Best 5.0 setup for under $1k, mixing looks and sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-28-2014, 05:17 AM - Thread Starter
Bedowyn's Avatar
So we are finally buying a house! And I have family room to build.
We are wall mounting a 65" and want to do a 5.1 discrete setup. I have a great Denon receiver and amplified sub, but my speakers are old and worn out. I can definitely do with an upgrade.
So I am looking for suggestions for a center, left, right and pair of surrounds. My total budget is $1000 (give or take), mixing value and relative quality. And because I want to wall mount, perhaps on a floating wall, I would like them to be wall mounted. Obviously, I want a set that is timber matched, and if there was a set sold all at once for a discounted rate, that would not be a bad thing. smile.gif
My concern is that as I look around the internet, it seems like you have three options:
- Small egg like speakers
- free standing left and rights, or
- book shelf (meaning boxey looking) speakers
Ideally, I would love something that was a bit leaner looking, perhaps a bit long and thin. Kind of like the center speakers are, but turned vertically. Someting a bit shallower than a foot deep would be nice too.
And yes, I know that aesthetics should not prioritize over acoustics, but hopefully I can have it all, with reasonable quality and at a realistic price. If you take a look at Groove's setup on the UK board, you can get an idea of what I am shooting for.
HELP ME AV-Form-obi.... your my only hope!
(Thanks in advance)
Bedowyn is offline
post #2 of 3 Old 02-28-2014, 02:59 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
Definitive Technology Mythos speakers are meant to be wall mounted. Not sure if they will fit your budget.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 3 Old 02-28-2014, 03:08 PM
RayGuy's Avatar
Quoted: 918 Post(s)
Liked: 780
RayGuy is online now
Reply Speakers
