B&W M1 vs. Anthony Gallo Micro... which for rear? which for 2nd zone? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 02-24-2014, 01:33 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
I am in-between picking the B&W M1 and Anthony Gallo Micro speakers for my new setup. Not sure which would do a better job.
#1 Pair: Rear speakers, matching B&W 805S, B&W XTC Center, B&W PV1 sub, connected to Pioneer Elite SC-67 (or 77 - buying either this week)
#2 Pair: Dining room speakers, feed from receiver in the other room
#3 Pair: Bedroom/office speakers, feed from PC/iPod/iPad for background music
Now, which of the two speakers fit best for each usage? The Anthony Gallo Micro look very nice and fit quite well into my living room for the rear speakers, but I am afraid if they have enough low-end. The specs on both are similar, and I have auditioned both but not together, so hard to compare.
Any ideas?
Pioneer Elite SC-67, B&W 805S/XTC/M1/PV1, Pioneer Elite Kuro 111FD, Elite BDP-05FD
alexb76 is offline
post #2 of 21 Old 02-27-2014, 09:40 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
Any advise on these?
alexb76 is offline
post #3 of 21 Old 02-27-2014, 09:58 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
If you want some type of bass response - then go with the M1
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 21 Old 02-27-2014, 10:23 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+1 ^^^^
Though IMHO both of the speakers would be a bad fit for Zone 2 use (in your case the dining room and bedroom). They are satellite speakers designed to be used with a sub to not only cover the low end, but even help out with the mid-range. Can you go with a small bookshelf speaker for the Zone 2 uses? (There are options that will give you much better Zone 2 sound for less money.)
sdg4vfx is offline
post #5 of 21 Old 02-27-2014, 10:36 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
Originally Posted by sdg4vfx View Post
+1 ^^^^
Zone 2 options are limited to wall mounting, and I only have a small wooden bracket of 5.5" covering the blinds on the window to mount these. I think for sure in Zone 2, M1 would be a better choice, or, this is another option:
Focal Dome: http://www.focal.com/en/dome/163-dôme-satellite-3544052690132.html
alexb76 is offline
post #6 of 21 Old 02-27-2014, 11:01 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Gotcha. Maybe have a look at these - both are sealed and designed to be wall mounted.
Ascend Acoustics HTM-200 SE http://www.ascendacoustics.com/pages/products/speakers/htm200/htm200.html
NHT Absolute Wall Speaker Black (and White) http://www.nhthifi.com/Home-Theater-Absolute-On-Wall-Speaker-Black?sc=12&category=3772
For the Zone 2 use either of these would give a fuller, more pleasing sound than any satellites speaker. (I also know folks who have painted them the same color as their walls.)
(BTW, I think the Focal Dome is an excellent satellite speaker. But still a satellite and dependent on bass/low-mid help.)
sdg4vfx is offline
post #7 of 21 Old 02-27-2014, 11:23 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
Thanks man, those look great, but still won't work in the space. Here's where they should be mounted.
LEAD Technologies Inc. V1.01
alexb76 is offline
post #8 of 21 Old 02-27-2014, 11:37 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
Originally Posted by alexb76 View Post
Thanks man, those look great, but still won't work in the space. Here's where they should be mounted. Hence, the smaller satellite speakers... specs of each:
B&W M1:
1x 25mm (1in) aluminium dome high-frequency
1x 100mm (4in) woven glass fibre cone bass / midrange
Frequency range: -6dB at 55Hz and 50kHz
Frequency response: 64Hz - 23kHz ±3dB on reference axis
Sensitivity: 85dB spl (2.83V, 1m)
Crossover: 4KHz
Focal Dome:
4" (10cm) Polyglass mid-bass,
1" (25mm) Al/Mg inverted dome tweeter
Low frequency point (-6dB): 72Hz
Frequency response (±3dB): 80Hz - 28 kHz
Sensitivity: 88dB
Crossover: 2500Hz
Anthony Gallo Micro:
Frequency response: 80Hz to 18Khz
Sensitivity: 89 dB/w
Driver: 3" full range
Anthony Gallo A'Diva:
Frequency response: On wall or stand 76Hz to 20Khz
Frequency response: On isolation ring 88Hz to 20Khz
Sensitivity: 88 dB/w
So, based on this, B&W should go lowest, while Micro has some good spec, although I am not so sure how reliable that is. I most likely set the Sub crossover to 80 Hz, but the sub won't be heard in 2nd Zone much.
alexb76 is offline
post #9 of 21 Old 02-28-2014, 06:36 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Do not get too carried away with reading marketing specs
The Anthony Gallo is fortunate to play around 125 hz
The Focal Dome is limited around 110 hz
Also, it would be a stretch for B&W to hit real low
For your options I prefer B&W or Focal Dome
Who AM I
zieglj01 is offline
post #10 of 21 Old 02-28-2014, 02:08 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Thanks man, those look great, but still won't work in the space. Here's where they should be mounted ...
In that case +1 zieglj01's suggestions (again).
