Pure Copper Banana Plugs - AVS Forum | Home Theater Discussions And Reviews
 20Likes
  • 3 Post By commsysman
  • 1 Post By Bill Fitzmaurice
  • 2 Post By jdcrox
  • 1 Post By FMW
  • 2 Post By Bill Fitzmaurice
  • 1 Post By audiovideoholic
  • 4 Post By Bill Fitzmaurice
  • 1 Post By afrogt
  • 1 Post By airgas1998
  • 1 Post By Ormy
  • 1 Post By cesar123
  • 1 Post By Ormy
post #1 of 30 Old 03-05-2014, 01:44 PM - Thread Starter
mantaraydesign's Avatar
Quoted: 163 Post(s)
Liked: 35
Anyone know a place where I can buy pure copper banana plugs with gold plated?
I am hearing pure copper plugs will sound much better than brass plugs. Most of the banana plugs out there are made of brass metal with gold plated.
mantaraydesign is offline
post #2 of 30 Old 03-05-2014, 01:49 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
There are no pure copper banana plugs, because that would be stupid, for a couple of reasons.
Pure copper is soft and would not retain the springyness required to fit tightly.
Pure copper would also corrode quickly and contact would be bad.
What you want is banana plugs that are gold-plated for long-term corrosion resistance.
A brass alloy that has good spring qualities is used; that's what is required.
Gold is one of the few metals that does not corrode.
Chu Gai, darthray and oneeyeblind like this.
commsysman is offline
post #3 of 30 Old 03-05-2014, 01:55 PM - Thread Starter
Quoted: 163 Post(s)
Liked: 35
Thanks for the advice!
So what you are saying is that all banana plugs will sound the same as long as they are gold plated.
post #4 of 30 Old 03-05-2014, 01:59 PM
Bill Fitzmaurice's Avatar
Liked: 5684
All banana plug materials sound the same, with or without gold. The only advantage to gold plating is that it won't corrode, but for that matter neither will tin.
oneeyeblind likes this.
Bill Fitzmaurice is offline
post #5 of 30 Old 03-05-2014, 08:22 PM
BuddTX's Avatar
Quoted: 110 Post(s)
Liked: 83
When I used banana plugs, I use the Orange County Banana Plugs (google it)
However, just a few weeks ago actually, I decided it was better to connect my speaker wire directly to my receiver. I always have had a hard time getting the cables connected to the receiver, so that is why I used Banana Plugs. However, unplugging everything, and turning my receiver upside down to connect the negative posts worked perfectly.
Also, what I noticed, was that several banana plugs became "loose" since the last time I checked them, and I can get a better, tighter, more secure connection connecting my cables directly to my receiver.
I also feel better knowing that there are fewer "breaks" in my speaker wires.
BuddTX is online now
post #6 of 30 Old 07-16-2014, 11:25 PM
Liked: 0
There are Copper banana plugs - I just purchased and received 24 pieces and have Copper Spades on the way. I'm going to use a RESPONDERS advice (actually lack of advice) to guide you!
There is a brand name called Nakimichi that are copper - you can find identical units with various names. But are they Copper ?- I sawed one in half to find that telltale pink metal within. Copper and brass, by the way, is not magnetic. Look on E-Bay or Amazon
I've seen a popular plugs selling for 4 for $30.00 WOW - I just paid $20.00 for 24 pieces- 12 red/12black - they have double screws and screw on sleeves.
Hmmm - I always found it annoying to find the pennies in my pocket all bent out of shape. Copper Banana plugs DO have quite a snug fit (the Nakimichi I purchased but IF you are that concerned use SPADES
So I guess - it is bad to also use copper wire??? Copper changes color to a greenish patina. I wonder IF the Gold plating would prevent copper from corroding?!
Yes, Gold plated COPPER!
ABSOLUTLY NOT!!! Amplifiers have copper wiring within as well as speakers. They are connected with COPPER wire. Why would anyone BREAK that chain by introducing a BRASS element??? That IS STUPID!
The International Annealed Copper Standard material conductivity study reveals the following FACT:
Silver - 105%; Copper - 100%; Gold - 70%; Aluminum - 60%; Brass - 28%
Well you got one right!
Joseph1975 is offline
post #7 of 30 Old 07-16-2014, 11:26 PM
Liked: 0
So what you are saying is that all banana plugs will sound the same as long as they are gold plated.[/quote]
NO! That is WRONG!
post #8 of 30 Old 07-17-2014, 02:56 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 104
NO! That is RIGHT!
