Behringer Eurolive B215XL 15" 2-Way as L/R Mains - Page 14 - AVS Forum
post #391 of 414 Old 09-14-2014, 09:30 PM
DavidK442's Avatar
Quoted: 65 Post(s)
Liked: 78
Originally Posted by imagic View Post
That said, I'm sure my Behringers could sound a bit sweeter if I had Pass Labs amps.
DavidK442 is online now
post #392 of 414 Old 09-14-2014, 09:34 PM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Quoted: 1130 Post(s)
Liked: 2278
Originally Posted by DavidK442 View Post
Just sayin', if I had the amps Sandy Gross used to power the triton Ones, there's a chance they'd sound a bit better than they do playing via my Pioneer Elite receiver. Maybe not, but there's good reason to believe those amps outperform what I'm using, if only because the speakers themselves can handle a fair bit more power than my AVR produces. That's about all I was saying, and of course Pass Labs amps are pretty much impeccable. I'm not trying to debate if amps sound much different from each other or not.
Find out more about Mark Henninger at
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
imagic is offline
post #393 of 414 Old 09-15-2014, 02:06 AM
teddytusen's Avatar
Have a few days off this week and are going to try the 212`s with XTZ AP100 (50w class A) instead of my no-name PA-amp. Don`t expect huge differences, but have to try anyhow. Do you guys use toe-in? I prefer generous toe-in with waveguide speakers.
teddytusen is offline
post #394 of 414 Old 09-15-2014, 06:58 AM
Jeff in Canada's Avatar
Quoted: 82 Post(s)
Liked: 41
What is the major difference between the 12's and 15's? Woofer only? Anyone heard both?
I do understand the difference between the 15 and 12" horns.
I posted above about my usage for them but didn't hear anything back. I want to order one or the either but is there a big sound difference between the two? I see the 15" seem to go to 20k vs the 18k for the B12XL Odd.
Equipment: Denon AVR-4520, Fusion Tempest (LCR), Fusion Alchemy (4xSurrounds+Wides+Heights),15" Dayton Ultimax X 4, SMX 2.35:1 Screen
Jeff in Canada is offline
post #395 of 414 Old 09-15-2014, 07:05 AM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Liked: 2278
Larger woofers have narrower dispersion, which is accounted for by the narrower dispersion of the horn on the B215s, as compared to the B212s. I prefer the narrower dispersion of the B215s for use as L/R mains, but for surrounds I'd use B212s. I have not performed a direct A/B comparison between the two. However, I have considered adding a pair of 212s as my surrounds. If I do, I'll compare the two, for sure.
imagic is offline
post #396 of 414 Old 09-15-2014, 11:15 PM
tyee's Avatar
Quoted: 17 Post(s)
Well I got them today from my DJ guy. Played them quite loud this afternoon without realizing how loud they were. I guess the low distortion can cause that. Played with them tonight for a couple of hours too. They are very dynamic compared to my supposedly audiophile like speakers. I've never used horns before so it's quite a difference. I don't expect any of the audiophile qualities of floating instruments between the speakers with horns and I don't think I got that. They were only about 6 ft. apart in my listening area so if I move them wider it would probably be better. I'm still testing, running through all my test CDs. I wanted to get a Yorkville PS12P to compare it but that will have to wait for next week. Haven't played a movie yet, only music. I'm not sure on the 15" vs the 12". 12" might be better for voice but I don't have that one around to compare. Either way looks like I will purchase this type of speaker, it's just which make and model will suit my tastes. I heard the 1099's in July and a few others too, but that was in a different environment. Also heard the 1099's in the exact spot where these B215XLs are currently. I prefer the 1099's from what I remember. It's hard to say what they had that I preferred. I guess the multi drivers helped with instrument separation and soundstage. Anyway my search goes on.
Tried playing with the toe in and that makes quite a difference too. Crossed just in front of the listening position sounds very good. I wish I could move them further apart and see how the stage gets bigger.
tyee is offline
post #397 of 414 Old 09-17-2014, 12:52 AM
Peen's Avatar
Has anyone thought about trying something else in the line, like the B2520 Pro?
Peen is offline
post #398 of 414 Old 09-17-2014, 09:12 AM
DocOrange88's Avatar
Quoted: 26 Post(s)
Liked: 24
They are not the same speaker, this is discussed earlier in the thread. Design, components and other elements are different so it can't really be compared.
DocOrange88 is offline
post #399 of 414 Old 09-17-2014, 02:18 PM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Liked: 2278
I've opened 'em ep. Pics coming soon. Also, I'm going rogue with my B215s. I'll post an update shortly.
DocOrange88 likes this.
imagic is offline
post #400 of 414 Old 09-17-2014, 03:23 PM
Quoted: 26 Post(s)
Liked: 24
Going rogue aye? Building your own enclosures for them?
post #401 of 414 Old 09-17-2014, 03:35 PM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Liked: 2278
I'm actually going open baffle... but yeah. The backs are already off, and I'm listening to them right now.
Peter Lyngdorf and the Steinway Lyngdorf demo at CEDIA inspired me. Peter does not even remotely care if a driver is flat, he'll let EQ fix that. His speakers were all open baffle 2-ways. I looked at the B215XLs and said OK, the front baffle is one piece, if I take the back off and work the EQ I'll be OK."
