Martin Logan Motion or Golden Ear - AVS Forum | Home Theater Discussions And Reviews
Old 03-03-2014, 09:09 AM - Thread Starter
LoudVH's Avatar
I have finally narrowed down my speaker search to two.I'm looking for something small and wall mountable. I have heard the Martin Logan Motion 4 and thought they sounded really good. I also am interested in the Golden Ear Super Sat 3 but have not heard them yet as the nearest dealer is 70 miles away and I haven't found the time to get there yet. It is the tweeter that draws me to these models. It sounds real nice on the Motions compared to the Bose AM 10 I've had for the last 10 years! Question is has anyone heard both? Which do you prefer and why?
LoudVH is offline
Old 03-03-2014, 07:37 PM
Eyleron's Avatar
Quoted: 251 Post(s)
Liked: 142
Well, sure the Martin Logan sounds great compared to the Bose. Most stuff does. Make sure you do make that drive to listen to the Golden Ears before you decide.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is online now
Old 11-17-2014, 03:14 PM
c_h_shin's Avatar
I'm considering the exact same two speakers! Did you ever get a chance to compare the two? What did you finally end up buying?
c_h_shin is offline
Old 11-17-2014, 05:07 PM
zgeneral's Avatar
Quoted: 874 Post(s)
Liked: 213
Find a dealer who sells both. Go listen to both of them. Few people on any of these sites will have heard both. Most people recommend what they bought because they spent money on what they purchased and want to feel like they made a good decision.
zgeneral is offline
Old 11-17-2014, 06:12 PM - Thread Starter
LoudVH's Avatar
I ended up with the Martin Logans. I did hear both brands and really liked both of them. I wanted to build my system with products from the same brand and my budget became a factor. I bought a ML Dynamo 300 for a sub much cheaper than a Goldenear would have cost me. If budget was not an issue I may have gone for the Goldenears but I have to say I am very happy with the MLs and have not looked back. Plus they look awesome on the wall! I don't think you can go wrong with either one.
LoudVH is offline