Any conductive banana plug that is firmly connected to both the wire and the jack it goes into will sound EXACTLY the SAME!
Measure the resistance from tip to the wire connection of any 2 banana plugs. Use a sensitive ohmmeter. Do you really think you will notice a difference?
jdcrox is offline
post #9 of 30 Old 07-17-2014, 05:25 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
Look to Monoprice.
I've bought all my plugs from there as well as several for family members. Never had an issue and they're great build quality.
Nicktx27 is offline
post #10 of 30 Old 07-17-2014, 05:39 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
Nice sales pitch but this is not the place to misinform people that wire conductivity affects sound. We all know better than that. For the OP, the very best way to connect speakers is to tin the ends of the speaker wire and connect them directly with no connectors at all. It is certainly more time consuming but certainly more secure. If you want banana plugs, the Monoprice connectors work just fine.
FMW is offline
post #11 of 30 Old 07-17-2014, 05:47 AM
Liked: 5684
+1. For the sound to be different the plug would have to present a resistance load at least 10% of that of the speaker impedance load. With a 4 ohm speaker it would take a brass plug thirty feet long to affect the sound.
Only with a laboratory grade meter capable of 1/1000 ohm resolution.
post #12 of 30 Old 07-17-2014, 08:11 AM
audiovideoholic's Avatar
Quoted: 654 Post(s)
Liked: 216
Get'em Bill! I swear by my $350 hdmi dinosaur cables. Better picture and much better audio!
A $10 high speed hdmi cable is just as good as a $100+ monster if you ask me. The only cable I've ever spent more money on was a 25' high speed hdmi cable to connect to 4k pj and that was probably overkill.
darthray likes this.
audiovideoholic is offline
post #13 of 30 Old 07-17-2014, 09:18 AM
Liked: 5684
I have a 25 footer connecting my computer to my TV. It cost me four bucks, works perfectly. One of the benefits to digital transmission is that it's far less susceptible to noise and interference than analog, and is far less demanding of wire and connectors. That hasn't stopped the cable crooks from taking advantage of those who don't know that.
I remember when the CD was introduced, and suddenly you saw 'digital ready' stickers plastered all over everything from amps to speakers to wires. The inference was that if you didn't go out and buy all new 'digital ready' gear that you wouldn't be able to play CDs. The only difference between 'digital ready' labeled gear and that without those labels was the labels themselves.
post #14 of 30 Old 07-17-2014, 09:31 AM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 972
I didn't know banana plugs had a sound.
The is news to me. I just use them to make a quick, easier and convenient connection to the speaker terminals on both receiver and speakers.
http://sewelldirect.com/Sewell-Deadb...gs-12-Pair.asp
bluewizard likes this.
Afro GT
afrogt is offline
post #15 of 30 Old 07-17-2014, 09:50 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
there just always seems to be some kind of sales pitch in these types of threads. guess those 1k dollar interconnects aren't selling to well.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #16 of 30 Old 07-17-2014, 10:21 AM
89grand's Avatar
Quoted: 289 Post(s)
Liked: 163
I have 2 sets of these in different lengths from Sewell Direct. I have to admit, I only bought them because the price was reasonable, and they looked pretty good. I had no expectations of better sound because it won't happen, and that's good because I didn't get it.
http://sewelldirect.com/Silverback-Speaker-Wire-by-Sewell-15ftTerminated.asp
89grand is offline
post #17 of 30 Old 07-17-2014, 10:47 AM
AllenA07's Avatar
Quoted: 701 Post(s)
Liked: 571
I'll second the monoprice ones, they are what I'm using. As others have said, banana plugs won't do anything for your sound, it's just a matter of convince.
My Theater: The Ugly Theater
AllenA07 is offline
post #18 of 30 Old 07-17-2014, 11:19 AM
Quoted: 654 Post(s)
Liked: 216
Yea I think most of my hdmi cables were under $10.
I don't remember the digital ready era but obviously used what cables I already had when got my first CD player without issues.
post #19 of 30 Old 07-17-2014, 11:41 AM
DonH50's Avatar
Quoted: 2170 Post(s)
Liked: 1751
Now it's "HD anything" from TVs to cables to eyeglasses to an "HD Makeup Mirror" I saw at Wal-Mart (last time I go with wife-unit ).
I owned a heavy set of pure-copper banana plugs and jacks for a while. Proved to corrode and exhibit poor capture just like any other despite a design that improved contact (basically a screw down the middle of the plug to expand the spring strips). I much prefer to tighten down bare wire.