Except in reality, I did not need any EQ at all. Instead, all I had to do was cross over the open baffle B215XLs at 100 Hz and call it a day. It sounds so good, I feel guilty about how simple the whole process was. Pics coming soon.
imagic is offline
post #402 of 414 Old 09-18-2014, 05:04 AM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Liked: 2278
Here are the innards of a B215XL
DSC06562 by ImagicDigital, on Flickr
DSC06555 by ImagicDigital, on Flickr
DSC06546 by ImagicDigital, on Flickr
XStanleyX and teddytusen like this.
imagic is offline
post #403 of 414 Old 09-18-2014, 06:51 AM
NicksHitachi's Avatar
Quoted: 95 Post(s)
Liked: 143
If it were mine, I would remove and short circuit that bulb fuse. IDK how much it would matter but its unnecessary for home audio and does nothing positive in that application.
NicksHitachi is offline
post #404 of 414 Old 09-18-2014, 07:06 AM
tuxedocivic's Avatar
Quoted: 316 Post(s)
Liked: 542
For sure. It's there to limit output during big peaks. In other words, cause compression. Short it out.
The magnet looks quite small so I'm guessing a high Q driver. Thus open baffle wouldn't totally kill the bass. There are many technical issues I have with doing that otherwise, but if you're enjoying it, go right ahead.
Thanks for sharing. I've wanted to see the guts of this one for a while.
NicksHitachi likes this.
tuxedocivic is offline
post #405 of 414 Old 09-18-2014, 10:22 AM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Liked: 2278
I'm actually amazed that the compression driver is as well-made as it is. The bulbs are gone already. Open baffle is definitely working for me, my sump basin subs are breaking up the back wave. Without EQ, they measure very favorably compared to having the enclosures on, so there's that.
imagic is offline
post #406 of 414 Old 09-18-2014, 10:50 AM
Quoted: 316 Post(s)
Liked: 542
Ya it looks like a good unit, especially for a budget speaker. And the components in the XO are good too. You should see the Paradigm speaker I have open in my shop right now, the XO is 1 electrolytic cap and 1 iron core inductor and 1 resistor. Total junk.
Open baffle will extend the directivity down below the woofers usually omni frequency. So it makes sense if you're getting less room interaction. And like I mentioned, that woofer is probably a suitable unit for OB. Going OB might not work so well with other speakers.
My concerns would be a dipole peak right around 400 or 500hz. You can't eq those. Most guys go 4way active to avoid them. But they're also hard to hear. The other would be power handling. Excursion will go up quite a bit, even with the higher 100hz XO. And eq will add to that issue if needed. So you win some and you lose some
post #407 of 414 Old 09-18-2014, 12:43 PM
teddytusen's Avatar
How do I short out the fuse...?
post #408 of 414 Old 09-19-2014, 04:29 AM
Quoted: 95 Post(s)
Liked: 143
Assuming it just pulls out, just use a piece of wire to jumper the sockets direct to one another. Just make sure its a solid connection with wire of decent size.
imagic and teddytusen like this.
post #409 of 414 Old 09-19-2014, 06:56 AM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Liked: 2278
There is some sort of soft glue/sealant that presumably keeps the bulb from shaking loose, but it's very easy to remove.
imagic is offline
post #410 of 414 Old 09-19-2014, 07:05 AM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Liked: 2278
A peak like that is not obvious in my initial measurements but I'll be on the lookout. As for excursion, I just ran some tests and there's zero issue, I got the system up to dangerous volume levels running sine waves between 80 and 150 Hz—the woofer barely gets moving and it's already intolerably loud.
imagic is offline
post #411 of 414 Old 09-19-2014, 07:47 AM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Liked: 2278
You do need to toe in controlled directivity speakers. I get tons of precise imaging with floating instruments and voices out of by B215s, so hopefully with some experimentation you'll find an arrangement that gives you those audiophile qualities.
imagic is offline
post #412 of 414 Old 09-19-2014, 07:49 AM
teddytusen's Avatar
6 days, somewhere between 20-25 hours in front of the B212 now. They integrate so well with my 18" subwoofers it is pure bliss. I obviously had major phase issues with my old setup because I have turned down the subs many db over this week. Many db first, and gradually some more. Somewhere around 8db I think. What I find strange is that I did not have the bass I have now even when my old speakers was set to same xo frequency...
My setup sounds very good right now.
imagic likes this.
post #413 of 414 Old 09-19-2014, 08:00 AM
Quoted: 316 Post(s)
Liked: 542
It won't be. Its hard to see any wave front coming off the speaker at 500hz in room, especially something that behaves like a dipole peak (changes quickly off axis). And it can't be eq'ed even if you did see it. But like I said, you may not notice.
post #414 of 414 Old 09-19-2014, 08:37 AM
Gooddoc's Avatar
Quoted: 179 Post(s)
Liked: 218
I think toe-in has more to do with dispersion characteristics and power response than it has to do with controlled directivity, although the two have become synonymous.
CHT SHO-10 x 5 powered by Denon 4311 and Lab Gruppen 10000Q amp
JTR S2 x 2
CHT 18.1 x2
Oppo BDP103D bluray player/Sonos/PS3
Gooddoc is online now
Reply Speakers
Behringer B215xl Passive Speaker Pair , Pioneer Elite Sc 55 Sc55 9 1 Channel 3d Ready A V Receiver , Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Behringer , B 52 Lx 1515v3 1000w Dual 15 Pa Speaker , B 52 , Behringer Eurolive B212d Active 550 Watt 2 Way Pa Speaker System With 12 Inch Woofer And 1 35 Inch C
Gear in this thread - B212d by PriceGrabber.com
