz
crazyrob425 is offline
Old 02-21-2014, 12:55 PM - Thread Starter
Cocahoe's Avatar
CrazyRob where did you get your info. Do you have the same setup as I do??
Cocahoe is offline
Old 02-21-2014, 07:45 PM
Quoted: 443 Post(s)
Liked: 337
No I don't but I have heard a similar setup with those settings
I got those numbers by the speaker specs.
Monitor 60's are 48hz-24k hz (-3db) so 60hz works
CS1 is 65hz-24k hz (-3db) so 80hz works
OWM3's is 100hz-24k hz (-3db) so 100hz works
Old 02-21-2014, 07:53 PM
Liked: 4630
Specs don't say when the drivers will run out of excursion, causing distortion. If the speakers distort at high volume that may be cured with a higher crossover. One just has to be sure the distortion is sourced in the midbasses, not the tweeters. If the tweeters distort you must turn it down or risk damaging them.
Old 02-23-2014, 02:44 PM - Thread Starter
Cocahoe's Avatar
I thank everybody for their responses. I am still somewhat new to all of this. What am i listening for when I make these cross-over settings?? Do I leave the BIC PL-200 at 80?? Thanks again.
Cocahoe is offline
Old 02-24-2014, 11:48 AM
Quoted: 443 Post(s)
Liked: 337
You referring to the knob on the back of the subwoofer or the setting on receiver ? If the knob on the back of the subwoofer turn that to max but at least higher than 120hz. The receiver's only settings for the subwoofer is Yes or No. if the manual is to believe
Old 02-24-2014, 02:40 PM - Thread Starter
Cocahoe's Avatar
My question is When I make the cross-over settings on all of the speakers including the sub how do I know they are correct?? Are these just suggestions and there is no right or wrong? Is it personnel preference?? Thanks
Cocahoe is offline
Old 02-24-2014, 02:43 PM
fatbottom's Avatar
Liked: 518
Look in your manuals for speakers. Look at the frequency response, and set your amp crossover no lower than that the low bass response.
crazyrob425 likes this.
Old 02-24-2014, 02:47 PM
Quoted: 443 Post(s)
Liked: 337
First off your receiver has no crossover setting or low pass filter settings for the subwoofer. You are best to just cranking the knob on the back of the subwoofer.
A lot of crossover settings have to do with your personal preference and you can pick what sounds best to you. If you want to get scientific you will need a sound level meter and a test tone CD. But its more hassle than worth it. What did Audyssey set your speakers crossovers at?
The Monitor 60's can be set from 60hz-80hz, whatever sounds best to you
The CS1 performs best at 80hz and most people would agree
The OWM3's will work with a 100hz
Using the settings I recommended will work for your setup.
Have your run Audyssey 2EQ? What were the settings it used for your speakers?
Old 02-24-2014, 02:48 PM
Kal Rubinson's Avatar
Quoted: 674 Post(s)
Liked: 460
Unless you are very experienced, you cannot do this by ear.  Suggestions from others are not relevant since your particular room and the speaker positions are unique.
Get the microphone and run Audyssey.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 02-24-2014, 03:00 PM
fatbottom's Avatar
Liked: 518
Generally the auto crossover picks the wrong one, I guess it picks up the room gain, thinking it's the speakers natural response but it's not. What should happen is you set crossovers before, so the calibration procedure know what the actual response is.
Old 02-24-2014, 03:27 PM
Liked: 4630
The purpose of the crossover frequency is two-fold. On the one hand it needs to be as low as the mains will allow, so that there's no directional content from the sub. OTOH the lower the mains are run the less headroom there is, for both the main speakers and the AVR amps, as both excursion and power demands on the mains and power demand on the AVR amps go up as frequency goes down. So the bottom line is yes, personal preference has a lot to do with it, that having to do with how loud you run your system. The louder you want to run it the higher the crossover must be, but that comes at the expense of getting the best overall sound. I already explained to you what you should be doing with the low pass setting on the sub amp.
Old 02-24-2014, 04:16 PM
Quoted: 674 Post(s)
Liked: 460
1.  Generally the auto crossover picks the wrong one, I guess it picks up the room gain, thinking it's the speakers natural response but it's not.
2.  What should happen is you set crossovers before, so the calibration procedure know what the actual response is.
1.  That is possible but not assured and, besides, it is usually due to the AVR manufacturer's decisions.  Using Audyssey, he will also get the correct delays, levels and EQ.
2.  That is impossible.  Audyssey ignores/resets all such settings made prior to the calibration procedure.
Kal Rubinson
Old 02-24-2014, 04:22 PM - Thread Starter
Cocahoe's Avatar
Thanks again guys. Just want it to sound as good as it can.
Cocahoe is offline
Old 02-24-2014, 07:41 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
So that you can see, and hear the differences, you could set everything manually first, then listen to one of your reference albums...something you know very well. Then do the auto set up. You'll see where the numbers are (if they changed), and then do some more listening to the same album.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
Old 02-24-2014, 07:45 PM
MarsianMan's Avatar
Liked: 33
A lot of crossover settings have to do with your personal preference and you can pick what sounds best to you. If you want to get scientific you will need a sound level meter and a test tone CD. But its more hassle than worth it. [...]
Worth is pretty subjective. It costs money and time but I don't think I've wasted anything doing it. It's certainly helping me to learn more about how audio works in a room. The OP may agree with you or not, but hard to know without being them.
If you really want to know the best crossover setting you should get a SPL meter or calibrated microphone and measure your frequency response with something like REW. They have calibration files for Radio Shack SPL meters. I am not sure how accurate they are but the box says +- 2 db.
From my measurements (my speakers go down similarly to the 40s) my best measurement was at 60 Hz crossover. It didn't really change the bass but it did help flatten out the high end response for my mains a bit.
MarsianMan is offline
Onkyo Tx Sr604 7 1 Channel A V Receiver Black , Polk Audio Am6095 B Monitor60 Series Ii Floorstanding Loudspeaker Black Each , Polk Audio Monitor Series Cs1 Center Channel Speaker Single Black , Polk Audio Owm3 On Wall Speaker Pair White