BTW, while you can plate Au on Cu, with pure copper the underlying metal is soft so chances are you'll quickly scrape off the gold. Brass instruments and fine gold-plated igtems tend to plate with Ag (silver) or Ni (nickel) first to provide a hard base layer, then plate gold on that.
If you want high conductivity, gold-plated solid silver should do it. I am sure the sonic benefits over regular Cu alloy and gold plating will be immense, as anyone who sees the gold/silver plugs will say.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #20 of 30 Old 07-20-2014, 11:02 AM
Liked: 0
I appreciate your advice to posters - BUT your accusation towards a SALES pitch - is out of line!
The OP ASKED - where can He purchase Gold plated copper banana plugs. He did NOT ask what would result in the best connection. As You can see He was advised there is no such thing - that is INCORRECT.
He was also advised COPPER is too soft...this worries me as my home is full of copper pipe! If copper is too soft to simply connect to a speaker terminal THEN it must be inappropriate for WATER.
I alluded to the fact with the CONDUCTIVITY information provided - IF HE CHOOSES to get the most minutest connection IMPROVEMENT & CONVENIENCE then GOD PLATED COPPER IS the way to go!
Be advised that IS the reason most knowledgeable Folks USE speaker wire ENDS - convenience. Especially IF you are changing between more than one Amplifier. I would further advise IF you are changing wires from one amp. to another - repeated removal of banana plugs will wear down little by little - consider SPADES Gold plated copper that is!
I mentioned a name as the plugs are very reasonably priced - and are actually COPPER. Many plugs out there are brass. The OP - I'm sure knows how to perform computer research; knows how to CONTACT PLUG sellers to ASK what metal is used - but chose to come to THIS FORUM to ask the POSTERS here. I gave Him the answer to His question. I DO NOT profit from giving advice! Just desire to HELP.
post #21 of 30 Old 07-20-2014, 01:25 PM
DonH50's Avatar
Liked: 1751
Silver is more conductive than copper or gold. If the OP wants to get "the minutest connection IMPROVEMENT..." he should get pure silver instead.
BTW, unless your water is very hard, speaker terminals are harder than water.
DonH50 is offline
post #22 of 30 Old 07-21-2014, 03:53 PM
Quoted: 111 Post(s)
Liked: 54
This is my first post. I felt compelled to sign up and correct some of the tragic misinformation being pushed in this thread. I am not an audio expert, I only know what I've learned through reading this and similar forums quite a lot over the last 6 months. What I do have is a degree in Physics (which contained electrics modules and audio/sound modules) and some minimal experience experimenting on my own system with the effect of different guages of wire on audibility, trying to find out what is the smallest wire I can get away with for a given distance because I'm on a tight budget.
Copper is soft, but its harder than lead which was used for pipes for centuries, flexibility over brittleness is necessary. The coins in your pocket are mostly zinc with a small amount of copper. Copper is not 'springy' like brass, you could still make a reasonably snug fitting plug using a different design but it would not remain snug fitting past a few dozen insertions/removals.
Copper wire is always coated in plastic insulation which prevents any corrosion. The ends that you've exposed for connection WILL corrode, and should be removed and fresh wire exposed every time you reconnect the wire or every 6 months, which ever is LESS frequent. (For example if you reconnect the same piece of wire a dozen times in a month, you don't need to expose new wire every time, but if its been a year since you removed that particular end of wire it will be significantly corroded and should have fresh copper exposed.) Gold is often used as a coating, because it does not corrode AT ALL, its very conductive and its ductile (easy to apply a very thin coating).
In dry air copper will not go green for a long time, it will dull significantly though. In very moist air or exposed to water and air it will turn a bright green quickly.
This is the crux of the error and misinformation in your gibberish Joseph. Firstly, giving conductivity as a percentage of copper is misleading (even though the figures are technically correct). For example stainless steel is 40 times less conductive than copper but it is still considered well within the realm of conductors in general, and therefore an inch of steel wire in a 10ft analogue signal chain would almost certainly be inaudible. Sea water is about a million times less conductive than steel, yet eels can use electricity to shock prey. Drinking water is about a thousand times less conductive than sea water, but is still dangerous around only 220v (even 110v for you yanks) of electricity. Glass, rubber, wood and air are about a billion times less conductive than drinking water, and only now are we firmly in the realm of insulators.
