Behringer Eurolive B215XL 15" 2-Way as L/R Mains - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1609Likes
post #31 of 4091 Old 03-06-2014, 07:47 AM
elmerfudII's Avatar
Quoted: 64 Post(s)
Liked: 26
If you are looking for dispersion, the Behringer stage monitors have it in spades.
elmerfudII is offline
post #32 of 4091 Old 03-06-2014, 10:34 AM
brianstrawberry's Avatar
Liked: 27
Mark,
With the connections the way that they are, how do you hook these up to a receiver? Maybe its easier than it looks, but it doesn't look like I can use regular speaker cable.
Also, is there any specific reason you are not using a third as a center?
Thank you
brianstrawberry is offline
post #33 of 4091 Old 03-06-2014, 08:59 PM
mhutchins's Avatar
Quoted: 98 Post(s)
Liked: 121
You can convert your own speaker cable in about five minutes for less than $8. Here is one example:
Speakon connector: Parts Express #092-198
Banana Jacks: Parts Express # 091-356
90 degree connector shown, but the straight connector in the link is even easier to assemble. In the last image, the wire is not positioned fully into the screw cup of the connector. The insulation should stop just above the cup, not 1/4" above.
Mike
mhutchins is offline
post #34 of 4091 Old 03-08-2014, 08:23 PM
fish323's Avatar
Quoted: 18 Post(s)
Nice write up! Much appreciated.
Was there ever a time while watching TV/movies that a center channel would've help center the dialogue more, or were these doing the job just fine? Did you take note at what degree off-axis the stage started to collapse? Thanks.
fish323 is offline
post #35 of 4091 Old 03-10-2014, 09:19 AM - Thread Starter
Mark Henninger
imagic's Avatar
Quoted: 6596 Post(s)
Liked: 11347
That's entirely circumstantial, based on the room and listening distance. The speakers have relatively controlled directivity. which I find helps prevent the image from collapsing, so long as your listeners are all within the tweeter's range, which is 70 degrees (horizontal) by 40 degrees (vertical). I toe in the speakers a fair bit, and I get good imaging across my couch. I don't miss the center channel at all, dialog is ridiculously clear and I watched Star Trek: Into Darkness last night, which cemented my view that these speakers are perfect for home theater.
If I get another projector—I recently sold my Epson 8350—I'll look for an acoustically transparent screen and add a third B215XL. However, for both movies and music I am perfectly pleased with using phantom center mode. 2-channel stereo is superb as well, really a highlight.
Mark Henninger, Senior Editor at AVS Forum
imagic is offline
post #36 of 4091 Old 03-11-2014, 02:14 PM
Liked: 27
I bought a trio of these for my front stage based on Mark's review and how the design is similar to other theater speakers. Though I have little to no background in premium speakers, I am very very impressed with the big sound these are capable of - especially watching movies.
Thank you for the review, I am very pleased with this speaker!
imagic and rouslan like this.
post #37 of 4091 Old 03-11-2014, 02:21 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11347
Oh wow! Glad you like. What's the possibility of going vertical with the center channel? The horn dispersion is relatively limited when it's on the side like that, although maybe its enough to cover a sofa. If it works, one nice thing about that arrangement is how the speaker was designed to double as a stage monitor, so it has just the right tilt for use on its side like that.
 I've been thinking about getting a third for the center and actually using it as the TV stand.
imagic is offline
post #38 of 4091 Old 03-11-2014, 08:44 PM
Liked: 27
Plan A was to move the Denon and place the center channel vertical under the TV. It turns out, with the center on its side its firing directly at the couch and it seemingly ties in equally with the L/R. Thankfully it also spared me rerunning a bunch or wires and tearing out the permanent shelf.
I hope to learn REW soon (UMIK-1 is on the way) which may help me make a better-informed decision on final placement.smile.gif
post #39 of 4091 Old 03-12-2014, 09:43 AM
elmerfudII's Avatar
Quoted: 64 Post(s)
Liked: 26
Prior to this thread, I never would have thought of using a 15" woofer in a center channel. I think the relatively high resonant frequency helps.
