Set up Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-06-2014, 06:45 PM - Thread Starter
robert3353's Avatar
Liked: 59
Hello all,
I will be ordering Klipsch RF-62 II Theater System that comes with a Klipsch SW-310 sub woofer on March 12 from Sound Distributors.  This will be my first home theater set up and will be using a Yamaha RX - V773 AV receiver to drive them and need some suggestions as to the correct type of speaker wire to purchase.  Also any links you may be able to provide as to the correct placement of the speakers especially where to put the sub woofer would be greatly appreciated.
Robert
robert3353 is offline
post #2 of 3 Old 03-06-2014, 07:29 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
crazyrob425 is offline
post #3 of 3 Old 03-06-2014, 08:13 PM
Bill Fitzmaurice's Avatar
Liked: 4630
The least expensive pure copper conductor wire of adequate gauge, which you can find out by using this:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Bill Fitzmaurice is offline
Reply Speakers
Yamaha Rx V773wa Receiver , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker
