Behringer Eurolive B215XL 15" 2-Way as L/R Mains - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 1552Likes
post #451 of 4020 Old 10-25-2014, 08:35 AM
Liked: 0
I don't remember if this has been answered already, but do these speakers do well at seating locations outside of the MLP or is the sweet spot more localized?
The Money Train is offline
post #452 of 4020 Old 10-25-2014, 11:29 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
By design I would imagine they would be more localized. Waveguide speakers have a more focused sound pattern.
jbrown15 is offline
post #453 of 4020 Old 10-26-2014, 01:17 AM - Thread Starter
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 5046 Post(s)
Liked: 8514
Its dispersion is wide enough to cover typical home theater seating, not just the MLP.
Mark Henninger
imagic is online now
post #454 of 4020 Old 10-26-2014, 01:25 AM
jbrown15's Avatar
Liked: 1993
I'm not saying it won't, but I wouldn't want one 2ft from my head as a surround. I know they are an excellent value but it wouldn't be my first choice as a surround. But I'm sure if someone wanted to use on as a surround it would work just fine, just wouldn't be something I'd want or something I would recommend to someone.
jbrown15 is offline
post #455 of 4020 Old 10-26-2014, 07:25 AM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 61
I agree you on this. Unless you have a big room or you are going 5.1 and want to put two of these in the back corner, I might use them. I have an EOS 8 for side and rear surrounds. I'm going to move my sides to heights and rebuild my sides because I think that the dispersion is too tight for the sides. These would be way tighter.
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #456 of 4020 Old 10-26-2014, 09:05 AM
Liked: 0
I have a pretty wide seating area with two rows about 6-8 seats across at 14-16 feet from the speakers. The room is 22'x19' (LCR on the 19' wall). It sounds like the Behringers may be tough in that space. Although given the seating distance, would that ameliorate some of the issues? I know the CX-10s have been talked about a lot on recent threads as well. I assume those would cast a wider sweet spot, correct?
post #457 of 4020 Old 10-31-2014, 12:15 AM
brianstrawberry's Avatar
Liked: 25
Here is what I've come up with in my basement/media room this year. It has been a very fun project to plan and piece together. The Behringers sound really really good to me. There are three 215XLs behind the AT Falcon screen (excellent screen too BTW), and two sets of 212XL serving as heights and wides. Surrounds are Axiom QS8s and the subs are FV15HP Rythmik. Projector is a JVC RS-65 and the second/mirror screen is a 27" computer monitor on a swing arm to use when playing music or games. AVR is a Denon X4000 and an Oppo 103 is used for blurays.
Going from five channels to nine so far has been a blast! We watched Snowpiercer tonight and the train sounds created a pretty cool effect where it sounded like the room was riding along on the train. I am also having a lot of fun letting the Denon process Pandora on all channels as well.
Here are some pictures of the room, the first is right behind the MLP:
brianstrawberry is offline
post #458 of 4020 Old 10-31-2014, 09:22 AM
Mike12086's Avatar
For a 7.1.4 Atmos setup what would you recommend for ceiling speakers? My ceiling is not that high so i cannot get away with ceiling mounting these guys.
Mike12086 is offline
post #459 of 4020 Old 10-31-2014, 09:25 AM
shepP's Avatar
Quoted: 39 Post(s)
I've just bought 3 of these and joined the club. Has anyone played around with trying to eq some more midbass out of these speakers? I have lots of power on tap so I want to see how low I can get them to play.
imagic likes this.
shepP is offline
post #460 of 4020 Old 10-31-2014, 09:26 AM - Thread Starter
imagic's Avatar
Liked: 8514
I'm thinking hard about that. Wide dispersion is the main requirement for ceiling speakers, so Behringers, or any other horn-loaded design, would not be ideal anyway. I'm looking at high-quality bookshelf or satellite speakers that have some provision for mounting.
Mark Henninger
post #461 of 4020 Old 10-31-2014, 09:33 AM - Thread Starter
imagic's Avatar
Liked: 8514
Yes, I switched for my AVR to a Crown XTi-2002 that has parametric EQ. If you are bold and have the power, you can get 'em to play flat down to 50 Hz or so with enough headroom to make yourself deaf. I have found usable output down to 35 Hz. The woofers are very under-utilized. The EQ compensation is not going to be subtle, and it would give an audiophile purist a heart-attack.
TheGiantPeach likes this.