See what I mean? So a tiny layer (microns) of air is enough to disrupt your signal chain only because it is 20something orders of magnitude less conductive than copper. Unless your analogue signal chain has more than 1/40 of its length (so more than an inch of steel for every 3ft4 of copper say) made of steel, the steel will not add any audible effect whatsoever aslong as both wires have equal guage. The banana plug is a big lump of metal, much thicker 'guage' than the copper wire, it is also shorter by 100 or even 1000 times, so one sixth the conducitivty (for brass for example) will make absolutely no audible difference at all. Your nonsense about 'breaking the chain' is just that, nonsense.
A good rule of thumb is, as long as your entire analogue signal chain has less than 1/10-1/20 the resistance (impedence) of your loudspeaker there will be no audible effect. For digital signals the resistance of the wire only has to be low enough so the signal can be detected the error correction can do its thing, beyond that it makes no difference.
This, everything you said is spot on apart from the last sentence which is obvious (and pretty funny) sarcasm.
See my comments above regarding conductivity vs audibility. Yes, with a VERY sensitive ohmmeter you MIGHT detect a brass vs copper banana plug on 25ft of copper wire, but it could not affect audibly any audio passed over the wire, not a chance. You could negate the conductivity difference of the brass vs copper plug (so you couldn't even detect it with any ohmmeter) by just making the copper wire very slightly thicker (or shorter) for the brass banana plug. You are peddling nonsense and misinformation.
Ormy is offline
post #23 of 30 Old 07-21-2014, 04:32 PM
Liked: 5684
Perhaps if you live on a boat or in an ocean side home, but otherwise don't bother. If you want to be safe coat the wire with an anti-oxidant.
post #24 of 30 Old 07-21-2014, 06:09 PM
Quoted: 111 Post(s)
Liked: 54
Perhaps I was a little overzealous with my 6 month estimate lol, point taken Yes coating the wires is the best solution, I'm just too lazy for that
Ormy is offline
post #25 of 30 Old 07-21-2014, 07:32 PM
DonH50's Avatar
Liked: 1751
If the connections are properly tightened there should be minimal if any oxidation at the (inner) contact points. "Properly tightened" IME requires something other than banana plugs (something with more positive capture and seal -- like bare wire crush-fit).
There always conformal coating, works in space... A spray-can of commercial-grade coating will run you about $20.
DonH50 is offline
post #26 of 30 Old 07-09-2015, 11:34 AM
Liked: 0
To ORMY:
You read advice offered to posters and actually became ornery! You also state this is your first post - was driven to sign up just so you can provide your take on this! IMO - the only reason you responded here was to make a personal attack on Me - Joseph1975 as NOT once did you make any offer of assistance with your information to the original poster - but rather to ridicule - even there you got it wrong.
You over reacted to the information provided.
Here is a rule or guideline for you - when responding always have your response be within an attempt to HELP the Original Posters question or concern.
If you feel some information offered is incorrect in need not be insulting. You claim to have a degree in Physics??? Everyone, anyone with 'higher learning' - I've ever met was always respectful in sharing their knowledge - with class. You Sir are uncouth!
Yes, I seemed a bit arrogant - because the first response to the O.P. question was made without knowing. When offering advice it should never hurt someone, cost them or lead them astray. If you do not know for sure then do not post! It would be irresponsible to leave it not corrected.
Copper is soft, but its harder than lead which was used for pipes for centuries, flexibility over brittleness is necessary. Joseph says: However -with the right thickness and shape - copper will also have the springiness required in a Banana plug. I said I purchased them - all you had to do is ask about this and you would have received my answer that they work just fine. My use is removing them whenever I alternate between Amps to a single set of speakers - therefore they are receiving a good test of the materials effectiveness in a Banana plug.
The coins in your pocket are mostly zinc with a small amount of copper. Joseph says: No, the pennys in my pocket, if I still 'used' them, are 95% copper - I ceased carrying play money when the content was changed. All the large bottles I have filled with pennys are before the change to the lesser metals - If I remember right 1982. Here is interesting item for you: ever think what is the reason for 'something'?
The cell phone donations supposedly for the Troops - when I asked a Captain in Iraq - how do the troops feel about the cell phones - He said no cell phones ever came there. I found out the reason they were collected is for the small amounts of precious metal. Ever wonder WHY the change your coin to dollar machines popped up?
Not to relieve you of the burden of all those heavy coins or all those jars 'everyone has filled with heavy penny' - just ask yourself: How many pennys to the pound and then look up the price of a pound of copper. Ever ask what an Catalytic converter is worth in a junked car? Look it up you will be very surprised.
Without getting into the other passages you gave a weird twist to this one you and other might take into consideration:
One must 'read into' a posters question. He the O.P - I assumed must have nice equipment. The reason I believed He desired a plug of quality.