FYI, these are the speakers that are used in commercial cinemas.
http://www.jblpro.com/www/products/cinema-market/3000-series#.UyCM62fDj01
Its interesting that some speakers (8320, 3678) are THX certified (certifiable ?) and the others aren't.
post #40 of 4091 Old 03-12-2014, 11:20 AM
Daniel Chaves's Avatar
Quoted: 436 Post(s)
Liked: 342
basically it comes down to if the company wants to pay to have THX engineers look at their product, test it and then slap an approval on it so if the company had a few similar speakers already tested and you build another series based around the same design and build quality then why pay to have THX certify those when you know they would most likely pass their requirements thus slapping the label THX certifiable, mean yeah we didnt feel like blowing money getting the actual certification but we are fairly confident that it would lol. smile.gif
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Marantz SR6011 ATMOS/DTSX + Darbee 5000s
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Polk Audio TSx110B (Ceiling FL/FR RL/RR), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.4 Source: OPPO UDP-203 4k Bluray Player, Roku 4, HTPC, Nexus Player
Daniel Chaves is offline
post #41 of 4091 Old 03-19-2014, 11:07 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11347
I tried finding the upper volume limit of the B215XLs when powered by my Pioneer Elite SC-55 and I chickened out when it started to feel dangerous—which happened to measure between 110-115 db at my MLP. There was no sign of strain whatsoever.
imagic is offline
post #42 of 4091 Old 03-19-2014, 07:28 PM
elmerfudII's Avatar
Quoted: 64 Post(s)
Liked: 26
Its great to see you share this sort of information !
Any updates from subwoofer land ? I saw in another post that you sent the SVS PB2000 back. How did it match up with the 215s ?
Did you do a build thread for your home made subs ?
post #43 of 4091 Old 03-19-2014, 08:19 PM
tyee's Avatar
Quoted: 73 Post(s)
Liked: 29
Anyone else have these speakers? I'm tempted to try to listen to them somewhere but my local music stores don't carry the non-powered version.
tyee is offline
post #44 of 4091 Old 03-20-2014, 11:36 AM
tyee's Avatar
Quoted: 73 Post(s)
Liked: 29
Hey Mark
Just reading the GTG you attended. Very interesting. JTR seems to be regarded by everyone as one of the best, especially the 212, but how does the Single 8 compare to these Behringer B215XL's? You seemed to like them a lot. Coax vs Horn?? I do prefer my speakers just like you said, "Very forward, crisp and dynamic".
tyee is offline
post #45 of 4091 Old 03-20-2014, 02:51 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11347
Originally Posted by tyee View Post
Hey Mark
I will bring the 215XLs with me to the next GTG or perhaps demo a pair of Single 8s at home if I can work that out. My room and my system are too different, and it's been too long, to offer that opinion.
imagic is offline
post #46 of 4091 Old 03-20-2014, 06:13 PM
tyee's Avatar
Quoted: 73 Post(s)
Liked: 29
Just for fun I went down to Long&McQuade today and listened to the U15P (powered version). I have never heard any of the PA type speakers before. They were only sitting on the sales counter shelf so not ideal at all but that's all they could do. Took my demo CD's. They did sound very good. Nice and clean with good bass. If the Behringer B215XL's were close in performance for us at home then I would be a customer. The U15's are $1725 each!
tyee is offline
post #47 of 4091 Old 03-20-2014, 09:43 PM
Liked: 27
From my X4000 for what its worth. Still not sure what the waves around 100Hz mean and have not yet had the energy to learn REW.
I just got in dual FV15hps yesterday have have been ecstatic to say the least! I listened to music for a few hours last night and watched Man of Steel BR tonight. Very impressive on both accounts and capable of being incredibly loud...
Im looking forward to having a few of my B&W friends over to show off. smile.gif
post #48 of 4091 Old 04-03-2014, 10:27 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11347
For what it's worth, I've literally stopped thinking about speakers since I got the Behringers. I've enjoyed every minute of music and movie soundtrack that's come out of them. Amazing.
digitrip and rossandwendy like this.
imagic is offline
post #49 of 4091 Old 04-12-2014, 08:14 AM
elmerfudII's Avatar
Quoted: 64 Post(s)
Liked: 26
Any updates on subwoofer pairings with these speakers ?
post #50 of 4091 Old 04-13-2014, 02:49 PM
Quoted: 436 Post(s)
Liked: 342
How do we find out about these AVS gatherings? and were each one occurs?
post #51 of 4091 Old 04-13-2014, 03:14 PM
GIEGAR's Avatar
Quoted: 834 Post(s)
Liked: 1423
Daniel, you usually have to keep your eye on the Area Home Theater Meets section.
Also, the DIY fellas tend to organise a fair proportion of G2G's and coordinate them in the DIY Speakers and Subs section.
-Axle- and Daniel Chaves like this.
GIEGAR is online now
post #52 of 4091 Old 04-14-2014, 08:00 AM
Utopianemo's Avatar
Quoted: 172 Post(s)
Liked: 121
So what are you using for your house "stereo" and why aren't the Behringers in there ?
