Blown 4-ohm Midrange. Replace with 8-ohm OK? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-22-2014, 09:07 AM - Thread Starter
xboxmember1978's Avatar
I have a blown midrange and the back of it says 4-ohm, I have a nice brand new pair that are the same size but say they are 8-ohm. Will this be OK? What issue might I have? I don't want to mess up the cabinet crossover
xboxmember1978 is offline
post #2 of 8 Old 02-22-2014, 09:26 AM
Jack D Ripper's Avatar
Liked: 272
You should look for an identical driver to the original.  Otherwise, it will not be right.  The crossover was designed for the original driver, not for anything else.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
post #3 of 8 Old 02-22-2014, 09:41 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
No, it won't be OK. It will cause your midrange to disappear. You might be able to make up the difference with an active bimaplification system but that would cost more than simply getting the right drivers in the first place.
FMW is offline
post #4 of 8 Old 02-22-2014, 09:59 AM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
The level will be different-the crossover freq will be different and unless the driver is the same model just a different impedance the response will likely be different.
sure you can replace it and it will make sound-but nothing like the original.
It depends on whether this is important to you-or you just want to make noise
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #5 of 8 Old 02-22-2014, 12:05 PM - Thread Starter
The thing is that I don't know the specs on the blown midrange, I can't find the info anywhere on the net, the model is Cerwin Vega VE-15F
post #6 of 8 Old 02-22-2014, 02:21 PM
FMW
FMW's Avatar
Liked: 1686
You need to contact the manufacturer and order replacement parts.
FMW is offline
post #7 of 8 Old 02-22-2014, 02:31 PM
East Glenn's Avatar
That's all you need to know. As FMW suggests, contact CV and get the right part.
East Glenn is offline
post #8 of 8 Old 02-22-2014, 02:58 PM
Liked: 272
Actually, it is possible that he will need to give them the serial number as well, because sometimes manufacturers make changes in productions without changing the model number.  But they will tell him that if it matters in his case.
Reply Speakers