I for one feel IF the Audio companys choose copper for the internal wiring and speaker wire is copper - then I will continue the connectivity chain with - COPPER.
But again - I did not take it as the OP asking for the cheapest connectivity - regardless IF there is not an audible difference. Then You Ormy said you are on a tight budget. Well - if the OP has expensive equipment and when I have four Marantz (reference level) pieces; a Cayin A100-T (value over $3000.00) an Sansui 9090DB and an 8080db along with two pair of top of the line Definitive Technology speakers - do you believe I or the O.P. care about the cost or effectiveness of copper connectivity components??? Just 'the thought' I used the 'better' of the lot for my systems - makes me feel complete.
If after all the information is offered - an O.P. chooses to buy Gold plated anything - whatever makes 'you' happy. I must say though - my Wifes Uncle is in manufacturing and many of those audio accessories can be had for about $12.00 a DOZEN at times with shipping. Do you really believe it is GOLD the precious metal plated? I'll leave you with that - and that I did purchase several pieces from many sources here - had the resources to analyze them to find them to be 'junk'! A gold color plated zinc or at best brass. What I bought - I had to speak personally to the production manager to ask for the real thing. If 24 pieces of gold plated copper banana plugs for $20.00 is not help or answering a posters concern then what is? Even you Ormy could have purchased the 24 pieces and sold what you did not need to get your money back or reduce your expenditure.
post #27 of 30 Old 07-09-2015, 11:40 AM
cesar123's Avatar
Quoted: 376 Post(s)
Liked: 557
Yippee-ki-yay...
cesar123 is offline
post #28 of 30 Old 07-09-2015, 01:47 PM
Quoted: 111 Post(s)
Liked: 54
To ORMY:
Wow, and it only took you a year. Nothing I said was a personal attack, and helping the original poster is exactly what I was doing by pointing out the blatant misinformation and illogical arguements that fill your every post. Debunking the gibberish you peddle is a service I perform free of charge, enjoy while it lasts.
I will not speak directly to any of your points regarding speaker cable or termination method any further here, such nonsense is routinely debunked in much more recent discussions.
Audio Cable
Speaker Cables - choice
Notice how those people preaching the benefits of expensive cables and interconnects (like you) are quickly corrected by people with actual knowledge.
jdcrox likes this.
Ormy is offline
post #29 of 30 Old 07-09-2015, 05:56 PM
bluewizard's Avatar
Quoted: 1916 Post(s)
Liked: 1212
Any copper that has any Spring Tension is not pure copper.
If you want Banana Plugs that have tight positive connection, then get Locking Banana Plugs, of which there are many brands -
Sewell Harpoon Locking Banana Plugs 8-pair = $18.95 -
https://sewelldirect.com/Sewell-Harp...-Plugs-8-pair-
If you scroll down you will see a graphic explaining how the Locking Mechanism works. Basically, when you screw the outer sleeve up, it contacts to small side pins, these small side pins push a center pin that cause the end of the Banana Plug to expand making very tight contact with the Amp or Speaker Terminal Posts.
When you want to release it, simply screw the outer sleeve down, and the center pin retracts, and the plug can then be removed.
We can talk theory all day long, but in the end, it is practical reality we have to live with. Rather than being obsessed with trivia details that only have the most microscopic effect, if any, simply enjoy the music.
Still if a person want pure copper plugs, that's their business, but I suspect what they are really buying is frustration and headaches.
Still ... their money ... their life.
Steve/bluewizard
bluewizard is offline
post #30 of 30 Old 11-23-2015, 06:24 AM
Liked: 0
Just wanted to point out a couple of things:
All brass alloys are not equal (some have higher copper percentages but are softer)
I have used "pure copper" spades from Audioquest ... Can't say anything magical happened, looks very nice however.
99 percent of equipment used brass for the binding posts. Even Bryson, Mcintosh etc.
A previous post was right on with total loop resistance vs loudspeaker impedance.
Really the worst thing I can think of is having too much nickel or using too much solder. One of the reasons you bend legs of components over before soldering to a pc board is to establish a shorty path to the pad. One of the reasons I love surface mount is the components are touching. But I think of it like this. Despite an amp being wired with copper, and for benefit of doubt let's say it's a brand new amp equipped with WBT posts (SAE) it will be built with tons and tons of soldered components. That in itself introduces tin and other not so audiophile friendly metals. I cannot think of many manufactures using solder bearing over 4% silver.
Anyways sorry to muddy the waters just wanted to add that.
RDHaudio is offline
Reply Speakers