Mark Henninger
post #462 of 4020 Old 10-31-2014, 10:11 AM
jbrown15's Avatar
Liked: 1993
When I made a comment about these speakers having a more focused dispersion and might not be ideal for surround use you said that it would be fine to use as surrounds. So if its goo enough to use as surrounds why not Atmos? They are both similar applications.
jbrown15 is offline
post #463 of 4020 Old 10-31-2014, 10:14 AM - Thread Starter
imagic's Avatar
Liked: 8514
When I made a comment about these speakers having a more focused dispersion and might not be ideal for surround use you said that it would be fine to use as surrounds. So if its good enough to use as surrounds why not Atmos? They are both similar applications.
But they are not similar applications at all. It's the vertical dispersion that's an issue with horn tweeters. The B215's cover the horizontal spread just fine, which works for regular surrounds. But on the ceiling, you want the same dispersion in all directions.
Mark Henninger
post #464 of 4020 Old 10-31-2014, 10:23 AM
jbrown15's Avatar
Liked: 1993
Okay gotcha, I guess that's why lots of people are saying a good coax driver would make a good Atmos speaker.
imagic likes this.
jbrown15 is offline
post #465 of 4020 Old 10-31-2014, 10:32 AM
shepP's Avatar
Quoted: 39 Post(s)
Thanks, that is great to hear! I have an old Emotiva LPA-1 with 125 watts per channel that should give them some power. What setting did you use for your parametric EQ? I will probably start by using the parametric EQ that is built into my UMC-200.
shepP is offline
post #466 of 4020 Old 10-31-2014, 10:36 AM - Thread Starter
imagic's Avatar
Liked: 8514
That is 100% correct and Andrew Jones used coax drivers in his Atmos-enabled speakers for just that reason.
Mark Henninger
post #467 of 4020 Old 10-31-2014, 10:40 AM
jbrown15's Avatar
Liked: 1993
If I decide to go with Atmos I've already talked with Jeremy from Reaction Audio about it, I have his CX-15's and CX-8's in my theater right now and REALLY like them. He's using some really nice Radian coax drivers in his speakers, I'm sure they'd do nicely!...
imagic likes this.
jbrown15 is offline
post #468 of 4020 Old 10-31-2014, 10:46 AM - Thread Starter
imagic's Avatar
Liked: 8514
It's going to be room dependent, but you are going to have to cut at port tune and then boost below that. Below port tune the B215XL behaves like an open-baffle speaker, meaning it needs a huge boost to equalize it.
I removed the enclosures on my B215s, they run as actual open-baffle speakers not. My EQ curve is way different than what it would be with the enclosure on. I have mine boosted 6 dB at 50 Hz, with a Q of 1.
Mark Henninger
post #469 of 4020 Old 10-31-2014, 12:43 PM
shepP's Avatar
Quoted: 39 Post(s)
Thanks for the help. Couple of questions.
What is the port tune of these speakers?
How would I setup a cut off using a parametric EQ? What would the highest frequency after this cut off that I could potentially start boosting?
Looks like I will need to break out my room eq wizard equipment again
shepP is offline
post #470 of 4020 Old 10-31-2014, 12:55 PM
tuxedocivic's Avatar
Quoted: 1921 Post(s)
Liked: 1743
Careful eq'ing and using any speaker below port tuning. Excursion rises very quickly and if you like big SPL and lots of bass, you may damage the woofer. Now, Behringer may have built in some kind of protection. Such as running out of BL at high excursion, or some kind of suspension arrestor. But then that means the speaker will heavily compress. Also, port tuning shift 90 degrees out of phase from the rest of the system, so sub integration becomes an issue. Just keep these things in mind. I certainly wouldn't recommend it.
jbrown15 likes this.
tuxedocivic is online now
post #471 of 4020 Old 11-02-2014, 04:12 AM
Archaea's Avatar
Quoted: 2926 Post(s)
Liked: 2526
Why are you doing that? What does the fr measure like?
Archaea is online now
post #472 of 4020 Old 11-02-2014, 04:19 AM
Archaea's Avatar
Liked: 2526
Question
There is no port tune now, Mark is running his speakers open baffle. I don't see how he'd be getting much at 50Hz no matter how much eq applied. I'm not that knowledgeable about speaker design, so I don't even know what that would do, but I would imagine it cancel all bass response, and cause lots of nasty room reflections and associated frequency response issues, unless heavily treated (absorption) behind the front baffle that is shown in the pic.
post #473 of 4020 Old 11-02-2014, 05:08 AM - Thread Starter
imagic's Avatar
Liked: 8514
Not all the bass is cancelled. Here's a plot of just the two B215XL speakers running full-range, measured from my main listening position.
I was specifically inspired by Peter Lyngdorf of Stenway Lingdorf. I met him at CEDIA where the S/L Atmos demo was the best I heard. Peter mentioned that he did not care if a speaker measures flat because in his approach (which uses open-baffle speakers) everything gets equalized based on in-room measurements. Therefore, anechoic flat response is not a necessity. I decided to try the hacked, zero budget version of that. I like the results, what else can I say.