In the living room I have Acoustic Zen as my front three and Paridigm as surrounds with 2 JL 112 Fathoms for subs. Home theatre ( under construction) has 3 JTR Noesis 212 HT-LP. surrounds will be DIY V-8 or V-10's and 4- UXL 18's.
I don't think I would have any problem using Behringer's all around in theatre if I was limited on the budget, other than surround duty as its hard to make them blend into room. For the cost of just 2-JTR's you could by a complete Behringer system. Would it have the performance of my system? I don't think it would ( At least I hope not, or I'm going to feel really dumb for spending all this extra money) LOL If I get to the point of Getting mains hooked up this weekend, I might just haul down Behringer's to Basement and do a side by side with the mains. Won't have a sub comparison as I'm still waiting for UXL's and Pro 1800 is a little heavy to haul down stairs by myself. I can tell you that it blows away Fathom's from 35 or so Hz up in volume, and to my girlfriend sounds better. She finds that very deep bass sounds muddy to her for lack of a better word ( not as tight sounding). For me I like the 20 hz notes hitting you hard and that's why I chose the UXL's and 4 of them.
I would love to hear your thoughts on a comparison
Pioneer SC-95
Epos Epic 2(LCR), Emotiva UAW 6.2(Rear), Aperion Intimus LC-I6(In-ceiling Atmos/DTS:X)
x2 Dayton Ultimax 18" sealed(subs), Behringer Inuke 6000DSP(sub amp),
Vizio P-65C1 LED HDR
Oppo UDP-203 HD-Blu Ray Player, Oppo DV971H DVD Player, Roku Premiere+
Utopianemo is offline
post #53 of 4091 Old 04-14-2014, 08:26 AM
BrentTHX's Avatar
I still haven't got around to hauling them down stairs to so the comparison yet, I know that in the midbass area the Behringers will win hands down. Been running the 212 full range for a month while I work on theatre and basement wiring and they don't have a lot. Although it may just be just because the 212 horn is so strong. I will see if I can get it done this weekend.
BrentTHX is offline
post #54 of 4091 Old 04-14-2014, 11:30 AM
Utopianemo's Avatar
Quoted: 172 Post(s)
Liked: 121
Mark,
This may be a strange question, but how would you think the speakers would do upside-down? In my present setup, my monitors sit directly on a cabinet. The Behringers are so large that the horn would end up way above ear level. I've seen other speakers oriented with the mid/woofer on top(RSL comes to mind); what do you think that would do to the Behringers?
Pioneer SC-95
post #55 of 4091 Old 04-14-2014, 01:59 PM
Quoted: 436 Post(s)
Liked: 342
Anyone is the LA area using these speakers in their home theater that I would be able to check out?
post #56 of 4091 Old 04-14-2014, 02:09 PM
Divergent9999's Avatar
Hello Mark,
Thank you for sharing this information about these speakers.
Would you recommend these Behringer speakers for a 2-channel stereo setup? I have an Emotiva Pre-amp and Power amp.
Thank you.
Divergent9999 is offline
post #57 of 4091 Old 04-14-2014, 03:51 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11347
Originally Posted by Divergent9999 View Post
Hello Mark,
Thank you.
Only in conjunction with a subwoofer, but yes.
imagic is offline
post #58 of 4091 Old 04-14-2014, 03:52 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11347
Mark,
Nothing bad happens. I had them higher up and upside-down for a while, it works.
imagic is offline
post #59 of 4091 Old 04-15-2014, 02:03 AM
Skylinestar's Avatar
Quoted: 1213 Post(s)
Liked: 226
@imagic
How do the B215XL compare with the JBL 3677 speaker?
How about B215XL against Klipsch Reference tower like RF82ii?
Skylinestar is offline
post #60 of 4091 Old 04-15-2014, 04:35 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 11347
Originally Posted by Skylinestar View Post
@imagic
They B215XL is a slightly more subdued. Both of those other speakers are more full-range, the Behringers require a reltively high crossover in comparison. When properly matched to subwoofers, all three speaker models perform rather similarly in that they are clean and dynamic and capable of tremendous output.
imagic is offline
Reply Speakers
Behringer B215xl Passive Speaker Pair , Pioneer Elite Sc 55 Sc55 9 1 Channel 3d Ready A V Receiver , Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Behringer , B 52 Lx 1515v3 1000w Dual 15 Pa Speaker , B 52 , Behringer Eurolive B212d Active 550 Watt 2 Way Pa Speaker System With 12 Inch Woofer And 1 35 Inch C