Just out of curiosity - what's the measurement on that ledge?
sdg4vfx is offline
post #11 of 21 Old 03-01-2014, 11:56 AM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
The ledge is only 5" 1/4.
alexb76 is offline
post #12 of 21 Old 03-01-2014, 11:57 AM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
Just under 5.5"
alexb76 is offline
post #13 of 21 Old 03-01-2014, 02:35 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
They're considerably more expensive, but the Galla Strada 2 ("center" version) would fit and offer significantly better sound quality. You might find some of the first gen Strada's used for a good price (I often see them on audiogon and ebay).
sdg4vfx is offline
post #14 of 21 Old 03-02-2014, 08:45 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
I like those but a tad too big.
I'm now between Focal and B&W. Focal looks nicer and is made in France, while B&W has better specs, made in China and $100 cheaper.
Hard to compare sound quality as they're in two separate places and setups.
alexb76 is offline
post #15 of 21 Old 03-18-2014, 05:39 AM
ercreador's Avatar
I have the focal dome 5.1 (in his white version) for a 1 year to now. Before purchase it, I have been tested and compared with the B&W M1 system. They sound more or less close but no one better than other, and they sound great. Then in my opinion the difference come to the manufacture : the french made in aluminum dome vs wherever made in plastic M1, no way to compare... and in addition the look of the focal dome is stunning. In my opinion only  surpassed by the B&O beolab 14 (concerning the looking)
ercreador is offline
post #16 of 21 Old 05-03-2014, 11:25 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
I thought an update is in order. At the end, I did get B&W M1s, and literally right now listening to them! I have B&W 805S for the front, and then use these for rear, as well as 2nd Zone/room. They are absolutely one of the best satellite speakers you can find, have great flexibility for mounting, and are built very good, and they sound much better than the older M1s (my parents have those).
I did a ton of auditions of many speakers and here is what I've found!
  • B&W M1: Great all around sound, best bass amongst smaller speakers I tried. BUT, they need a LOT OF POWER!
  • Focal Dome: Probably slightly better high/mid than M1, but less bass. It was very very hard to pick between these two. Focal is also made in France, comes in really cool shiny colors, it's round shape, and was just a toss-up.
  • Anthony Gallo Mico: Incredible highs and good mid, and if you place it correctly with a sub probably sounds the best. BUT, it literally has no bass, and must have a sub.
  • Monitor Audio Radius 90: GREAT sounding speaker, it lacked a bit of bass vs. the first two and again very close in performance. We just didn't like the look that much.
So, I would recommend ANY of the above, it basically comes down to style, how you need to mount them, price and if you have a good amp/receiver. I think if you are going to have a full satellite system (no larger front), then the MORE important thing is the SUB! Problem with all of these smaller ones is that they don't go low enough, and most subs don't go as high... so you usually get a gap in the 80-150Hz... My B&W 805s do an amazing job on bass, so it literally covers that gap nicely.
alexb76 is offline
post #17 of 21 Old 05-04-2014, 11:28 AM
pmanyon's Avatar
Quoted: 58 Post(s)
Liked: 32
I had the M1's for 5.1, matched with an svs pb-1000, and it was a very good sounding system. The M'1s or any of the speakers mentioned are not for use without a subwoofer. I went to the M'1 from orb audio mod2's which are similar to the gallos, and here is what I noticed.
The M'1's had much better detail in the high frequencies due to the 2-way speaker vs. full range design. Also, the low end of the M1's allowed me to move my receiver's crossover point from 150hz to 100hz. The midrange sounded much better with this setup and there was very little if any localization of the sub. Really, with the orbs, the rears sounded very thin. With the M1's, the sound all around was much fuller. I now have ARX towers for my front soundstage but still use the m1's for my rears. Although for aesthetic reasons I may have to go back to M1's all around, but honestly, this isn't a bad thing. For small speakers you get a great low end that will blend well with a sub. Again, they are not going to blow you away on their own, but you will notice a more fuller sound than competing satellites when paired with a good sub.
pmanyon is offline
post #18 of 21 Old 05-04-2014, 02:37 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
For surrounds I'd lean toward the M1 over the Micro.
You might also check out the Ascend HTM-200 - it is a sealed speaker and designed to be mounted flush on a wall (actually more space efficient than a satellite with a wall mount). It digs deeper than either the M1 or Micro and it will accommodate an 80Hz sub crossover, which is preferable to a higher crossover.
sdg4vfx is offline
post #19 of 21 Old 05-04-2014, 03:53 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
pretty daft the only surround speakers B&W make is the DS3
fatbottom is offline
post #20 of 21 Old 05-04-2014, 09:19 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Probably true. Though the only folks I know with 5.1 B&W Diamond series setups use Diamonds all the way around.
sdg4vfx is offline
post #21 of 21 Old 05-05-2014, 01:00 AM
fatbottom's Avatar
Liked: 518
Many people who are looking into a complete 5.1/7.1 system might overlook those B&W speakers, if I was forking out £15,000 on speakers I'd want matching rear speakers of the design type I prefer for side/surrounds- dipole, bipole and tripole. Then look at another brand. So they'd lose a sale.
Reply Speakers
