RF-62 II - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-06-2014, 10:45 PM - Thread Starter
satanmayhem666's Avatar
I have this set of speakers.. 2 RF-62II Towers 1 RC-62 II Center 2 RS-52 II Surrounds, BIC Acoustech PL-200 x 2, Harman Kardon AVR 3700 7.2 AV Receiver. i usually listen to black metal music and i am looking for a better way to get the best sound quality from this set.. also wondering if it is a good idea to add two more towers for better voice clarity. my room is approximately 24x36.. any ideas will be really helpful.
satanmayhem666 is offline
post #2 of 9 Old 03-07-2014, 05:46 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
What about your current sound do you find lacking? That is a very large room, how far away do you sit?
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 9 Old 03-07-2014, 09:32 AM - Thread Starter
my current set up sound great , but since the room is big and i listen to metal music i tad maybe by adding 2 more towers the sound will be better , but i dont know if is a good idea , or maybe if there is a different pair of speakers to ad more voice to my current set up ...
post #4 of 9 Old 03-07-2014, 09:36 AM
Kini62's Avatar
Quoted: 1419 Post(s)
Liked: 1307
Add two more towers- where? Replace the surrounds? If so when running in 5 channel "stereo" it would help.
If you like the klipsch sound the only real upgrades would be to go to the RF7II or the Heritage line. In a room that size a pair of Klipschhorns would be pretty awesome.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #5 of 9 Old 03-07-2014, 09:37 AM
Liked: 1319
Music is being played through your front speakers, so adding towers elsewhere doesn't help you. Your receiver has pre-outs, so you could buy a discrete amp and give the front speakers more power since you are in a big space.
post #6 of 9 Old 03-07-2014, 09:48 AM - Thread Starter
the receiver i have, still have space for 2 other speakers ( avr 3700 H/k) . so if i add two other towers i will place them rig in the middle of the room or maybe two spear that produce a lot of voice ,
post #7 of 9 Old 03-07-2014, 09:54 AM
Liked: 1319
The thing is, music is played in stereo, meaning your front L and R speakers are the only ones working. Unless you switch to all-channel stereo mode or have mutli-channel audio like SACD or DVDA, then the rest of your speakers don't effect music. So adding two more speakers to make it 7.1 is not going to change how music sounds. You could upgrade the front speakers to the RF-82 II, and then move your current fronts to the back for surround, but just adding another pair of surrounds is a waste. Those Klipsch will play loud, so if you are running out of juice on your receiver, you might need to add an external amp.
post #8 of 9 Old 03-07-2014, 09:54 AM - Thread Starter
i may  buy an AMP thanks . this is my first time owning a set up like this , so i dont know to much about it
post #9 of 9 Old 03-07-2014, 10:06 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
I would do that first. Or when you play music just use the towers in stereo as you reciever looses a bunch power when running in all 5 channels
2 Channels Continuously Driven, 8 ohm loads: 151.1 watts (0.1% THD) 170.2 watts (1.0% THD)
5 Channels Continuously Driven, 8 ohm loads: 37.2 watts (0.1% THD) 40.6 watts (1.0% THD)
7 Channels Continuously Driven, 8 ohm loads: 27.9 watts (0.1% THD) 33.8 watts (1.0% THD)
http://www.soundandvision.com/content/harmankardon-avr-3700-av-receiver-test-bench
How are your speakers setup? Are you running a crossover for all of them? Running your towers in full range? If so, what?
crazyrob425 is offline
Reply Speakers
Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Black Each , Klipsch Rs 52 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Bic Pl 200 Acoustech Platinum Series Subwoofer , Harman Kardon Avr 3700 7 2 Channel Av Receiver
