Speakercraft AIM7 Five in ceiling and AIM LCR 5 + AIM Cinema Speaker - 7.1 setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-02-2014, 07:04 AM - Thread Starter
journeyguy's Avatar
Quoted: 26 Post(s)
I am trying to go for the following 7.1 set up in my great room. This is the Speakercraft top of the line speakers. Anyone has experience with these speakers and recommend it.
AIM LCR 5 in wall - Center. Can be installed vertically or horizontally
http://www.bestbuy.com/site/aim-lcr-5-dual-5-1-4-in-wall-speaker-each/2903765.p?id=1219082670436&skuId=2903765&st=asm84651&cp=1&lp=1
AIM Cinema - Left and right
http://www.bestbuy.com/site/aim-cinema-speaker/8556314.p?id=1210290067155&skuId=8556314&st=asm71551&cp=1&lp=1
AIM 7 Five - 4 inceiling speakers for side and rear surrounds
http://www.bestbuy.com/site/profile-aim7-five-7-in-ceiling-speaker-each/1308444787.p?id=mp1308444787&skuId=1308444787&st=in%20ceiling%20speakers&cp=1&lp=15#tab=specifications
I am also thinking of Paradigm ASM series, but I am getting a great deal from Best Buy. Let me know.
journeyguy is offline
post #2 of 3 Old 03-03-2014, 06:58 PM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 167
In-wall speakers are much better with back box enclosures.
The LCR-5 seems on paper to be a little weak on the power handling compared to the AIM Cinema, so I wonder if you cranked it would the center distort more?
Also look at Triad In-Wall and In-Ceiling.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #3 of 3 Old 03-05-2014, 07:56 AM
dougri's Avatar
Quoted: 46 Post(s)
Liked: 52
Also consider the DefTech UIW series... I've been very happy with the RCS ii and RSS ii... Have heard very good feedback on the in-wall LCRs as well. And of course the Triads if you can budget them.
dougri is offline
Reply Speakers
Speakercraft Aim7 Two Fully Pivoting High Fidelity In Ceiling Loudspeaker