Mark Henninger
post #474 of 4020 Old 11-02-2014, 06:22 AM
Liked: 1743
I was referring to what ShepP wanted to do below port tune. But I also happen to agree with you on imagic's setup. That also runs the dangers.
Marc Alexander likes this.
post #475 of 4020 Old 11-02-2014, 06:30 AM - Thread Starter
imagic's Avatar
Liked: 8514
It sounds good and works in my room, and that's all I ask of any system. I'm not suggesting what I did is the right approach, but to my ears it's as valid as any other speaker design with no obvious audible issues, although I'm sure plenty of people could find plenty of flaws. However, let's not forget the price of these over-achieving speakers.
Mark Henninger
post #476 of 4020 Old 11-02-2014, 06:48 AM
Liked: 1743
Which is why I haven't criticized what you've chosen to do. I could tell you a hundred theoritical reasons why it's bad, but you like it, so sure.
But for ShepP using eq below tuning, and anyone reading about your method, I'm just noting the serious power handling risks. If you aren't clanking the woofers the way you have them, then you're either listening quiter than most people, or the woofers are stopping before they should (compression). There's no law of physics these woofers are breaking.
post #477 of 4020 Old 11-02-2014, 06:53 AM
Archaea's Avatar
Liked: 2526
Very interesting Mark. I would have expected a much different frequency response. That's corrected by EQ? If so, do you happen to have a raw capture of the uncorrected open baffle use? I'm legitimately curious how much EQ has to be applied to make that work. I'm surprised you can get it to work at all. Again I'm not a speaker designer, like tux and have very limited experience - so surprise is all I can muster without experience to now how it works. I'm just thinking back to the several times I've run a subwoofer driver free air and you basically hear nothing out of the driver, even at high excursion levels, because without a cab the driver movement cancels out lower frequencies - so I'm surprised you can even get output in subwoofer territory - 50-80-120hz range on your chart.
post #478 of 4020 Old 11-02-2014, 07:04 AM
Archaea's Avatar
Liked: 2526
As aside, I recently stuffed my Mackie C200 speakers with poly fill. The response after the stuffing measured a bit smoother than before, and distortion and bass decay numbers were slightly better. Since the Mackie C200 and Behringer B215XL both have similar plastic enclosures - It may be possible that the Behringer owners in this thread would also benefit from stuffing their Behringer speakers with polyfill. Thanks to the DIY guys for the suggestion.
Here is my experiment documentation. Post 31 from this thread:
Mackie C200 - under the hood
In the interest of following up on some advice from the DIY guys I performed a little additional testing today on the Mackie C200. I was advised to stuff poly fill in the C200 cab and see if that helped the speaker. Here are the results of that test. For the test a crossover of 80hz was used. The Onkyo PR-SC5508 was the source, Pure Direct mode on the Onkyo was used to bypass all AVR EQ functions. A Crown XLS-202 amp bridged was connected to one 8ohm Mackie C200.
The test results seem to indicate the polyfill helped smooth the frequency response below 1Khz, at the expense of some spl around port tune.
The red line is the 10 capture average of the native frequency response of the C200 speaker.
The blue line is the 10 capture average of the poly stuffed frequency response of the C200 speaker.
Here are the distortion measurements stock
Here are the distortion measurements poly stuffed
Here is the bass decay stock
Here is the bass decay poly stuffed
measurement pictures
stuffing pictures
LTD02, imagic, MKtheater and 2 others like this.
post #479 of 4020 Old 11-02-2014, 07:10 AM - Thread Starter
imagic's Avatar
Liked: 8514
Well, it works. It's certainly not that I listen to lower levels overall, and if there is dynamic compression it is not entering the equation at anything even remotely normal volume-wise, at least in my small space (roughly 12x18) where I am seven feet from the speakers. But I agree that readers should heed your warnings.
Mark Henninger
post #480 of 4020 Old 11-02-2014, 07:23 AM - Thread Starter
imagic's Avatar
Liked: 8514
Here's a measurement from (roughly) the same spot. No EQ, pure/direct mode stereo. Two sweeps, one at my normal listening levels, and one rather loud sweep.
Archaea and TheGiantPeach like this.
Mark Henninger
Reply Speakers
Behringer B215xl Passive Speaker Pair , Pioneer Elite Sc 55 Sc55 9 1 Channel 3d Ready A V Receiver , Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Behringer , B 52 Lx 1515v3 1000w Dual 15 Pa Speaker , B 52 , Behringer Eurolive B212d Active 550 Watt 2 Way Pa Speaker System With 12 Inch Woofer And 1 35 Inch C
